Modern Tire Options
Old Jan 5, 2023 | 12:41 PM
  #121
LetsGetThisDone's Avatar
Originally Posted by kaj
I am 100% surprised to see the 660 rate higher than an a052.
Just goes to show you how important a properly set up car is.
As for the RS4, I've been promoting that tires, personally, for years. I had a set on the Evo, on stock wheels, and absolutely beat on the car at Laguna Seca for a whole day. They never complained once. I also don't think they wore it all lol
The A052 is very much a 1, MAYBE 2 hot lap tire and it's done. They may not have had the test set up appropriately to maximize that tire. Or they weren't driving the car appropriately. With the AO52, we'll do our warm up laps at 15-20 seconds off the pace to gently warm the tire up before we put in a flyer.
Old Jan 5, 2023 | 04:09 PM
  #122
kaj's Avatar
kaj
I guess I assumed everyone does that, but their test isn't for the best time attack tire, so ...
Old Jan 5, 2023 | 04:40 PM
  #123
Dallas J's Avatar
Veteran: Army
The A052 is epic, in its element. This wasnt its element. The new RE71rs is impressive and the RT660 is right at home there.
Old Jan 5, 2023 | 08:51 PM
  #124
I finally read the test, it sounds like the A052 had enough grip to cause enough body roll in a stock suspension car that the front end stopped working. The A052 was a second slower than the RE71rs in that test. Most other tests it's the other way around.
Old Jan 5, 2023 | 09:06 PM
  #125
Construct's Avatar
They did acknowledge that chassis tuning would have been necessary to make the A052 work properly.
Tire testing is hard.
@LetsGetThisDone in your experience, can the A052 recover after a cool down lap? Or is it a more prolonged falloff after temps get too high?
Old Jan 5, 2023 | 09:33 PM
  #126
They seem to be ok if you give them a good cool down lap, slower than a warm up lap, like as slow as you'd go as if it was an in lap after the checker. We'll usually get 2 hot laps in a 20 minute session.
Out lap, warm up, hot lap, cool down, hot lap, in lap. However, if you want top performance, they heat cycle worse than a Hoosier. Less than 10 hot laps. And really they're at their best with less than 5 fliers on them.
Old Jan 6, 2023 | 06:44 AM
  #127
RazorLab's Avatar
Ya’ll still sleeping on Nankang CR-S I see.
More for me then.
Old Jan 6, 2023 | 09:06 AM
  #128
More for me then.
We've tested the AR1. Its a certain improvement over NT01's. Haven't tried the CRS yet.
Old Jan 6, 2023 | 09:07 AM
  #129
RazorLab's Avatar
CR-S is faster than the AR-1
It's like the A052 but without the whole one lap wonder thing, and you can actually feel things.
Old Jan 6, 2023 | 09:14 AM
  #130
Good info. I'll have to try a set.
Old Jan 6, 2023 | 09:29 AM
  #131
Construct's Avatar
Tell me more.
I remember hearing some hype about the CR-S, but then not much after that. Good track day tire? How's the longevity?
Old Jan 6, 2023 | 09:30 AM
  #132
RazorLab's Avatar
Def my current favorite tire. They are fastest the second day, unless you get them heat cycled. I've been getting about 4-5 events out of them before they heat cycle out. I also stayed out almost whole sessions every session this past season as I got used to the car and they don't fall off a ton like the A052 and RT660, however I don't drive like an Ape.
They also make no sound like NT01/AR1/R888. No helicopters following you. My one criticism is that they don't communicate audibly a ton on the limit but they are recoverable, which is good.
Old Jan 6, 2023 | 12:41 PM
  #133
kaj's Avatar
kaj
I have a set ordered for the Supra. Which is the same size I run on the Evo. It's a damned shame the bolt patterns are different so I can't move the wheels and tires from one car to the other.
On the Evo, I am still using NTO1s. They are 2.5 years old with an unknown amount of heat cycles, and I'm still setting PBs. Sure, those PBs would be faster on a newer, fresher tire, but I would have stuck with them until my lap times peaked, then swapped.
Old Jan 6, 2023 | 12:51 PM
  #134
RazorLab's Avatar
What size?
Old Jan 6, 2023 | 12:57 PM
  #135
Balrok's Avatar
Granted there's still debate on bolt on spacers even if Titan used em - but couldn't you convert the bolt pattern that way too?
