Tow Rigs, What do you have/use?
Old Jul 4, 2014 | 08:30 PM
  #421
psushoe's Avatar
Is that the explorer with the ecoboost v6? I was curious how they handled a trailer.
Old Jul 4, 2014 | 09:21 PM
  #422
CooperS7777's Avatar
It is; and it tows pretty well. There is more than enough power for towing this setup; it's the same motor as in the trucks mounted transversally instead of longitudinally.
I've moved my 24' Formula a few times with it as well and I'm sure that's more than the evo/trailer. I know with my evo on the back, this setup is probably slightly over the 5k max tow capacity, but it handled just fine. The trailer is equipped with electric brakes on both axels, and I was running a brake controller.
Old Aug 6, 2014 | 07:30 AM
  #423
SLOEVO71's Avatar
built a custom trailer hitch for the evo X, just a class I, but it gets my dirbike to the the track!
Old Aug 12, 2014 | 10:05 AM
  #424
Brianawd's Avatar
05 Jeep liberty crd. Has upgraded torque converter,trans cooler, full exhaust and a hot tune. This was a test to see how I like towing the car on a dolly(yes I un-bolted the drive shaft at the rear diff). Weight of the car and dolly was 4,078lbs. I was able to get 20.1mpg round trip. Not sure if I like towing with a dolly or not. Sucks not being able to back up.
Attached Thumbnails Tow Rigs, What do you have/use?-crdevo.jpg
Old Aug 12, 2014 | 12:25 PM
  #425
Gordian79's Avatar
Here is mine 2006 Ram 3500 Diesel(obviously) Yea its modded i know its a bad habit.makes around 400 hp 790 ft lbs tq.I tow a 26' enclosed trailer with it and i get around 16-17mpg towing about 12000lbs.Empty i get around 24mpg or more if i drive slow.
Old Aug 12, 2014 | 02:57 PM
  #426
WestSideBilly's Avatar
El Jefe
Did you find that your mileage went up after modding it?
Old Aug 25, 2014 | 09:29 PM
  #427
BubbaKush's Avatar
Do you have to remove the front bumper on Evo with Stock suspension on enclosed trailer?
Old Aug 26, 2014 | 06:12 AM
  #428
Balrok's Avatar
Not normally unless your at a super odd angle. And even then you can level things out with wood/ramps or what not.
Old Aug 26, 2014 | 01:02 PM
  #429
xXANCHORMONXx's Avatar
So I've been towing my Evo with my work truck with no issues. Its a 2002 1500 Silverado long bed with a 5.3 V8.
I added rear leaf springs to reduce squat, poly bushings, derale trans cooler, and an 8000lb hitch.
Power is ok, but stabilty was lacking.
Unfortunately it died yesterday due to a failed fuel pump and since I need to my truck to work I decided to buy a new one.
Its a 2014 GMC Sierra SLE 2500 HD with the 6.0 V8. It has a 13000lb tow rating which is more than enough. It came with a trailering package, so Anti Sway, trans cooler, oil cooler, brake controller, and all that good stuff. Hitch that came with it is rated at 18000 lbs.
I almost got a diesel but it was 10K more and the two rating is the same with the regular hitch. With a gooseneck the diesel can tow 3000 more.
For what it needs to be this truck is perfect, I couldn't be more excited to tow my evo to the track.
Old Aug 28, 2014 | 10:38 AM
  #430
Balrok's Avatar
Purrty truck. Once you go diesel though you never go back because you learn how much better it is at......well everything .
Old Aug 28, 2014 | 11:19 AM
  #431
mouseIX's Avatar
When are you going to post pictures of that shiny enclosed?
Old Aug 28, 2014 | 11:44 AM
  #432
mx4life85's Avatar
This thread is awesome. More pics please! And nice new GMC!
Old Aug 28, 2014 | 12:55 PM
  #433
Balrok's Avatar
This weekend likely, ima bring it home to start doing shelving and winch. Or do the control arms and alignment. STILL haven't heard anything from R/T on arms....
Old Aug 28, 2014 | 01:45 PM
  #434
flawlessninja's Avatar
I just picked up a 2000 Chevy Tahoe with the 5.3l V8 for a tow vehicle/winter DD. I'm new to the truck game, but I'm sure it'll haul the X just fine... anyone here have experience with that combo, good or bad?
I don't have a trailer yet, but hoping to get an enclosed one early next year.
Old Aug 28, 2014 | 01:46 PM
  #435
Thank you sir!
