Upgrading 8/9 front brakes
Old Dec 8, 2021 | 12:14 PM
  #136
kaj's Avatar
kaj
Originally Posted by ayoustin
I know lots of stuff in the rear of the X are different. As long as the radial depth of the rotor isn't smaller than the 8/9 then yea it wouldn't be too hard to do rears for an X in similar fashion. I'd just need to get my hands on a car to take measurements.
Edit: Woah, turns out Centric now sells replacement MR front rotors. Maybe that's nothing new but I was under the impression no one was making OEM replacement 2 piece rotors. Price isn't terrible either at around $200/rotor.
Me thinks I should snag a set or two.
Old Dec 8, 2021 | 12:40 PM
  #137
LetsGetThisDone's Avatar
Those Racing Brake calipers look very similar to the generic Taiwanese calipers I see tons of companies use in their "bespoke" brake kits. The fact that it doesn't have any bridge over the pads would make me think it isn't much stiffer than the factory caliper either.
I'd be much more inclined to go the Aero6 on a stock or X rotor route. I've had no issues with the Aero6 on my car other than the fact they could be a bit lighter (still lighter than stock) and I have to remove them to change pads.
120.46073 and 120.46081 for left and right respectively.
The Aero6 is nicely affordable. My car already has X front brakes. I think that could be a great upgrade. Why do you have to remove them to change pads? Does the bridge not come out?
Turn14 doesn't show, and Summit shows as NLA for both those centric numbers. And they're not on centrics site anymore.
Old Dec 8, 2021 | 12:46 PM
  #138
kaj's Avatar
kaj
I found them. I have a local distributor I'll be calling today.
https://centricparts.com/part-detail/12046073
Old Dec 8, 2021 | 12:49 PM
  #139
Ayoustin's Avatar
Aero6 is a very good balance between price and performance and they'll work on the X rotors. And yes the bridge is integral to the body of the caliper so it is not removable. Overall I think they're a great option for guys not trying to go broke on brake upgrades.
I pulled the numbers directly from the Centric catalog on their site.
Old Dec 8, 2021 | 12:51 PM
  #140
Let me email my Turn14 rep and see if we can get those added. My guess is there will be a lengthy back order on them though.
For anyone off EvoM I could make a pretty good price on the Aero6's for you.
Old Dec 8, 2021 | 01:03 PM
  #141
Dallas J's Avatar
Veteran: Army
FYI, If you wanted to use my brackets I only make the offset for the 17mm pad (5.2ci not 6.6ci) which matches the OEM thickness. Austin runs the thicker version but I chose to stick with the thinner pad cause I didnt want more clearance issues with wheels (the extra space is to the outside) and pads are slightly lighter.
I did try the SL6R also, at the end of the day the caliper isnt stiff enough. The Aero6 and XT10 combo has finally given me the braking I was hunting for. A more baller setup could certainly be better but I can now panic brake into an element being too late and things still work out. The crazy thing in my car that all the co-drivers eventually figure out, if you need more braking just push harder. Even my wife found the old brakes (SL6R and ST43s) were crap and at the Montana event the new setup just worked. Worst thing for us was the heat build from low overlap cooked the wheels and I was spraying the crap out of the inner barrel to keep them cool but by 5th runs (90sec runs hitting just under 90mph in a couple spots) with only a few min overlap things were so saturated we both slowed each day by run 5.
My bracket does a standard 8/9 rotor with the spacer on the back side and flip the spacer to the inside for the X size. I was going to do a stud but I didn't want to limit wheels with too long of a stud. Like the STU guys running 17" wheels. But if you instead sources a stud, pulling the nut to pull the rotor or pads would be more ideal.
Old Dec 8, 2021 | 01:21 PM
  #142
kaj's Avatar
kaj
I'm interested in the Aero6s.
Going to a thicker brake pad moves the caliper??
Old Dec 8, 2021 | 01:24 PM
  #143
Dallas J's Avatar
Veteran: Army
The 17mm and 20mm versions have different centerline to mount hole offsets.
Old Dec 8, 2021 | 01:34 PM
  #144
Ayoustin's Avatar
This frustrated the hell out of me. Wilwood makes two different offset Aero6 calipers but they use the same engineering drawing for both of them
For those wondering, Dallas' brackets are meant for use with the calipers that have a pad volume of 5.2, not 6.6 (what I bought). Though they will work with the 6.6 volume calipers, you just need to put a spacer behind the rotor, I just had some stainless shims made to get everything centered, it's around a 2mm difference so nothing crazy.
Old Dec 8, 2021 | 02:05 PM
  #145
My car already has the X brakes (knuckles drilled to 14mm). Do you make a bracket for the X knuckle/brakes? Also, how many dollars (DM me if needed)?
Old Dec 8, 2021 | 02:52 PM
  #146
kaj's Avatar
kaj
Oooh. A different caliper. Gotcha. Makes more sense.
+1.
Old Dec 8, 2021 | 07:06 PM
  #147
Dallas J's Avatar
Veteran: Army
They're drilled/tapped for OEM 8/9 bolt but these work great for going back to 12mm from 14mm. I've used them for some customers that want option to run X calipers.
Amazon Amazon
Old Dec 9, 2021 | 08:49 AM
  #148
Balrok's Avatar
I'll go a dollar less then him :P
Old Dec 9, 2021 | 09:05 AM
  #149
The race to the bottom where no one wins
@Dallas J I'm probably going to try this on my car. And if it works well, try it on my friends EvoX. Do you have a bracket for the X as well?
Old Dec 9, 2021 | 09:46 AM
  #150
Dallas J's Avatar
Veteran: Army
I could look at making an X specific version, but really these would just work on an X as well with the bushing and running the spacer on the inside. I have about 1500lbs of aluminum to machine first though and another ~20hrs of steel parts to finish. And house goes up for sale in a month, and something about a full time job... Adulting is hard.
