Tow Rigs, What do you have/use?
Old Dec 7, 2014 | 12:24 PM
  #496
killerpenguin21's Avatar
figured i could get an accurate answer here.
what is the correct size trailer for an evo (for both open and enclosed)? i seem to recall it needed to be 18 feet long. other car id be towing is an s2000 so if the evo fits that will too.
ive started craigslist surfing and found a few pretty decent looking deals.
Old Dec 7, 2014 | 03:17 PM
  #497
honda-guy's Avatar
my Econo Trailer 15' works fine. Its the lightest steal trailer and also cheapest, I paid $2400 shipped for it new. I've towed Evo, E36 and CRX with it.
http://www.econotrailer.com/Open.html
Old Dec 7, 2014 | 04:43 PM
  #498
and here i though $2500 used was decent...looks like ill probably pick one of those up. your so helpful thai!
Old Dec 7, 2014 | 05:28 PM
  #499
Sawdust's Avatar
Steel and it only weighs 1450 lbs, interesting...
Old Dec 7, 2014 | 06:29 PM
  #500
honda-guy's Avatar
^ yeah, it's even lighter than some open deck aluminum i've found when i was looking.
Old Dec 7, 2014 | 06:32 PM
  #501
honda-guy's Avatar
took them like 4 weeks to build mine when i ordered. so call them and check the lead time if you're interested in one.
Old Dec 7, 2014 | 07:05 PM
  #502
honda-guy's Avatar
the 15' is a perfect fit for the Evo, but not much room to move it forward if add a tool box in front, if you ever have to move the car forward for load balance. but the evo is front heavy, so you don't really have to move it that much forward. you'll have plenty of room even with front splitter.
I added tool box and brackets for gas jugs.
here's me towing marc's car, notice the pit bike in front of his car. it was tight but just enough room.
Attached Thumbnails Tow Rigs, What do you have/use?-img_20140611_183656a.jpg   Tow Rigs, What do you have/use?-img_20140828_135236-01.jpg
Old Dec 7, 2014 | 07:17 PM
  #503
i8acobra's Avatar
As for rigs, I used to tow a 3 car wedge trailer with a Dodge 3500 dually, Cummins, stick shift. Yep, with an exhaust brake. Probably a wee bit overkill for a single car, but you could always rent space to other people going to the same event. Oh, but you'll need a CDL. ;-)
Old Dec 7, 2014 | 08:23 PM
  #504
they sell an 18 foot too. it would be nice to have enough room to add a winch an tire rack eventually.
Old Dec 8, 2014 | 08:26 AM
  #505
heel2toe's Avatar
Yeah I was just poking around on their site and saw the 18' one as well which caught my eye. It's only 100# heavier than the 15' one so the additional weight should be insignificant. I guess the only downside is that you are hauling an extra 3' in trailer.
Thai- did you outfit your trailer with heavier duty axles, brakes or wheels?
Old Dec 8, 2014 | 10:24 AM
  #506
CooperS7777's Avatar
I went 20' Nate, knowing that I would end up towing a few different things.
What are you towing with? I hadn't seen the Econo Trailers before I made this purchase but they look like a solid option, the weight is really impressive. I was restricted in what I could get based upon weight; the sport is all we have to tow with right now.
So far Ive had my TBSS, a couple Evos, an SC300 and a mini truck on the trailer.
Old Dec 8, 2014 | 10:32 AM
  #507
psushoe's Avatar
I use an 18' closed deck. The car sits near the back to keep the tongue weight in check, so I have plenty of room up front. I usually haul 15gal of fuel on the tongue, a set of wheels/tires in front of the car, and two bikes mounted in front of and down the sides of the car. I found a set of fork mounts that work great and just throw the front bike tires in the car. At some point I might get more creative and put a storage box on there for spare parts with a tire rack. The extra 3' really gives a lot of options to take extras.
Old Dec 8, 2014 | 10:53 AM
  #508
honda-guy's Avatar
yeah, i was trying to keep trailer weight down to minimum. plus it's 3' less that i have to worry about when maneuvering around. i got the standard axles and brakes. i made my own mount for the spare and got the spare at walmart.
i did have to tighten all the wheel bearing nuts at the end of the season.
Old Dec 8, 2014 | 10:55 AM
  #509
honda-guy's Avatar
i don't fill the gas jugs up till i get close to the track
but i guess you run e85, not too many options around to fill up
Old Dec 8, 2014 | 11:02 AM
  #510
tow vehicle is my uncles 2500HD with the duramax and allison trans....weight is not an issue
