razorlab's simple build(s)
Old Aug 16, 2017 | 02:31 PM
  #766
mrfred's Avatar
Originally Posted by heel2toe
I've had a Boomba Racing check valve on my car for about 2 years now and its held up. I think Im doing a BLT on my car tonight or tomorrow night so I can check the valve and make sure its still functioning as it should. I have no idea what the ball is made out of but it might be a good option for you...
I have Boomba as well for several years. No issues. Definitely a metal ball.
Old Aug 16, 2017 | 04:25 PM
  #767
RazorLab's Avatar
Cool, thanks for the check valve input. super helpful!
Old Aug 16, 2017 | 06:06 PM
  #768
Jaraxle's Avatar
So the flow rate through the checkvalve when under vacuum is not a concern? I thought it had to be a controlled flow to prevent idle issues?
Old Aug 16, 2017 | 10:26 PM
  #769
LetsGetThisDone's Avatar
The X has a large check valve stock.
Old Aug 16, 2017 | 10:50 PM
  #770
RazorLab's Avatar
So this is what I am thinking with my breather system, thoughts?
Old Aug 16, 2017 | 11:42 PM
  #771
mrfred's Avatar
That will work although without an OEM PCV valve in the line to the manifold, you might have high idle issues.
Old Aug 17, 2017 | 09:26 AM
  #772
That will work perfect Bryan.
He won't. The X has a MUCH larger PCV valve than the 8/9.
Old Aug 17, 2017 | 10:08 AM
  #773
RazorLab's Avatar
Have no plans on using the OEM PCV. It's highly restrictive, the opening is ridiculously small.
Old Aug 17, 2017 | 10:20 AM
  #774
It's way bigger than the 8/9...lol
But with the check valve in the line to intake pipe, you're idle will be fine.
Old Aug 17, 2017 | 10:21 AM
  #775
RazorLab's Avatar
OEM Evo X PCV:
Old Aug 17, 2017 | 10:24 AM
  #776
RazorLab's Avatar
So I'm currently looking at a Mighty Mouse catch can which already has check valves incorporated in the top and side so seems to be the ticket!
Although not sure if I want to run a couple feet of pressurized hose from the intake manifold all the way to the can. I think I would rather have the check valve as close to the intake manifold as possible.
Been speaking with the owner and he has been very helpful.
Old Aug 20, 2017 | 02:27 PM
  #777
RazorLab's Avatar
So I received the new check valve so I could see what the internal valve looked like before my other one got destroyed.
All I have to say is FFFFFFFffffffffuuuu this check valve. 100psi capable? Give me a break. no ball.
This.Rubber.Flap is the check valve. I can easily bend it with my fingers, and now it's in in my motor somewhere...
Nope. Nope. Nope.
Old Aug 20, 2017 | 06:55 PM
  #778
mrfred's Avatar
If its a small enough hole, then even a piece of rubber can handle 100 psi.
Old Aug 20, 2017 | 09:36 PM
  #779
RazorLab's Avatar
Theory is awesome, however in reality it didn't even hold 26psi on my car.
Old Aug 20, 2017 | 10:55 PM
  #780
mrfred's Avatar
I hope that you find the piece of rubber.
