4g94 mivec??
Old Sep 19, 2008 | 12:54 AM
  #61
Lucas03ES's Avatar
I think that is one of the most beautiful things I have ever seen.
Old Sep 19, 2008 | 07:07 AM
  #62
bcollinstex's Avatar
Hmm. I was going to wait till I bolted on all the parts I've got piled up when I put a turbo on the car. Now, I'm considering holding off on the turbo and doing the DOHC head and seeing how far I can get an NA to go...
Choices...
Old Sep 19, 2008 | 03:22 PM
  #63
Jehuty's Avatar
Originally Posted by llt-racing
there still a few more items i have to put back in the car it should be hitting 100KW next week + ill put some cam gears and SAFC. There is plenty more to go mate
heh heh heh
He said mate
Old Sep 19, 2008 | 04:36 PM
  #64
smartidiot2122's Avatar
^lolz i was thinking that too
Old Sep 19, 2008 | 06:40 PM
  #65
llt-racing's Avatar
Choices...
ill be good im expecting with the ecu, cam gears and the right box will push over 100KW (136HP) respectively you guys are lucky RA gearboxes i believe is 4.0 final drive i had to build mine with mivec gearsets to get a 4.6 ratio and it cost me a lot i guess i can push the figures more with a SAFC
Old Sep 19, 2008 | 06:41 PM
  #66
llt-racing's Avatar
what up with that mate
Old Sep 24, 2008 | 09:56 AM
  #67
llt-racing's Avatar
i tried the car with above set up, no alteration got a best time of 15.06 in 1/4 mile w/2.31 60ft time consistently.
Old Sep 24, 2008 | 10:50 AM
  #68
drucea's Avatar
Well thats a big step up from the stock what? 16, 17 second quarter mile?
Old Sep 24, 2008 | 02:40 PM
  #69
WADADLIG_OZ's Avatar
That's the coupe version right? which is smaller and lighter than the 4 door Lancer in the US with the 4G94 engine.
It's basically the 2 door MIRAGE?
WADAD
Old Sep 24, 2008 | 04:56 PM
  #70
llt-racing's Avatar
no my car is a 4 door, tha night i ran full interior i have leather seats too i had no time to remove. I also sold my coilovers last sunday so i had to use stock struts with some lowering springs it was squating on hard launch.
Old Sep 24, 2008 | 05:31 PM
  #71
Jehuty's Avatar
just with the head swap you are now matching Ralliarts? No f-king way!
Old Sep 24, 2008 | 07:03 PM
  #72
llt-racing's Avatar
hmm well you can decide on that i dont know many ppl racing RA here. have a peek at my time slip bit blurry but you can just see it:-
mine is the one on the right hand side
Old Sep 24, 2008 | 08:18 PM
  #73
KillahB's Avatar
That seems awful fast for a 2400 lb car with 115 whp ..... Did you add more mods?
Old Sep 25, 2008 | 04:58 AM
  #74
llt-racing's Avatar
no i did not i cant plug in the dohc ecu because i need to bypass the immobilizer otherwise it wont start. I still have the 1.5 gearbox i can take pics if you like including the cat, its about right because with my sohc setup with bolt ons and 4G93 cam i was able to pass the 1/4 mile with the same gear above 15.560
next week i will install mivec gearset in my F5M42 gbox, cam gears and dohc ecu possibly if funds allow it a hi flow cat and get Toda to retune my reg again.
Old Sep 25, 2008 | 05:31 PM
  #75
Jehuty's Avatar
Wait so your 1/4 mile time was with what mods?
