Tow Rigs, What do you have/use?
Old Oct 2, 2014 | 08:55 AM
  #451
GTABurnout's Avatar
Originally Posted by psushoe
You get a lot of squat from the suspension, but it still looks like too much tongue weight. Try moving the car back a little.
Originally Posted by Dallas J
Just looking at the car position on the trailer, and knowing the evo is 60% front heavy, that car is way too far forward of the axle. You need to weigh the tongue.
Or a simple dirty way to guess is to measure the hitch, stand on it and measure how much it moves. Easy math to your rate and to how much it should move with 12-15% tongue weight.
I agree. First time towing with such a little truck and I wanted to make sure I had enough tongue weight to prevent the dreaded sway that happens when the trailer and car weigh more then the truck your towing with. The trip home was a little better balanced. Next time i will grab another picture of it more level. Also remember its a Tacoma lol not a full size shes going to squat.
Old Oct 3, 2014 | 08:27 AM
  #452
Dallas J's Avatar
Veteran: Army
Yeah, I don't worry too much about the squat as long as tongue weight is appropriate of the load.
Once you start using a load distribution hitch though, towing will be 1000x more enjoyable. Our trip to Nebraska (3800miles towed in total) we cruised at 80 almost the entire way with the Jeep. First day of driving the weights were just a little off and it felt a bit twitchy in the hills on the corners. I moved the Evo forward 2" (I measure to repeat the setup and would highly advise it) and it rock steady the rest of the trip.
Old Oct 4, 2014 | 05:59 AM
  #453
psushoe's Avatar
I leave the rear straps fixed and only tension with the fronts. Once you find the right spot, it is easy to get it every time.
Old Oct 4, 2014 | 08:11 PM
  #454
Dallas J's Avatar
Veteran: Army
Speaking of which, what do you strap to? I go over the subframe but it can be a pain at times to fish through. Its as solid as things get but isnt quick and easy like the front hook.
Old Oct 5, 2014 | 03:26 PM
  #455
griceiv's Avatar
strap to the chassis t-slots at 4 corners (in front of rear wheels, behind front wheels). the front and rear "tow hooks" are definitely not structural. I've seen them rip off
Old Oct 5, 2014 | 05:02 PM
  #456
Dallas J's Avatar
Veteran: Army
I haven't used the rear since that's just tacked to a large sheet metal panel but the front has been solid. Guess I need to put in an order for some T-hooks though.
Old Oct 6, 2014 | 04:57 AM
  #457
honda-guy's Avatar
i use T-hooks on all 4 corners. easy to get to and more secure.
Old Oct 6, 2014 | 07:01 AM
  #458
psushoe's Avatar
I have always used the rear subframe and front t-hooks. Might try the rear t-hooks next time, since I just got an extra pair.
Old Oct 6, 2014 | 06:02 PM
  #459
FilthyEvo's Avatar
Originally Posted by GTABurnout
Not going to break any speed records but for now it gets the job done.
2007 TRD Tacoma
Mid Travel Icon Suspension
285 MTR's
Way too far forward.
Evo looks great though.
Old Oct 6, 2014 | 06:05 PM
  #460
FilthyEvo's Avatar
I tow a 20ft enclosed aluminum V-nose with my 2000 F350 7.3 - pulls it like it's not even there.
Averages 11.5-12.5mpg.
Old Oct 16, 2014 | 08:51 PM
  #461
letMeIn's Avatar
Old Oct 16, 2014 | 10:13 PM
  #462
BrendanS's Avatar
...painful going through this thread. Hope to be able to post in here one of these days
Old Oct 17, 2014 | 03:08 AM
  #463
Balrok's Avatar
Same, I tried putting the Thooks in the rear but it's too far "up" for the hook to get in, using the reg ones from Northern tool.
Old Oct 17, 2014 | 03:11 AM
  #464
Balrok's Avatar
Originally Posted by letMeIn
Also a bit far forward, reason we say that is because 60+% of the evo's weight is on the front, and it's on the tongue rather then near the trailer axels. So if you back up the car to where it clears the rear by a couple inches then the majority of the weight will be directly above the trailer suspension and it won't droop the truck as much, thus tow better.
Old Oct 17, 2014 | 06:16 AM
  #465
honda-guy's Avatar
i use these t-hook with ring. i don't have any issues getting the t-hooks on, from the side of the car, don't even need to get under the car. the driver side is a little tight because of the fuel line and evap line, but you'll get a hang of it after a couple of times.
Attached Thumbnails Tow Rigs, What do you have/use?-t-hoo-link-towing-part-455191_2.jpg
