2008 Lancer "pulls to the left" Issue Petition
Old Jan 7, 2008 | 02:50 PM
  #136
emroc's Avatar
Hey all,
I'm glad I found this thread, I thought maybe it was just me.
My car (GTS) has drifted to the left from the beginning. A couple of weeks ago, I put on winter tires and steel rims and the problem was gone.
I had a look at the rims themselves after I changed the tires and I noticed a bunch of small weights on the inside. I could be wrong, since I only glanced at them momentarily, but I recall there being less weights on one of the rims than the other three. Could this have anything to do with the issue?
Old Jan 7, 2008 | 03:06 PM
  #137
ProRCRacer's Avatar
I took my Lancer to the dealer today to get alignment because it pulls to the left. They told me the alignment was off on the front end a little and on the rear end alot. I HAVE NEVER HIT ANYTHING WITH THE FRONT END. My car has been pulling to the left ever so slightly from the beginning when I wasn't able to tell for sure until now when it has progressively gotten worse to the point where I had to take it in.
I bumped a curb with the right rear a little while back. This bent a camber bolt and took the right rear out of alignment. Surprisingly, the car didn't pull either way any more or less. Recently, I rotated the tires. The right rear wheel with curb rash was now on the front right. When I took the car in today the dealer service manager told me that the warranty wouldn't cover the alignment. This is understandable for the rear because I hit something. But they insist I am the reason the front end is out of alignment. Can you believe he even suggested that maybe hitting the rear wheel on the curb knocked the front end out of alignment! I wasn't born yesterday.
Good news is the bolt was only $9.00, which they had to order. 4-wheel alignment is $79.00. I'm considering taking it to a local suspension shop instead. It's the same price and I'll be able to actually watch the mechanic do the work and not have to leave my car for the day. The mitsu dealer would have to take it to a suspension shop anyway because they don't have the necessary tools.
Old Jan 7, 2008 | 03:13 PM
  #138
Blacksheepdj's Avatar
Take it to the suspension shop. And since the stock front bolts are NOT camber-adjustable, get a set of RRM camber bolts while you're at it. Then they could actually *gasp* align the front camber.
Old Jan 7, 2008 | 06:40 PM
  #139
ProRCRacer's Avatar
I thought about that too but what do you mean by "gasp" align? Never heard of. But I know a little more neg. camber on the front might improve cornering.
Old Jan 8, 2008 | 12:05 PM
  #140
GS41_Lancer's Avatar
mine pulled to the left too, now it pulled to the right after i bought it back to service....... sigh..
Old Jan 8, 2008 | 10:42 PM
  #141
nj_08_gts's Avatar
Very true. But on a daily driver street car it's not a very safe idea to give yourself too much negative camber.
Old Jan 9, 2008 | 03:17 PM
  #142
The *gasp* was me being a sarcastic jerk.
Basically, I was just annoyed that I paid to get an alignment on my car only to hear "yeah, I couldn't change the settings on camber or caster, so those are just going to remain misaligned." Obviously it's not the mechanic's fault, but it's frustrating nonetheless.
Old Jan 10, 2008 | 12:49 PM
  #143
Mad_SB's Avatar
O.K.
First, sorry to hear about all the folks with this problem.
Second, the dealer's do not know what the F they are doing. I say this because of the OP's coment about the dealer showing him a print out saying it is in spec. You need to go to a real suspension shop and have them dial in the alignment. If you are in georgia, give gran turismo east a call. they are hands down the best. http://www.granturismoeast.com/
I had no less than five alignments done on my evo when it was new. two by mitsu, one by subaru of gwinette, one by some tire shop, and finally I went to gran turismo east. Never been anywhere since. Just because the machine says everything is in spec does not mean ****. If they knew anything about alignments they would know that.
Old Jan 10, 2008 | 03:30 PM
  #144
Nosman's Avatar
Originally Posted by mad_VIII
O.K.
it's not an aliment issue its a rubber issue . Switched tires and the pulling to the left dissapered !!!
Old Jan 10, 2008 | 04:18 PM
  #145
WhiteGTS18's Avatar
read up in the thread, i have changed my tires and my wheels and then stock wheels with winter tires and it still pulls and so have others. but could an alignment shop easily install the RRM Camber kit if i was to bring it to them? is it just swapping a not adjustable piece with an adjustable piece? because i think i might just get that and get a nice alignment and just f$%@ mitsu.
Old Jan 10, 2008 | 08:11 PM
  #146
ProRCRacer's Avatar
I'm with ya. I'm sure the alignment shop can install the rrm camber kit. You could probably install the kit too. Ballpark the settings, drive it to the alignment shop and let them precisely set it up.
Old Jan 12, 2008 | 08:32 PM
  #147
WhiteGTS18's Avatar
yeah ill probably just pay them to slap em on cause its winter and im lazy and that way if there is a problem it is their problem and not mine.
Old Jan 19, 2008 | 10:39 PM
  #148
g.romay's Avatar
hey
my car also pulls to the left, its a stock ES. i suspect its the tires, not sure do.
one thing im sure of, the dealer is a disappointment.
Old Jan 29, 2008 | 10:43 PM
  #149
08MitsubishiGTS's Avatar
Just got my 08 Lancer GTS CVT and I too notice a pull to the left
Old Jan 30, 2008 | 10:39 AM
  #150
You know, I'm going to unstick this. This "petition" is going nowhere, and the OP hasn't even come back. The point of having a petition is to SHOW it to someone and get changes made. Not to slap it up on the web and ignore it.
