Philadelphia's Classiest Drunkards
Old Jun 20, 2012 | 01:27 PM
  #37906
ineedmorepsi's Avatar
Originally Posted by AreSTG
you're right. i was stunned. first couple posts, off the bat, were clicks, and pictures of people in action on track. badass.
huh. During the test fit i was not taking camber into account for getting things to fit. Mostly, what i saw was the rubber hit the trailing link. Assumed some amount of spacer required. With the huge tire, i also needed to make extra room for sidewall flex, giving me a pretty big (i assumed) spacer. Then, with a spacer it looked like my tire was gunna be out passed where the stock body is, so not just a roll, but a pull as well. That's when i said screw it, and ordered the trailing links.
Now on the subject of camber though... I use my Evo as a weekend fun car on the street, in addition to the autox and dragstrip. Keeping a streetable alignment is appealing to me. Can i run that sort of camber you mentioned on the street without destroying my tires? Keep in mind, I roadtrip between NC/PA at least a couple times a year, the car gets some miles on it.
I run -2.1 front -.8 rear I DD and that's what I'll be running this weekend.
Autox I would go -2.6 or more up front and maybe -1 in rear
Old Jun 20, 2012 | 01:29 PM
  #37907
robertg's Avatar
Dam it, gotta fast scroll past the ghey vamp .. still at work yo. Can't read PCD while ghey vamp sit on screen.
I would like to go wider fender on the rears rather than add mad camber to tuck in the EVO X wheels. But I'd like to get camber bolts for the front. CBRD stopped dev on the bolts and suspension for RA, no demand no care. So.. front camber bolts and go see R/T? What about rear fenders, wat chu say?
Old Jun 20, 2012 | 01:30 PM
  #37908
chu's Avatar
chu
I daily drive my Evo all year round, as does some others on here. I've ran -2.8 degrees for over 2 years, and tire wear is even across. In the rear, I was running between -1.5 to -1.8, which is also normal. I use the same tires for street as I do for track. What you're attempting is nothing new.
Robert, a little bit of rear camber doesnt' hurt. Would it be possible for you to use Evo X camber bolts for the front?
Old Jun 20, 2012 | 01:35 PM
  #37909
shuttlegoose's Avatar
Originally Posted by honda-guy
i looked up opti-coat. doesn't look like it's thick enough to prevent paint chips from stones ect.
Mmmmm. I need something to protect the paint. Back to the drawing board.
Old Jun 20, 2012 | 01:43 PM
  #37910
robertg's Avatar
Chu, I can use these:
http://www.jscspeed.com/catalog/Mits..._Ralliart.html
Old Jun 20, 2012 | 01:44 PM
  #37911
chu's Avatar
chu
Not a fan of those aftermarket camber bolts myself.
Old Jun 20, 2012 | 01:55 PM
  #37912
BBS's Avatar
BBS
Any recommendations for a nice tool to get the damn drivetrain fluids in? Last time I used a pneumatic handpump and that crap for messy quick
Old Jun 20, 2012 | 02:14 PM
  #37913
robertg's Avatar
Double Post...
Old Jun 20, 2012 | 03:11 PM
  #37914
Mr. MR's Avatar
Post
Its 95ish degrees in my garage right now and I have 2 beers in me and some trees. Going to commence operation brake domination. I have 1 beer left before I am out, sheesh. Plan on busting this out tonight, will report back later on my progress.
probably going to sweat out a gallon of water, why? Because this aint a f'in game foolz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
Old Jun 20, 2012 | 03:12 PM
  #37915
Mr. MR's Avatar
only seen it done with hand pump, just need to use some finesse mang, minor mess if you have rag in hand
Old Jun 20, 2012 | 03:14 PM
  #37916
Mr. MR's Avatar
That vampire thing you guys love to post is freaky.. How bout some chicks up in here, the vampire is played out son
Old Jun 20, 2012 | 03:17 PM
  #37917
dek0026's Avatar
I don't DD my Evo but there is a definite difference in how the tires wear and behave with close to -3* camber versus -2*. My tires exploded instantly.
Seriously though I don't drive enough to appreciate DD tire wear but once I started running -3* the tires started making a lot more noise when street driving. It may mean nothing or it may mean something.
If I were driving up from NC frequently, I'd run a max of -2* up front but that's just my useless opinion.
Where in NC are you?
Old Jun 20, 2012 | 03:23 PM
  #37918
grillpt's Avatar
I told you it was gonna be hot as hell in your garage..
You don't need all that brake nonsense btw... but whatever, have at it, kid.
Old Jun 20, 2012 | 03:34 PM
  #37919
PeteyTurbo@KHC's Avatar
wolf's has a product to temperalily protect against chips and washes off easily
Old Jun 20, 2012 | 05:02 PM
  #37920
AreSTG's Avatar
thanks for the help. really appreciate it!
