4g94 mivec??
Old Sep 18, 2008 | 07:13 AM
  #46
bcollinstex's Avatar
That's at the wheel?
I would like to see a what a 4g94 block can do. I can see the enormous potential in a DOHC.
Old Sep 18, 2008 | 07:27 AM
  #47
llt-racing's Avatar
yes thats at the wheels, let see what happens when i install my original gearbox and DOHC ECU.
As it is there is plenty of potential
Old Sep 18, 2008 | 09:37 AM
  #48
smartidiot2122's Avatar
what is that in whp.... or is it the same
Old Sep 18, 2008 | 09:44 AM
  #49
depsy's Avatar
its not the same..you have to convert it...i forgot the exact numbers
Old Sep 18, 2008 | 09:48 AM
  #50
Approx 1 hp = 0.746 kW
Old Sep 18, 2008 | 10:44 AM
  #51
4g94T's Avatar
that would be about 119.3509653743 WHP
Old Sep 18, 2008 | 03:17 PM
  #52
KillahB's Avatar
I got about 115 whp. Roughly 15 - 20 whp more than the Lancer in stock form. Just about right for a head conversion. Now here's the tricky part that Luie will probably show us: if it responds to mods better ..... I'm almost sure it does. We'll see if a modded hybrid can give us something relatively close to RA / Si / SE-R / RS numbers.
Old Sep 18, 2008 | 03:49 PM
  #53
Jehuty's Avatar
So.......Marquez when are we going to do this on my car
Old Sep 18, 2008 | 08:27 PM
  #54
rpm_ruffryders's Avatar
thats it?
Old Sep 18, 2008 | 08:31 PM
  #55
drucea's Avatar
Well initially that's it. But that opens more doors to possibly better gains from bolt ons than before. Now instead of .5 hp from an intake, you might get 5-10. Like the rest of the cars in our range.
Old Sep 18, 2008 | 08:47 PM
  #56
i'm gonna wait for the other guys to try this before i do..
Old Sep 18, 2008 | 09:51 PM
  #57
KillahB's Avatar
Do what? You're like a woman ... you cant make up your mind
First its 4G64, then 4G63, then selling the car, now head swapping? Make up your mind, u bastid.
Old Sep 18, 2008 | 10:23 PM
  #58
doctorjon's Avatar
hahaha bastid??
This just makes me happy that im keeping my lancer stored away for greater things to come.
Old Sep 19, 2008 | 12:16 AM
  #59
llt-racing's Avatar
the main problem with had when the was in dyno is we were running out of RPM, the 93ECU cuts out 6899 or something rather, but as you can see there plenty more to squeez out of the motor itself. the red figure indicates the SOHC old dyno readings i cleared 20kw and a bit from its stock form.
my tuner said surely we can clear 100KW with the dohc ecu, adjustable cam gears and a hi flow cat im still using my original catalytic converter which is 130Ks old
I sold this motor last saturday i will build a new one with hi compression pistons, port and polish, 3 angle valve job, shaved head, ACL crank bearings and some cams for PR, and ofcourse bolt on mods. Will see where that takes me then but so far i am very happy with the gains.
Old Sep 19, 2008 | 12:18 AM
  #60
llt-racing's Avatar
Originally Posted by rpm_ruffryders
thats it?
there still a few more items i have to put back in the car it should be hitting 100KW next week + ill put some cam gears and SAFC. There is plenty more to go mate
