Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
DRL answer
Old Aug 20, 2007 | 01:08 PM
favre95's Avatar
DRL answer
You CANNOT shut the DRLs off. I work for a dealer and own a new 08 GTS. We hooked it up to the MUT this weekend. To shut them off. Because I want HIDs too. It wouldn't work. So we checked all the TSBs on the car. There is one TSB that says the DRLs cannot be shut off. Just for everyones info.
Old Aug 20, 2007 | 02:25 PM
Blacksheepdj's Avatar
Guess the folks talking about switching the headlight and foglight wiring are about the only ones getting HIDs...
Old Aug 20, 2007 | 02:35 PM
jRox's Avatar
womp womp.
Old Aug 20, 2007 | 02:44 PM
mughal87's Avatar
thats bad.. we cant turn DRL's off
i really wanted HID's in headlights... just got 6000K HID's in foglights.
need in headlights tooooo....
hope a soultion comes soooooooooon !....
Old Aug 20, 2007 | 02:52 PM
SeRious08's Avatar
Give it time. I have faith in Rob and the rest of the RRM team.
Old Aug 20, 2007 | 03:23 PM
FireFighter2968's Avatar
This would be the second Mitsu Employee to tell us that the ECU will Not allow the drl removal. I doubt RRM will have much luck other than a diffrent way around besides the Fogs. (not saying i doubt their abilities....)
Old Aug 20, 2007 | 03:24 PM
Eagles GTS's Avatar
Ill keep my fingers crossed
Old Aug 23, 2007 | 08:08 PM
psxnitro's Avatar
So what about that post in the HID thread with the bypass relay, is that bogus?
Old Aug 23, 2007 | 08:20 PM
favre95's Avatar
no probably not...I was just stating that you cannot shut them off VIA the ecu/mut-3.
Old Aug 23, 2007 | 10:59 PM
chetman7's Avatar
who wants take a trip to singappore and get some hid projectors
Old Aug 24, 2007 | 06:02 AM
jRox's Avatar
^^haha
Old Aug 29, 2007 | 06:10 PM
Lancer_GTS's Avatar
Could you leave the DRL bulb harness unplugged, then wire the HID's to the foglights. Then run a seperate switch to the foglights, and control them manually?
I know the computers are finnicky, but this might work? (If you feel like having a seperate switch of course)
Old Jan 17, 2009 | 05:57 AM
Drew84's Avatar
I work for a dealer too, we just tried yesterday to shut mine off in the EVO with the mut3. Doesn't work as stated above the only other thing we are going to try is pulling the relay.
Old Jan 17, 2009 | 06:15 AM
chetman7's Avatar
woa I thought this thread was dead.
I ended up splicing into the parking lights. Works like a charm to get rid of those DRL's
Old Jan 19, 2009 | 06:20 AM
kalpakiotis's Avatar
same here, i did it up under the plastic protector so now theres only an extra plug that hangs out for the ballasts. almost looks like its suppose to be there.
bandidom9
Outlander Sport
29
Dec 8, 2014 05:52 PM
itsPJ
May 11, 2013 10:20 PM
jtanda430
Sep 16, 2012 09:51 AM
AJ18
Lancer Troubleshooting
Oct 30, 2010 09:06 AM
kpac17
Oct 23, 2010 09:17 AM
