razorlab's simple build(s)
Old Apr 19, 2016 | 02:59 PM
  #376
e_kobz's Avatar
I'm about to install a EF2 with a ported and coated MHI housing on my X. Should be fun and make some jam on E85
  #377
whtrice's Avatar
Veteran: Air Force
Originally Posted by razorlab
Blouch makes the Dominator 1.0 which would be the same as the BBX Lite I had on the RA. That turbo is too small for what I am looking for.
Do they make a 2.0 then???
Old Apr 19, 2016 | 03:02 PM
  #378
LetsGetThisDone's Avatar
http://www.maperformance.com/collect...ant=9609666755
It flows less than MHI-18k though..
Old Apr 19, 2016 | 03:12 PM
  #379
RazorLab's Avatar
The BBX and Dom 2.0 (basically same thing) always advertised lower flow than actual.
From my experience, the MHI-18K and the above basically tune out the same.
All less than my power goals. I want more than 450 and less than 550 and not have to run the turbo on full kill to do it. For the track at least.
Old Apr 19, 2016 | 03:13 PM
  #380
whtrice's Avatar
Veteran: Air Force
Well looky there...there is!!! .... Not sure if that is a problem if it is similar to the BBK full design that was so much fun. Had great transient response which rules for track use........ also
Features
Horsepower Rating: 520HP
Bolt-On
I would say 500HP would be just fine
Old Apr 19, 2016 | 03:16 PM
  #381
RazorLab's Avatar
Features
Bolt-On
Highest Dom 2.0/BBX I've tuned on the GST dyno was 450, and that was on full kill 28-30psi.
I want to make 450-500 at 24-25psi, without stressing the turbo and blowing a bunch of heat.
Old Apr 19, 2016 | 03:17 PM
  #382
whtrice's Avatar
Veteran: Air Force
I think your higher CR would help in that area not having to over work the boost function...Oh you are considering 2.2L also?
Old Apr 20, 2016 | 05:30 AM
  #383
Fast_Freddie's Avatar
Veteran: Navy
You could always send the turbo to an FP and have them machine the MHI housing to keep it more stock appearing... I know they aren't listed on the site anymore, but I am sure Robert would be more than willing to build you something...
Old Apr 20, 2016 | 08:18 AM
  #384
whtrice's Avatar
Veteran: Air Force
Interesting......
Old Apr 20, 2016 | 08:46 AM
  #385
e_kobz's Avatar
That's what I did with the EF2. Never trusted the housings that MAP supplied with their turbos. Hard to beat the trusty MHI housing
Old Apr 20, 2016 | 09:05 AM
  #386
Unfortunately, it's hard to make big power on stock from Evo X stuff.
When I was talking to Aaron about a future upgrade for my friends X, he said they only were able to get ~540whp out of an FP red on a X, at a whopping 38psi.
The tiny exhaust ports on the X head that are good for emmissions aren't so great for power. Add in a restrictive turbine housing and the package doesn't do so great. Especially since the intake ports flow so well. The X really needs to breath better on the exhaust side to make power (T3 setup). It doesn't work quite the same as the 8/9 stock frames.
Old Apr 20, 2016 | 09:43 AM
  #387
RazorLab's Avatar
Not sure I would trust a Turbolab turbo on a track car...
Old Apr 20, 2016 | 09:47 AM
  #388
RazorLab's Avatar
Yea it's interesting, I never made good power with any FP turbo on the X when tuning, at least compared to the 4G63. However the Blouch/CBRD turbos made great power for what they where, which I always found interesting.
The 4B11 REALLY wakes up once you go beyond stock frame and you can rev them. I had stock cam 4B11's with PT6262's make 450whp on 91 octane @25psi, which took a Blouch/CBRD stock frame E85, cams and 28-30psi to make.
Then, if you build them and really let them rev with a high flowing turbo, they can make really awesome power:
Old Apr 20, 2016 | 11:54 AM
  #389
Cheap cams:
https://www.evolutionm.net/forums/sa...l#post11603630
Not sure if I would go with used though. The X using flat tappet cams, improper break in can easily lead to a flat lobe, and a waste of money..
Old Apr 20, 2016 | 12:03 PM
  #390
machoymaru's Avatar
Wow very impressive, and the way you did everything very organize. Thank you very much for sharing. When I see this on Evo's with very minimal MODS, and the # they put down; makes me appreciate even more my EVO. =-)
