kyoo
close
- Join DateMay 2006
- LocationUS
iTrader Positive Feedback100
iTrader Feedback Score(29)
Liked:283 Times in 244 Posts
fwiw i never use the ebrake on a track day, only for normal driving and when it's on the trailer. when i put it on the trailer i let it all cool down first also before using the ebrake.
kaj
close
- Join DateMar 2006
- LocationFresno, CA
iTrader Feedback Score(60)
Liked:824 Times in 685 Posts
My Girodisc rear hats are steel. Not *much* lighter than OEM
Quote:
An old design maybe? My Girodisc 2pc rears are aluminum hat.Originally Posted by kaj
Id have no worry about aluminum rear hats. Just dont use the E-brake after a track session. Steel is nice, but if going steel might as well just stick with centric blanks in the rear. They dont make enough heat that it matters as much as the front.
Ayoustin
close
- Join DateJul 2014
- LocationSC
iTrader Feedback Score(2)
Liked:648 Times in 468 Posts
Well I found PFC makes a V3 stock replacement rear disc using their sweet snap ring system so I'll design for stock rear rotor as I don't see their V3 having any issues on track and if for whatever reason enough people want a thicker rear rotor that's something we can explore in the future. Going to chat with them at PRI this week to see what it takes to become a dealer for them.
DBA 5000 series do a 2 piece rear rotor factory fitment. not sure if alu or steel.
My center hats for my front discs are 7075 alu and have been fine for years.
Well look at the AP discs too. Kinda makes more sense to one stop shop and not have to go "over here" just for rear rotor rings. Unless they don't make em.
Ayoustin
close
- Join DateJul 2014
- LocationSC
This is the beauty behind designing around the stock disc. You can choose whichever brand you want for rotors.
DBA is definitely nice stuff but last I checked (it's been a few years) they only make their 5000 2 pieces for the front.
I didn't look too hard but AP doesn't list a 22mm thick 300mm diameter ring on their site, which leads me to believe they don't offer a stock replacement disc, but if they do, there's nothing that would prevent you from using theirs.
I'm looking at the PFC because of their ease of service and the hardware is reusable so the only thing you have to buy is new rings. They do just as many cup car brakes as AP and Brembo so their stuff is plenty well race proven too.
Originally Posted by ayoustin
This is the beauty behind designing around the stock disc. You can choose whichever brand you want for rotors.DBA is definitely nice stuff but last I checked (it's been a few years) they only make their 5000 2 pieces for the front.
Yea just had a look and cant see it there. Possibly was being offered a rotor that was from another application which would also fit.
Girodisc do them https://www.girodisc.com/Rear-Rotors...-9_p_5528.html
kikiturbo
close
- Join DateMar 2008
- LocationCroatia
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:320 Times in 238 Posts
Quote:
I dont know about the legality, but GrN Brembos do not use the stock E brake. Just alu hat with a floating disc, and the e brake is hydraulic with rear lines going trough a twin hydraulic cylinder. They actually have a locking mechanism on the lever, so when they park the car they can lock the rear brakes with the rear disc calipers.Originally Posted by Dallas J
Ayoustin
close
- Join DateJul 2014
- LocationSC
Rear 8350 is on order. Bracket will be designed shortly after I get it. Likely just going to do a one time group buy for anybody interested.
Ayoustin
close
- Join DateJul 2014
- LocationSC
I know lots of stuff in the rear of the X are different. As long as the radial depth of the rotor isn't smaller than the 8/9 then yea it wouldn't be too hard to do rears for an X in similar fashion. I'd just need to get my hands on a car to take measurements.
Edit: Woah, turns out Centric now sells replacement MR front rotors. Maybe that's nothing new but I was under the impression no one was making OEM replacement 2 piece rotors. Price isn't terrible either at around $200/rotor.
LetsGetThisDone
close
- Join DateOct 2013
- LocationLas Vegas
iTrader Feedback Score(1)
Liked:1,629 Times in 1,392 Posts
Currently wondering how good the Racing Brake Caliper is because this is affordable, and even more affordable with out dealer pricing. Unless @Dallas J has a caliper bracket for me to move to a wilwood 6 piston (Aero 6 piston area is only a smidge less than stock, 4.04 vs 4.29)
https://racingbrake.com/2135-pu
Part number?Originally Posted by ayoustin
I know lots of stuff in the rear of the X are different. As long as the radial depth of the rotor isn't smaller than the 8/9 then yea it wouldn't be too hard to do rears for an X in similar fashion. I'd just need to get my hands on a car to take measurements.Edit: Woah, turns out Centric now sells replacement MR front rotors. Maybe that's nothing new but I was under the impression no one was making OEM replacement 2 piece rotors. Price isn't terrible either at around $200/rotor.
Ayoustin
close
- Join DateJul 2014
- LocationSC
Those Racing Brake calipers look very similar to the generic Taiwanese calipers I see tons of companies use in their "bespoke" brake kits. The fact that it doesn't have any bridge over the pads would make me think it isn't much stiffer than the factory caliper either.
I'd be much more inclined to go the Aero6 on a stock or X rotor route. I've had no issues with the Aero6 on my car other than the fact they could be a bit lighter (still lighter than stock) and I have to remove them to change pads.
Quote:
Part number?
120.46073 and 120.46081 for left and right respectively.Originally Posted by letsgetthisdone
Part number?
