razorlab's simple build(s)
Old Feb 16, 2016 | 07:03 AM
  #301
RazorLab's Avatar
Originally Posted by psfp
Why don't you try shorter front springs? 7" (perhaps 6") should clear your tires, IMO
Those are 6" in the photo and the Ohlins that are replacing them have 8".
Old Feb 16, 2016 | 07:58 AM
  #302
LetsGetThisDone's Avatar
Those tire are wiiiiddddeee. Wow. I wonder how the 255/40r17 NT01's I'm getting this week are going to fit compared the 255/40 Dunlop Z2's that are coming off of my track wheels.
Old Feb 16, 2016 | 08:03 AM
  #303
psfp's Avatar
Interesting. My ohlins perches sit at about the same height (if I'm not mistaken) using 8" springs, that's why I thought your springs were also 8". I think you should try the Ohlins first, then make your call.
Old Feb 17, 2016 | 01:05 PM
  #304
RazorLab's Avatar
Okay just ordered a set of custom 12mm, 67.1mm Hub / 72.6mm Wheel spacers...
Installing some ARP 76.2mm studs in the front when I get some time.
Old Feb 20, 2016 | 04:44 PM
  #305
RazorLab's Avatar
Got my new Flex Fuel harness. Thanks to Jason @ Flexconverter.com for sending it out so fast.
Now I can get the Ethanol sensor out of the engine bay, which will clean it up.
Old Feb 22, 2016 | 12:55 PM
  #306
jracer's Avatar
How did the install go ?
Old Feb 22, 2016 | 01:09 PM
  #307
RazorLab's Avatar
Going to get around to it in two weeks.
I'm going to Tahoe this week.
Old Feb 22, 2016 | 01:15 PM
  #308
e_kobz's Avatar
Ordering this next week so I can test this out at UMS for when we do flexfuel. Good stuff
***Wait a second does this only work on androids?***
Old Feb 23, 2016 | 12:20 PM
  #309
RazorLab's Avatar
The gauge read out only works on androids currently. The actual flex fuel with the cars ECU, it doesn't matter.
Old Feb 23, 2016 | 08:39 PM
  #310
Evo_AK's Avatar
Veteran: Air Force
Where do you plan on moving the sensor to?
Old Feb 24, 2016 | 07:47 AM
  #311
RazorLab's Avatar
From the engine bay to on top of the fuel tank.
Old Mar 2, 2016 | 05:07 PM
  #312
RazorLab's Avatar
Okay, update on wheel fitment!
Finally installed my Ohlins and did some fitment testing....
I start with the rear to make sure I made enough fender clearance, turns out I have more than enough and I didn't really have to roll the fenders as much as I did, but oh well.
Between installing the Ohlins, I took advantage of having no strut installed and tested fitment of the 18x10.5 +30 NT03+M and 275 NT01 tires by moving the suspension through it's stroke:
Plenty of fender clearance.
Clears the lower arm just fine:
The only thing it comes pretty close to is the inside fender liner but I doubt the car will ever compress this much with the struts on.
Now, onto the front...
I haven't got the front ride height exactly where I want it, probably lower it maybe 1/4 of an inch more to get closer to where I had it before so some of this clearance might change a tad.
I had another set of custom spacers made, 12mm, here is the wheel/tire to strut clearance with 12mm, huge:
Here is with a 5mm spacer:
and without a spacer!
I can fit a spanner wrench between the tire/wheel and the strut body. I'm amazed it fits (barely) with no spacer. although that might change once the tire gets hot so not sure if I want to push it.
I'm going to install some ARP studs in the front so I can run either set of spacers I want. I really don't have to for the 5mm spacer but with so much tire I wouldn't mind the stronger studs.
Old Mar 2, 2016 | 05:25 PM
  #313
psfp's Avatar
Awesome. Installing ARP studs in the front is pretty easy. Now you see what I was saying about the Ohlins front spring perches position?
Old Mar 2, 2016 | 05:37 PM
  #314
RazorLab's Avatar
Perch position is approx same as my Apexi's. The car is about 1/2 higher in the front than before. I'm going to lower it about 1/4 more.
Old Mar 2, 2016 | 05:45 PM
  #315
psfp's Avatar
Yes, but with 2" longer springs than the Apexi's. Hence my statement that shorter springs would help to clear the perches. I didn't imagine that the tires would be that close to the strut body, though.
