Gridlife Trackbattle 2018 Discussion
Northwood has an much older crowd and GPS has a bit younger crowd. I preferred GPS because the crowd is closer to our age and I like the organizer. Both are great groups to run with.
The only thing I will say, if you want to learn how to go fast. Ruining time attack at Gridlife. This is where I learned that I wasn't that fast. LOL
If you're not in for the partying, (I'm not either) There are a lot a seriously fast guys that are friendly, willing to openly share information, and help. It's a great racing event in that aspect.
Yea the longer gearing would definitely be nice. If it's under a grand then that's a pretty good price. I was already planning to go to TRE since they're somewhat local, just a couple hours away. I haven't seen enough good reviews of the carbon synchros to think they'd be worth upgrading to.
I agree with EVOizmm, Stay away from dogbox/faceplate. A properly built synchro trans paired with a proper clutch (Exedy twin) will shift quickly and last much longer.
TRE is awesome. He does all my trans work. He now sells a straight cut 4th gears with double synchros. They will last a lot longer than the single and take more shifting abuse.
I've been running a Comp sprung stage 4 clutch and really like it. Hasn't given me any issues shifting. The two big downsides to a twin disc to me are more weight and $$$. When the time comes for me to make more than 500whp I'll probably make the jump to a twin.
A proper dog box or even faceplate system will absolutely shift faster than a synchro box in nearly any case. Unfortunately the performance and reliability is much more up to the driver at that point, so there is always going to be mixed results.
Zack
Zack
If you have a race car that only lives at the track, then you can run something like a Quarter Master. Since the car doesn't see much run time.
Lets talk tires quickly. So I was under the impression my class was limited to 255 width and 100TW. Apparently it's unlimited width. I've run "275" width tires on my car before with R-Compounds and Full Slick.
What is the 100TW tire of choice? Pro's Con's?
I'm looking at NT01s, RS4s, 595RS-RR, RE71R. I'm leaning away from the RE71R due to concerns about it not taking back to back hot laps.
What are you guys running?
Seems like everyone who's not in unlimited is running the RE71R. None of those other options are as soft from what I've seen. The NT01 will hold up better long term but you'll be giving up some time.
I was interested in trying to run Federal FZ201 as it's a 100TW rcomp and they offer medium and soft compounds but I've yet to find any reviews on them.
I'm not worried about being in the top times, willing to give up times for being able to get more full-pace seat time per session and get the experience. Having my tires hold up better, be less expensive to run in the season. NT01 and RS4 seem like good candidates.
How do the NT01 and RS4 compare?
Economy tires below.. thoughts?
Federal 595RS-RR
Nexen N FERA SUR4G
Federal FZ201 - can't tell you anything about them. What about a Maxxis RC-1?
Federal 595RS-RR
Nexen N FERA SUR4G
Federal 595RS-RR
Nexen N FERA SUR4G
I run 275/35 RC1s on my evo. They're great trackday tires because they wear pretty well and have a pretty good amount of grip. Priced pretty well, fairly similar to an NT01 from what I've heard. You need to put a good amount of heat into them to wake them up though so they're not the best time attack tire.
So I signed up for Gridlife South Festival last Friday. Looking forward to my one Gridlife event this season. Plan is still Street Modified AWD on 255 Hoosierstones. I will debate a turbo upgrade and switch to E85 once the summer starts and my NASA TT4 season has a break.
