MAP Stage 2 LR 2.4L Build
Old Jul 27, 2012 | 06:00 PM
  #361
batty200's Avatar
I think 400whp on pump is easily do able. My car only holds 21psi to redline at ~400-420vdr. If I turned the boost to 21 from the get go I would make same peak power just the midrange punch would decline a lot. Tq would be flat and power increase through the rpm band. I like working that tq curve on e85!
Old Jul 27, 2012 | 07:19 PM
  #362
aggieEVO's Avatar
Really enjoyed your build thread. Nice work!
Old Jul 27, 2012 | 07:47 PM
  #363
Blue91lx's Avatar
I'm hoping so. I've spoken with a few people and they are really doubting my ability to make that on pump. I can not wait to work the car a bit on E85 at a later date!
Thanks, mang!
Old Jul 28, 2012 | 06:42 AM
  #364
Adam Brunson's Avatar
We already made 409whp on stock evo ix turbo with a 2.4L.
Old Jul 28, 2012 | 12:40 PM
  #365
Blue91lx's Avatar
Noice! I'm not trying to set a record, just would like to see 400whp.
Old Jul 28, 2012 | 03:17 PM
  #366
Evolution IVGSR's Avatar
What fuel? E85? Thats pretty good for the displacement of that motor on that turbo
Old Jul 28, 2012 | 03:48 PM
  #367
Blue91lx's Avatar
We is talkin' bout pump numbahs brotha
Old Jul 28, 2012 | 04:20 PM
  #368
Blue91lx's Avatar
Oh, and read about how my timing has been on this entire time?@!#&%^*
Originally Posted by Blue91lx
Since I ask enough timing questions I might as well answer one.
So, if you don't remember my really sweet threads (sarcasm) about timing a 4g64, I challenge you to educate yourself with the finest reading on EvoM (minus EvoLinda's Intro thread):
https://www.evolutionm.net/forums/ev...ctly-time.html
https://www.evolutionm.net/forums/ev...4g64-swap.html
However, I never really solved my issue, as all of my marks are worn off of my crank pulley and lower timing cover, so no one believed me.
So, 500 broken tools and one big broken heart later, I've come to my own damn consensus.
I placed my new, shiney AEM cam gears (with cool bolts) up agains my ugly ratty, unproven Fidanza gears and lined up the dowel pins. The AEM gears were two entire teeth ahead of the Fidanza gears, both zero'd out. However, I figured if my timing was actually off that much, my car wouldn't run or valves would be bending and making cool sounds and stuff.
So, I did what I didn't think to do before: I found where my #1 piston reached it's highest point (TDC, duh!?), and lined my inner cam gear marks up with my valve cover.
This was my result (I still have to fix the intake gear as I moved it earlier in the day when doing really cool stuff), but my +2 +2 configuration was spot on the entire time):
I bought these AEM gears for nothing besides to look cool. Oh well...BLING. Not really sure why I made this thread other than to prove that I'm not crazy, and to laugh at the fact that if I put the AEM gears on I'd have been even more confuddled.
Old Jul 28, 2012 | 08:23 PM
  #369
Pump gas....
Also, bob I don't understand what your trying to say in your post about timing.
Old Jul 28, 2012 | 08:27 PM
  #370
You must be using a 64 belt.
Old Jul 28, 2012 | 09:13 PM
  #371
Blue91lx's Avatar
If you didn't see the other threads about timing it won't make much sense. Everyone said my motor was off a million degrees and whatnot, so I found TDC on piston one and it was dead on. 'Twas just to show the million people who gave me **** that I was correct the whole damn time.
And yeah, I am using a 64 belt.
Old Jul 29, 2012 | 05:58 AM
  #372
That is why people think your off, because they probably aren't aware of the 64 belt.
Old Jul 29, 2012 | 07:12 AM
  #373
rhd-jon's Avatar
nice build good luck
Old Jul 29, 2012 | 11:28 AM
  #374
Blue91lx's Avatar
Adam, it'll only make sense if you were in the other thread. They were saying my timing was way off because of the Fidanza gears, with the understanding that I was using the 64 belt.
Thanks Jon!
Gettin' tuned at 6 boys!
Old Jul 29, 2012 | 12:36 PM
  #375
Very nice! I will be running a bigger turbo, but I will be shooting for around 450whp on 91oct and then 550whp on E85. Still very impressive on a Stock 9 turbo and pump
I will also be at 10.0:1 compression that I hope will help me get to my goal on pump with out having to run to much boost.
And this was the simplest post ever that makes it so easy and so much sense
Originally Posted by n2oiroc
the position of the teeth and belt arent whats important, what is important is that you line up the cams to tdc on the valve cover. dont worry about the mark on the toothed ring, line up the red one on the cam hub.
Thanks for that Thread
