Philadelphia's Classiest Drunkards
Old Aug 8, 2011 | 01:51 PM
  #26146
chu's Avatar
chu
Don't they sell that stuff at Home Depot?
Old Aug 8, 2011 | 01:57 PM
  #26147
igo4bmx's Avatar
Home depot only sells 3/16" pegboard
this is 1/4" thick and hardboard which is more durable.
plus amazon = no tax and free two day shipping thanks to prime.
Old Aug 8, 2011 | 02:04 PM
  #26148
AlwaysinBoost's Avatar
Originally Posted by igo4bmx
I used quikrete epoxy floor paint. Prep is key like any paint job (I cleaned it a total of 5 times with several different products).
I've dropped tons of stuff on it and it has never peeled or flaked
that looks good sir. have you tried putting the car up on jack stands and does it leave any gouges in the paint?
I just had my garage semi-redone. Add a double door and installed new windows. I still need to insulate it, install siding and do something with the mess that I have on the inside. What we really need is a PCD garage make over day... sorta like the Amish do with building houses except we'll have beer, hookers and blow... we can do each others garages and get it banged out in a very short amount of time.
Old Aug 8, 2011 | 02:05 PM
  #26149
Tims2006MR's Avatar
besides perrin what type of rear sway bar end links are you guys running? I need to get new ones so I can adjust my sway.
Old Aug 8, 2011 | 02:08 PM
  #26150
Tims2006MR's Avatar
I can see james with a megaphone yelling. The amish are efficient as hell building stuff. theirs building a new mcDonalds near me and theirs a bunch of them there.
Old Aug 8, 2011 | 02:32 PM
  #26151
dek0026's Avatar
i'd like to redo my garage floor next spring/summer. i bought the house with it done already but it's wearing away in places like where tires run in and out.
it's great for oil and fuel spills.
Old Aug 8, 2011 | 02:47 PM
  #26152
chu's Avatar
chu
They must have used the cheap stuff. Some I know used something cheap and it wore away pretty quick. Also flaked off in some areas.
Old Aug 8, 2011 | 04:16 PM
  #26153
robertg's Avatar
I read that too quickly...
Old Aug 8, 2011 | 04:57 PM
  #26154
chu's Avatar
chu
Tim, I have the Perrin links. Have had them for well over 2 years. I have had no issues with them thus far. No clunks or anything. i check them for play now and then and haven't noticed any.
Old Aug 8, 2011 | 05:43 PM
  #26155
Tims2006MR's Avatar
I think ill go with them. Everyone has said the same thing that they are real good.
Old Aug 8, 2011 | 06:11 PM
  #26156
psushoe's Avatar
Before:
http://www.flickr.com/photos/61060145@N04/6015482471/
After (look in background):
http://www.flickr.com/photos/61060145@N04/6015483289/
Old Aug 8, 2011 | 06:18 PM
  #26157
dek0026's Avatar
Maybe but it is like 8-9 years old and is only worn where the cars tires touch. You've seen it.
Old Aug 8, 2011 | 06:24 PM
  #26158
robertg's Avatar
Plus there is a +1 in the second one.
Old Aug 8, 2011 | 06:28 PM
  #26159
igo4bmx's Avatar
Yeah i've put jack stands on it with no issues. I'm down for a chil day of drinking and building!
Basically most over the counter floor paints are water and epoxy based making them not very strong. the heat of the tires wears into the epoxy breaking it down and eventually coming off. it will happen to mine eventually but ironically i don't park my car in there (too much crap in there right now).
What you will need to do is get a floor sander to get rid of all the paint including sanding down the area where the tires sit. tires leave a residue on concrete which makes it hard to have paint stick on it.
good options for you dan is race flooring (since you're a baller you should do it) or get higher end aspartic flooring which leaves a very thick protective layer on your garage
Old Aug 8, 2011 | 06:47 PM
  #26160
dek0026's Avatar
Thanks for the consultation. I'm no baller.
It also gets tons of salt in the winter on it too so I think that would play a role in breaking it down.
