Vacuum hose kinking
Old Nov 12, 2004 | 08:04 PM
4g94T's Avatar
Vacuum hose kinking
The "U" shaped hose that i changed always gets kinked no matter what i do. I've extended it and did the following on the picture. Does this cause any bad effects or mess with anything when it gets kinked?
Old Nov 12, 2004 | 08:10 PM
4g94T's Avatar
a closer look. this is what i did now to reduce the kinking, its not as bad as putting the hose shaped as an "U".
chinto's Avatar
uhh.. wich one gets kinked? looks nice but there a few that looked U
ahh.. got to the punch b4 i could type.. checking out..
k, two red hoses their is its some what non visable and coverd up by the one that semi looks like a streched out S
Old Nov 12, 2004 | 11:20 PM
Josh@Jive's Avatar
mine got kinked too... I decided to put the stock hose back on for that one
Old Nov 14, 2004 | 10:20 AM
4g94T's Avatar
yea, just wondering if it would cause any problems if i didnt put the stock one back
Old Nov 14, 2004 | 12:20 PM
myshtern's Avatar
There wont be any problems if you put the stock one back one
Old Nov 14, 2004 | 07:10 PM
ralli-art03's Avatar
If you want to stop the kinking, go to your local hardware store and see if they sell springs. I found at one place a spring that was 2 ft long that i could cut down to fit the vacuum hose snugly. Bring a piece of the tubing youre using with you so you can find the right size.
Problem fixed.
Old Nov 14, 2004 | 07:19 PM
SilverRally's Avatar
That same happend too me and my check engine light came on after 10 miles of driving the car. I finally figured out that it was that one that was causing the problem. Took it off and still the check engine light was on so i disconnected the battery and that fixed everyhing.
Old Nov 14, 2004 | 07:27 PM
alexis525's Avatar
i put the stock hose back on for that one...
Old Nov 14, 2004 | 09:19 PM
4g94T's Avatar
my ses light is always on because of my header, so i wouldnt know
Old Nov 15, 2004 | 02:32 PM
4g94T's Avatar
Problem fixed.
put the spring inside right?
Old Nov 15, 2004 | 02:34 PM
twardnw's Avatar
^yup
Old Nov 15, 2004 | 03:09 PM
4g94T's Avatar
thats a good idea, thanks
Old Nov 15, 2004 | 06:33 PM
I went to a true value hardware. they had all different size spring stock. If you don't have any little hardware stores you can always try home depot or lowes. This is great for any hose that makes a sharp bend or u-turn.
xRoguex
26
Mar 25, 2018 01:51 PM
Cajun Power
69
Oct 17, 2015 12:52 PM
MuslimEvoFreak
30
Dec 2, 2010 08:53 AM
cij911
Jan 23, 2009 10:50 AM
MSPlay
Feb 7, 2006 08:31 AM
