Philadelphia's Classiest Drunkards
Old Mar 23, 2010 | 05:54 PM
  #2056
grillpt's Avatar
Originally Posted by Mr. MR
^ Are you running big tires in the front? Regardless at full lock my car rubs a little, no biggie. If you look inside my wheels now it funny o see how much fender liner I have worn out running my tire size with agressive alignment thats sitting low.
Just tell Steve to give you as much neg. camber in the front he can get. For the rear do the 1 degree negative camber with a little toe out. Trust me, it will work for Autox and feel good on the street. Only draw back on street is car will track a little when road surface is uneven and maybe a little more tire wear than normal.
Do not know whats up with the burning smell, that is wrong. Wheel shaking like crazy, happened to me when my lug nuts were loose and my wheel flew off on the turnpike at 70 MPH, good times man! Wheel shaking and burning smell definitely means something is wrong.
Yeah def didn't like the burning smell so much. The scent wasn't familiar to me either... maybe a little like plastic. As far as the settings, I told him, they just couldn't get the one side to cooperate.
Originally Posted by chu
How is it that you have all these problems? Wouldn't the tires get cut since your fenders aren't rolled? I dont remember seeing any cut marks on your tires last I saw. The sway bar you're added makes no difference.
Chu never had these problems...
Old Mar 23, 2010 | 06:03 PM
  #2057
chu's Avatar
chu
Honestly didn't. The only problem I had was the lock to lock rubbing, but it was very slight. I didn't care for it since you never really do too many lock to lock turns. I hop you get it all figured out man.
Old Mar 23, 2010 | 06:06 PM
  #2058
Mr. MR's Avatar
My last post was wrong, in the rear do a little toe in with 1 degree camber.
in the front as much camber as possible with toe out (I think 1 degree out) I am sure Steve will know. If you are stuck PM me and I will go get my papers to clarify.
Just a suggestion to any of you guys getting into Autox for real, get a notebook to record all settings you use for the different events you goto, alot of real good Autoxers do that religiously. Keep all your suspension settings in there too with whatever other info you need to remember, it can be really helpful. I should practice what I preach because I have everything written on business cards and loose papers. I am organizing all that prior to first event. This sounds like common sense, but I never thought to do it until I saw someone doing at Nationals.
I can't wait for this weekend, I may do Harrisburg (awesome lot) on Sat. and CBP on Sunday to set it off right this season. I haven't Autox in forever.............need my fix...
Old Mar 23, 2010 | 06:55 PM
  #2059
PeteyTurbo@KHC's Avatar
+1 I have a few whiteline booklets that are made specifically for this purpose, I think they even have feilds for you to fill out. I just need to remember to get them from work..
Old Mar 23, 2010 | 07:11 PM
  #2060
AlwaysinBoost's Avatar
Originally Posted by grillpt
Yes on the wheels. No rubbing in the rear... I would hate to have to go to RT to get this thing straightened out. I don't think they got the one bolt lose, they won't admit that but one is still facing inwards.
Those essentric bolts can be a PITA. I just had all my **** apart less then a year ago (around 6k miles) when I installed my coils. just this afternoon I had to flip that bolt 180* and it was already fu(king siezed. took about a half an hour with a BFH and torch to finally get it loose. the other side was a breeze... go figure.
Mike I'm glad you hear your setup rubs a little too. I tested mine out and it looks like the driverside will rub the fender liner a very little bit when i turn left. right side seems fine. I was stressing about it but to read that makes me not worry so much. I can still fix it with smaller spacers and a 6" spring, but its not like I can't drive the car or anything.
Old Mar 23, 2010 | 07:18 PM
  #2061
chu's Avatar
chu
Same with mine Marc. One side was a breeze, and the other side was a b!tch.
Old Mar 23, 2010 | 07:23 PM
  #2062
found this on ebay, killer deal if you dont mind not being 3 inch the whole way, supersprint is top quality this is cheap as you will ever see
http://cgi.ebay.com/ebaymotors/ws/eB...IF:MOTORS:1123
they have the other pipe as well in a seperate auction
Old Mar 23, 2010 | 07:26 PM
  #2063
chu's Avatar
chu
ooo, had a SuperSprint exhaust on my EF Civic back in the days. There was one on sale here a few months ago, and I wanted it really bad. Ansa makes awesome stuff also.
Old Mar 23, 2010 | 08:52 PM
  #2064
DsB's Avatar
DsB
A-BOMB IS THE ****IN MANNN, thanks for the link brotha.
Old Mar 23, 2010 | 10:26 PM
  #2065
Kevin.'s Avatar
No news on the misc front end noise, I was reassured that everything is tight. So I do plan on driving the car this Sunday. Just waiting for an axle to snap....
Me either. I noticed it does it under a load being on that wheel when turning.
Originally Posted by K1tt3n5
Mine just slides around.
Well aren't you something!
Or he can try on his own, new set of wheels
Originally Posted by robertg
Fake
Originally Posted by dek0026
just ordered some AEM matching boost and AFR gauges.
Originally Posted by boostedtres
haha evos with such spoils as side curtain airbags....just shananigans. two airbags FTW! I got mine on the steering column too (thanks carson) and it works great
You need all the airbags you can get. I suggest you get an X
Originally Posted by BrandNew
Drexel Hill? I wonder if I've ever seen your car since I'm one town over.
I'm always impressed by how fast some vendors work. Touge Factory is one example. I was on aim with Mike, sent my paypal, and I got an email with tracking number within 5 mins.
Thats how I'd run my business haha
chu, peer pressure me on facebook. i never leave status messages. that was a shout out to the evo crew on there.
lol
Old Mar 24, 2010 | 12:11 AM
  #2066
K1tt3n5's Avatar
yes
Old Mar 24, 2010 | 05:52 AM
  #2067
morning bishes. just checked the scca site and registration for SM is looking kinda light... any of you BSP guys making the switch?
Old Mar 24, 2010 | 05:56 AM
  #2068
chu's Avatar
chu
Pete is considering it I believe...Cy and Corey has some peeps rethinking the class, lol. I thought Mike said he was considering moving out of PRO and running regular BSP so he can run with those guys?
Not like I will give you a challenge in SM either Marc, but I'll be happy running within 2 sec of you!
Old Mar 24, 2010 | 06:57 AM
  #2069
grillpt's Avatar
I'm just hoping my car isn't going to give me any issues let alone worried about what class I'm gonna run in. I think i broke a couple of the tabs that hold the rocker panel on with my rubbing, I guess I'll see if the dealer has any but I'm sure I have to order them.
Do you think part of the problem is my car isn't lowered? That aside from the fact that I'm only running -1.3 up front...?
Old Mar 24, 2010 | 07:06 AM
  #2070
dek0026's Avatar
you could get lucky with the dealership. i did with an odd part. dambrosio told me who had it in stock and got it to me the next day.
