GT3071 dyno results
Old Apr 8, 2005 | 08:51 AM
  #91
EVOlutionary's Avatar
Thanks smogrunner, I was not aware of the big difference between the two dyno's readings. I know Mustang dyno's read alot lower than Dynojet, but I had not heard too much about Vishnu's (DynoDynamics I think?)
So a car that puts down 350 hp on Vishnu's dyno would read alot higher on Buschur's?
Thanks,
EVOlutionary
Old Apr 8, 2005 | 11:04 AM
  #92
Ted B's Avatar
A Dyno Dynamics reads lower than anything else, followed by a Mustang, followed by typical 4wd Dynojets, and 2wd Dynojets give the highest numbers.
A car delivering a measured 350whp on Vishnu's or Dyno4mance's dyno will record over 400whp on a 4wd Dynojet.
Old Apr 8, 2005 | 11:15 AM
  #93
evowilling's Avatar
Originally Posted by shiv@vishnu
Just tested a 3071 turbo with our turbo adapter (allows it to bolt on to stock exhaust manifold).
Other mods:
Stock head, stock block with 280 cams at 0,0 deg
BJ Sheetmetal intake manifold
680cc injectors withe fuel pump
Stock airbox with stock BOV
XEDE/XEDEFlash
Sig exhaust WITH cat
91oct at 23psi
Results: 360whp
Surprised the heck out of us. The most we ever expect to make on 91oct is 300-320whp. Maybe there is something to those 280 cams afterall
cheers,
Shiv
This is just incredible. Shiv you have done it again. Was there any other mods on the car at all(fmic, etc)? So the 3071 turbo with the adapter is all you'll need (no downpipe/o2 housing mod, etc)? Will 660CC injectors be more than sufficient to support such a set up or will 680CC injectors be recommended? Do you think the intake manifold contributed significantly to these result? Any ballpark figure of what this turbo with the Vishnu turbo adapter will cost?
Old Apr 8, 2005 | 11:53 AM
  #94
Ludikraut's Avatar
And to add even more $.02 to this, a DD dyno does not seem to put as much of a load on the car at lower rpms when compared to an AWD Dynojet. If you look at the torque/hp curves your average Evo generates then you will usually see a nice torque "hump" at ~3200-4000rpms on an AWD Dynojet, whereas the torque curve will be much flatter on a DD.
l8r)
Old Apr 8, 2005 | 01:23 PM
  #95
Drews_WRX's Avatar
how does flatter mean more load? just wondering....
Old Apr 8, 2005 | 04:02 PM
  #96
Ludikraut's Avatar
flatter torque curve = less load ... I thought that's what I said
l8r)
Old Apr 8, 2005 | 05:09 PM
  #97
Drews_WRX's Avatar
*edit
Old Apr 8, 2005 | 06:06 PM
  #98
wilson1's Avatar
Other mods:
XEDE/XEDEFlash
91oct at 23psi
Results: 360whp
cheers,
Shiv
Awesome, shiv!
Old Apr 8, 2005 | 06:22 PM
  #99
Mercenary3's Avatar
So, bottom line, anyone know how much more power this turbo going to make over the stock turbo on pump and race gas given a similar setup to this car?
Old Apr 8, 2005 | 07:07 PM
  #100
MattGold's Avatar
Maybe I missed it - but what is the A/R on this turbo? .62? .83?
Thanks,
Old Apr 8, 2005 | 08:47 PM
  #101
wthoevo8's Avatar
.62
Thanks,
Old Apr 10, 2005 | 07:55 AM
  #102
bdking57's Avatar
This thing looks so sweet.. it looks like the standard AMS lower IC pipe upgrade, which i already have... and if its able to bolt up to a standard 02 housing and downpipe then this kit has achieved an incredible performance value (highest to date) while still maintaing much of the original engineering of the car!
Old Apr 10, 2005 | 04:49 PM
  #103
jfh's Avatar
jfh
Originally Posted by bdking57
This thing looks so sweet.. it looks like the standard AMS lower IC pipe upgrade....,
My AMS lower IC pipe doesn't look anything like the one piece pipe in Shiv's pic.
Old Apr 12, 2005 | 08:42 AM
  #104
Nez136's Avatar
hey guys, i have been reading the whole post, is there any updates as far as Vishnu's kit and sales?? i have money to spend on a kit and im torn between AMS & Vishnu!
Old Apr 12, 2005 | 12:16 PM
  #105
Ludikraut's Avatar
It all depends on what you're going for. From what I can tell the AMS kit is more of a no-compromise kit and would probably be the choice if you're looking to race and use race gas maps extensively. The Vishnu kit looks like it will be a very nice choice if you are looking for a pump gas monstAr. Either way, Martin at AMS should be able to tune the setup - IIRC he should have no problems with tuning an XEDE, although he'll probably try to sell you on the AEM
l8r)
