Old Oct 7, 2019 | 02:35 PM
  #961
Ayoustin's Avatar
That sounds like a valvetrain tap, possibly a sticking lifter. Stop running that trash oil and give your car something better if you're going to track it.
Also, I'm super jealous UMC is your home track. It's on my bucket list.
Old Oct 7, 2019 | 02:39 PM
  #962
Bee-Raddd's Avatar
Originally Posted by Construct
No aftermarket pan yet, but I only track and autocross the car on 200TW tires.
Utah Motorsports Campus is my home track. The NASA end of season event runs all four track configurations across two days. Was a great event until the car started making noises.
Sounds like something is broken in the head. Lift the Valve cover off and have a look around. broken spring or lifter or something possibly?
Always hard to tell from a video as the sound definition just isnt there. doesnt sound like rod knock to me thats generally more pronouced of a sound
If u find nothing from taking the valve cover off give it a compression or leak down test i guess if your worried.
Old Oct 7, 2019 | 02:43 PM
  #963
Construct's Avatar
What oil do you recommend?
Hit me up if you come out this way. I live less than an hour away from UMC.
Old Oct 7, 2019 | 03:36 PM
  #964
LetsGetThisDone's Avatar
That's not rod knock. It's something in the valve train. Pull the valve cover and take a really close look at everything.
Old Oct 7, 2019 | 04:29 PM
  #965
kyoo's Avatar
why would it have gone away? sticking and then unsticking? you revving at 8k over there or what @Construct
Old Oct 7, 2019 | 06:24 PM
  #966
Ayoustin's Avatar
Amsoil, Redline, HPL, Bradd Penn, any high grade motorsport oil.
Rotella has a lot of detergents in it and any most decent tests I've seen of it show it as a mediocre at best oil. I'd run in it a tow rig of a daily driver, not anything that touches a racetrack.
I doubt I'll ever make it out to the Salt Lake area but if I do I'll reach out. Thanks dude
Old Oct 7, 2019 | 08:39 PM
  #967
Biggiesacks's Avatar
Check the cam timing, belt might have jumped.
Old Oct 8, 2019 | 05:00 AM
  #968
Project_Broke's Avatar
I've always had good luck with T6. Enough to keep me from the high dollar oils anyway.
Hopefully whatever this is isn't catastrophic.
Old Oct 8, 2019 | 07:39 AM
  #969
kyoo's Avatar
Do you guys have any other suggestions for pads aside from ST43s? I am having a lot of trouble actually being able to trail brake due to how grabby the pads are. Just a brush of the pedal seems to slow the car down much more than I'd like.
Old Oct 8, 2019 | 08:19 AM
  #970
RazorLab's Avatar
Really? I've never had that problem with ST43 or even ST47's.
Old Oct 8, 2019 | 08:33 AM
  #971
Construct's Avatar
Are you running ST43 front and rear? Or just front?
With ST43 front / DS2500 rear I have no problems with initial grabbiness. Trail braking is nice and smooth.
Old Oct 8, 2019 | 08:58 AM
  #972
Sounds like you're not getting them all the way up to temp.
Old Oct 8, 2019 | 09:15 AM
  #973
kyoo's Avatar
St43s in front only, s/s (similar to ds2500) in rear
maybe i just need to train my braking foot a little better. they are def up to temp lol.
Old Oct 8, 2019 | 11:25 AM
  #974
Bee-Raddd's Avatar
Try pagid RST3. They arent super grabby and dont go off either. Really good all round pad.
Old Oct 8, 2019 | 11:26 AM
  #975
Bee-Raddd's Avatar
I would agree but the OP reckons the noise went away once the car cooled down. and i dont think the cambelt would have decided to jump back a tooth again once cold haha.
