Isn't That Lean?
Old Aug 13, 2006 | 04:26 PM
  #301
jrsimon27's Avatar
i wouldnt touch the timing tables at all! if you want to add more fuel to the base maps well thats fine but dont touch the timing tables unless you have a device to monitor knock!
i asked in another thread if i could zero out the timing tables for the 100oct maps but i would be using vp109 which has a higher octane just to be safe.
Old Aug 13, 2006 | 04:55 PM
  #302
nj1266's Avatar
I have the knock buffer and it does not log any large spikes. I will get the Tactrix cable soon and I will be able to log the knock sum. That will give me a good idea about the timing. What I have noticed from the base maps is that timing is pretty safe. The timing on Shiv's 93 octane base map is slightly more retarded than the timing on my custom 91 octane map.
There is a sticky thread in this forum that shows you how to create a race map. It is pretty simple and is in line with what my custom 100 octane map has. You basically map the AFR a bit leaner, zero out the timing and set the boost to around 24 psi which is the maximum w/o the xede flash.
Old Aug 13, 2006 | 06:40 PM
  #303
jrsimon27's Avatar
thanks nj yeah in the sticky forums it says that if you use race gas you ca zero out the timing table. what afr do you recommend to use for 109 racegas?
Old Aug 13, 2006 | 08:00 PM
  #304
nj1266's Avatar
If it is for drag racing, then 12:1 on 109 is a nice safe AFR as long as your not knocking.
Old Aug 13, 2006 | 08:12 PM
  #305
RazorLab's Avatar
Do you know this from experience or something you read?
Old Aug 13, 2006 | 08:45 PM
  #306
nj1266's Avatar
Since I do not drag race, so it is something that I read about. This is race gas. jrs is currently running Shiv's maps at 11.7:1 on 93 or 91 octane. Do you think that 12:1 is lean for 109 octane? Crap, shiv has his maps @ 12.5:1 on 91 octane.
Old Aug 13, 2006 | 10:24 PM
  #307
RazorLab's Avatar
I'm just saying be careful about taking other peoples writings as gospel.
Old Aug 14, 2006 | 07:42 AM
  #308
nj1266's Avatar
I appreciate what you are saying, but I have been in touch with jrs through pm and know the AFR and the set-up he is running. Out of curiousity what AFR would your run with 109 octane gas?
Old Aug 14, 2006 | 09:51 AM
  #309
RazorLab's Avatar
On my car, not sure, it hasn't seen higher then 100 octane. To be honest, I've yet to tune on a car on leaded gas.
Old Aug 14, 2006 | 11:37 AM
  #310
nj1266's Avatar
What about the AFR you run on 100 octane @ the road coruse?
Old Aug 14, 2006 | 11:56 AM
  #311
RazorLab's Avatar
11.5 to 11.2 @ 25psi peak (3rd gear)
It's a very safe tune however. Conservative timing for 100 octane. I could push it much more but since I don't car bowl, I don't.
  #312
Spec'd's Avatar
Any logs for us razorlab ?
Maybe just a mini one.
Old Aug 14, 2006 | 12:01 PM
  #313
RazorLab's Avatar
I have a bunch of logs at home I did on the dyno. I can post tonight if I remember. I have since tweaked it a bit from then. It richened up on track after the car started running 100% 100octane so I had to lean it out a bit more.
Here is the dyno AFR, I since tuned out the small dip in the middle and a also made it a tad richer up top (11.2):
Old Aug 14, 2006 | 12:30 PM
  #314
Spec'd's Avatar
Thanks for posting that.
I like nice conservative tunes even on 100.
I'm usually concerned about EGTs , even when knock
isn't a problem. I thought higher octane gas was
supposed to run cooler.
If that is true it sure doesn't seem to make a difference
in my EGT logs when comparing 93 to 100 octane.
Question:
Do you prefer dyno tuning over road tuning ?
Old Aug 14, 2006 | 12:33 PM
  #315
RazorLab's Avatar
From my experience, dyno tuning on a good dyno easier, faster and safer to get a good tune, I always do both though. On the dyno to get it as close as possible, then tweak it on the street/track.
