4g94 mivec??
Old Oct 7, 2008 | 06:29 PM
  #91
smartidiot2122's Avatar
hey didn you say you were gonna get mivec cams for your dohc? hows it been so far?
Old Oct 7, 2008 | 06:32 PM
  #92
depsy's Avatar
im really interested in this conversion also, just sold my stage 2 camshaft to prepare for this
Old Oct 7, 2008 | 08:07 PM
  #93
drucea's Avatar
OK, so just for some extra info. What kind of things change when this swap is done? As in supporting parts, like spark plugs, wires, coil? Just wondering if those things change and if they are available at local auto parts stores. I'm really interested in this now too. Looks like it will open up way more potential for bolt on mods.
Old Oct 7, 2008 | 11:39 PM
  #94
llt-racing's Avatar
Me?
You cant fit mivec cams on this head.
Old Oct 7, 2008 | 11:46 PM
  #95
llt-racing's Avatar
For 4G94 need plugs (same as your sohc)
coilpacks i can probably organise something as an extra but two ppl down here shorten the boots of there packs to fit.
70mm idler pulley NSK part number PBT82
Timing belt supra 7mgte
Head gasket (same as sohc)
Rocker cover/spark plug gaskets
oil
coolant
I dont know about you but i usually i get the head rebuilt, light shave, acid dip or steam cleaned with new vavle stem seals.
We supply crank angle sensor to suit
Old Oct 8, 2008 | 02:47 PM
  #96
Jehuty's Avatar
So, with DOHC does that add more hp when you add bolts ons then with a SOHC? I'm a moron at knowing the difference between the two, and no I don't mean in the simple obvious nature of DUAL and SINGLE.
Old Oct 8, 2008 | 04:24 PM
  #97
ambystom01's Avatar
I think it would depend on how much better the DOHC head flows vs the SOHC head.
Old Oct 8, 2008 | 04:30 PM
  #98
Jehuty's Avatar
But I mean can it make a difference between the .0000001 gain lancers get vs 10 or 15 hp gain from bolt ons?
Old Oct 8, 2008 | 04:55 PM
  #99
drucea's Avatar
I think it does make a difference in bolt on gains. Like most cars in our group gain a decent amount of power from intake and exhaust whereas we only get 1-2 if that. With a DOHC I think the gains will match the other cars in gains.
Old Oct 8, 2008 | 06:42 PM
  #100
porterj5's Avatar
Will this work on an automatic lancer?
Old Oct 8, 2008 | 08:17 PM
  #101
Complink's Avatar
.o0(Turbo DOHC= . . . nice)
Old Oct 9, 2008 | 02:40 AM
  #102
llt-racing's Avatar
few pages back i had the following mods.
Bolt on mods, i was robbed with power with wrong gearbox, cat and stock sohc ecu.
I will update the results in a couple of weeks i will bolt on the following mods up top plus adjustable cam gears. I want to see how far i can push it before i do engine internals. So far the response to modification is very positive and there is plenty of potential specially if i have a SAFC or piggyback/standalone ecu.
Old Oct 9, 2008 | 02:41 AM
  #103
llt-racing's Avatar
I does flow a lot harder by far.
Old Oct 9, 2008 | 02:43 AM
  #104
llt-racing's Avatar
Yes it will, im going to install on a automatic mirage on november 5th
Old Oct 9, 2008 | 03:11 AM
  #105
llt-racing's Avatar
will certainly be good
