post all STRANGE NOISE complaints here
Old Nov 4, 2010 | 10:49 AM
  #136
Antonovich's Avatar
I started getting a little crackling sound around the corner of my windshield by the driver's side. I don't think it's the windshield at all, but from that area. at first i thought it was my tweeter (sounds almost like a speaker crackling) but it's not. I can turn up the stereo and it drowns out the sound, not get worse. it seems to be worse the fast i go so i'm thinking the wind is pushing against something.
I took a quick look over and the pillar and everything seemed to be tight so i can't think of what it could be.
Old Nov 4, 2010 | 01:22 PM
  #137
yellerozrally's Avatar
Originally Posted by mci2727
Is it like a valve tick?
How long has this been goin' on and did it start when you installed the camshaft or later on?
Well a valve tick is common in a Mitsubishi thats what i thought at first.
It just started like 2 weeks ago, and I installed the cam back in march, so its been normal for 8 months, till now.
Old Nov 4, 2010 | 08:47 PM
  #138
mci2727's Avatar
Man yeah then, I'd be leaning to a valve tick.
Hope it's something else that's a easy fix though.
Old Nov 4, 2010 | 08:49 PM
  #139
mci2727's Avatar
I would pull the radio fuse out and see if you still have the sound.
It could be low fq sound bleeding through your system to your tweeter.
If this is it, then it'll cook your tweeters core and make it sound like crap.
Do you have a good eq in your system or just the one on the radio?
Old Nov 5, 2010 | 09:43 PM
  #140
ya thats what the shop said, and it could be that I may try to change my oil more often than 3000 miles. So ill know this next weekend if thats it or not..
Old Nov 6, 2010 | 02:27 PM
  #141
mci2727's Avatar
Could help.
Also a oil additive like engin restore or something might help.
What kind of oil do you use?
Old Nov 6, 2010 | 08:33 PM
  #142
Could help.
Mobile 1 full synthetic 5w30, ya that could work. I know that my engine is not going out or I would be loosing power, and i would be eating oil... Witch its not.
Old Nov 28, 2010 | 04:56 PM
  #143
IAmADirtDude's Avatar
Timing Belt Squeel need help please!
I've looked for days and am looking for some advise trouble shooting the squeel.
It's hard to hear with it running where the noise is coming from i thought it was the alternator. so i changed the belts and the alternator and sprayed lube on the idler pulley and it still squeeled. it is a constant squeel and doesnt seem to change much but always squeels.
I just so happen to Tap the TIMING BELT plastic cover with a hammer handle and the squeel stopped.
Old Dec 29, 2010 | 04:35 PM
  #144
Gotum209's Avatar
Hey guys i just got my car, 2003 lancer oz, and when i turn it on a fan sound turns on really loud and it stays on for like 5-10 seconds after i turn it off??
idk if thats normal, any suggestions??
Old Jan 13, 2011 | 09:58 AM
  #145
kevo1212's Avatar
i have an 2003 lancer es 2.0L 4 cyl with about 127,000 on the motor new auto tranny been sitting for 2.5 years and new pan gasket and valve cover gasket, i am up to date with my services do all myself, problems is its ticking and doing some sort of slight knocking what may it be
tell me how to post a vid of it and i can show ya
Old Jan 13, 2011 | 10:09 AM
  #146
kevo1212's Avatar
Old Jan 13, 2011 | 10:18 AM
  #147
kevo1212's Avatar
Originally Posted by bettorer
my car revs to about 2ooo rpms when i start it for a minute or so. is this normal
your air adjuster on your throttle body to turned to hight you need to adjust it and turn it down a bit just letting to much air throught at idle
Old Jan 13, 2011 | 11:22 AM
  #148
kevo1212's Avatar
is this with your a/c on or just when the motor is warmed up?
Old Jan 31, 2011 | 01:48 PM
  #149
piledrivingdude's Avatar
I have Mitubishi Lancer 2003 and the motor squeals when I start it up. It stops after a few seconds. I've checked the belts and they seem snug enough.
Old Mar 10, 2011 | 04:24 AM
  #150
Ghettofireman's Avatar
I just put a 2005 engine and turbo into my 2003 evo cause it blew and a new clutch. After breaking the clutch in I was able to get on it fine. It is set to stock boost I have a full 3 in exhaust to the housing and the injen intercooler piping and intake I'm still on my old tune. So I put a boost controller on set to 20 psi oh sorry old tune was set to 25.5 psi. When I got on the car set to 20 psi it started to make a loud squeal or whining noise so I set it back to stock. Now that I have it back to stock it only hits 12 psi and the turbo still makes this loud noise. Now I don't even go into boost I did check all the hoses and intercooler piping and it is fine. I didn't do a boost leak test yet but my vac is at 20 and down shifting it goes to 25 . I will check again but there was no shaft play on the turbo any help would be great thanx
