DarkMitsu's 4g64 Swap Page
Old Mar 17, 2010 | 11:05 AM
  #226
bvasquez12's Avatar
thanks, i never said it can beat an evo on the turns and througout the city, i said, can be just as fast, if not faster than an evo. Not, can be just as fast and handle as good as an evo. Where i live, thats all we have, 1/4 mile, and the occasional street race. so if i can take an evo on the 1/4 mile, i would be very happy. i would also rather have a lancer that i built on my own, than an evo that is stock, with no money for mods. Ill start my build thread next weekend, as soon as i start pulling the motor.
Old Mar 17, 2010 | 01:18 PM
  #227
Jehuty's Avatar
Either way, i wish you luck with your build as well. Just remember that your axles are weak and you're going to have to get custom ones which aren't cheap.
Old Mar 24, 2010 | 07:42 PM
  #228
bvasquez12's Avatar
so does the g63 head bolt RIGHT up to a stock g64 block? i came across an evo8 head and might just swap it out right away if thats the case. he wants/ 600 for the complete head.
Old Mar 24, 2010 | 09:06 PM
  #229
JRR's Avatar
JRR
as far as i know yes. i have found some information on that over on the eclipde 3g forums of guys doing it. as for whats all needed to complete im not sure.
josh
Old Mar 24, 2010 | 10:47 PM
  #230
bvasquez12's Avatar
hmm i did some more reading and seems like the g63 head isnt very beneficial until after you are boosted.One of the guys that did a write up on it only gained about 12whp and same the same track times running it NA. He also spent about 3k for the head swap parts including tuning. From what ive read, the best NA combo is, g64 block, optima head with the internals swapped out with evo parts. For boost, 64 block and evo head is best?
Old Mar 25, 2010 | 10:37 AM
  #231
gotrnet's Avatar
this may or may not be of help but i know in the 2g eclipse/5g galant, you have to block off 5 holes in the block that are exposed due to the difference in head size and shape. i just used freeze plugs and then the head just bolted on. mitsu may have redesigned the head/blocks for the rotated 3g version but i doubt it. as for which head to use, it is really up to you and your goals. both heads will work while the dohc will give you more top end power the sohc will keep the torque down lower. if you are going high HP you will want to go with the dohc because it flows better.
Old Mar 25, 2010 | 02:50 PM
  #232
darkmitsu's Avatar
hey guys I got something funny for you to watch http://www.youtube.com/watch?v=KH3sRpREwus its pretty funny ... Hey rpmrufferryder you still out there I want to know if your cam that you had cut made the mmwwa mmmmwwa mmmwwwaa wa noise , did it cam at idle? Watch the video you will understand...
I ran across a thread tonight on club3g this guy malachi with a 4g64 block with evo head post this "I ran this combo engine + no traction, i either went 13.3 @ 108mph or 13.7 at 111 mph depending on tire." that is turboed 16g setup running 15 psi on stock internals...
Old Mar 25, 2010 | 09:52 PM
  #233
*02Lancer*'s Avatar
ROLF^ i like the video.
Old Mar 26, 2010 | 07:08 AM
  #234
bvasquez12's Avatar
Yea i saw that same thread. 15 on stock internals!? Wow, if he got 13s then maybe in a lancer w slicks. 12s?
Old Mar 30, 2010 | 09:14 PM
  #235
bvasquez12's Avatar
damn this swap isnt as easy as it seemed haha, i got the differential in and ended up breaking a part of the shift linkage that goes inside the bell housing. so im gonna drop the trans off at a shop tomorrow so they can fix it for me. i guess my car will be down for longer than i expected
Old Apr 12, 2010 | 09:22 PM
  #236
bvasquez12's Avatar
Here is a pull video that darkmitsu sent me, he said i could post it since it takes him too long to upload vids.
http://www.youtube.com/watch?v=unzHYbam3nw
I also posted one on my Show and Shine thread of my car after i got the new header and o2 sensor working.
Old Apr 30, 2010 | 07:56 PM
  #237
bvasquez12's Avatar
Bump For Pull video
Old May 2, 2010 | 07:14 PM
  #238
03lances's Avatar
How is yours going? Havent had any updates for a bit
Old May 3, 2010 | 06:47 AM
  #239
bvasquez12's Avatar
its running, ive been driving her around for about 4 weeks, but it seems that Darkmitsus ROM isnt working well for me. Im running pretty rich but i already got an intake and RPW header, and next is an exhaust and im off to JMS racing for a tune. I think once i get it tuned ill have alot more response from it.
Old May 3, 2010 | 03:28 PM
  #240
darkmitsu's Avatar
Its kind of weird how the exact same settings work fine for one car , but the exact same flash wont work on another...
We are both running the 94170015 with the exact same settings...
The cel you see on my pull is from me running my car with no thermostat , I get a cel for insufficient coolant theshold , I run it that way because Those ebay fans arent worth anything for cooling , I need some new higher flowing fans ...
