Utah Evos
Old Feb 23, 2005 | 11:51 AM
  #2446
vtsnake's Avatar
well if i were you guys that got a dyno from them i would ask for some free pulls with the correct weight. theres a place on 3900 so that has a full scale. they weighed my car for about 10 bux. otherwise when you go back to see what your mods did they'll always have to dial in your weight at 3100 and you'll always get an inaccurate reading.
so did someone sit in the car during the dyno?
Old Feb 23, 2005 | 11:53 AM
  #2447
UT_Evo's Avatar
Yeah, someone has to push the gas
Old Feb 23, 2005 | 12:07 PM
  #2448
vtsnake's Avatar
okay if thats the case then don't they have to calculate the person sitting in it? or do they input that on another screen? i would think the dyno graph i just posted is showing 3500 lbs with the persons weight sitting in it calculated into the final number. if that indeed is the case then modern thinks the evos weigh under 3k?
Old Feb 23, 2005 | 12:12 PM
  #2449
UT_Evo's Avatar
Yes Ray, yes, I would assume that is the case. It still doesnt matter, as long as they set it the same, you can see if you gained or lost power.
Old Feb 23, 2005 | 12:27 PM
  #2450
dohc4g63's Avatar
Originally Posted by UT_Evo
Ray... Look at the weight setting... and then look at what Modern sets theirs at... THAT is why Al hates the mustangs... we've all been dynoed at 3100 lbs here... crank that up to 3500... Al hates Mustangs, cuz you can only compare people done on the EXACT same mustang in the EXACT same way, not Mustang to Mustang, it's good for seeing what you've gained if you do a baseline, but crap for comparing to others
My dyno sheet says 3050..WTF? I don't really care though. I would like to see the difference if I were to dyno with it at 3300
Old Feb 23, 2005 | 12:31 PM
  #2451
UT_Evo's Avatar
You're an MR, so they assumed you weighed less...
Old Feb 23, 2005 | 12:36 PM
  #2452
MSM_S2K's Avatar
Here's the upgrade you need and it fits in your price range.
http://www.axdo.net/
Old Feb 23, 2005 | 12:51 PM
  #2453
vtsnake's Avatar
i know what youre sayn but it's still not accurate. you obviously will be doing more dynos but since your "base" dial-in is wrong you forever will have to use that number to compare to. to me that just isn't right cause you'll never know what your car is "actually" putting out. i guess if you don't care its no biggie.
Old Feb 23, 2005 | 12:55 PM
  #2454
dohc4g63's Avatar
I guess so..but in reality the MR weighs more than the rest of the EVOs (05' anyway) . Next time I go I will see if I can dyno first pull @ 3050 then change it to 3285 + drivers weight. and see what that does.
Old Feb 23, 2005 | 12:58 PM
  #2455
UT_Evo's Avatar
I don't care, cuz they're ALL off, the only dyno that ever truly is accurate, is drag strip times, and then driver skill comes in to play and ruins everything there... It's improbable that ANY dyno out there is anywhere near perfect, someone's gotta push the gas, afterall, and Humans are full of more errors than my Evo, but yes, you're right, I actually wish it would've just been done on a Dynojet, that's what most people use... too late to care now, my baseline is just sitting there
Old Feb 23, 2005 | 01:39 PM
  #2456
bullfrg's Avatar
Mine too, but like Jake said it really is to tell the difference after mods , which it does.
Old Feb 23, 2005 | 02:32 PM
  #2457
liberty2000rs's Avatar
Engine dynos are very accurate.
Old Feb 23, 2005 | 02:58 PM
  #2458
silverofs's Avatar
that is pure bull**** that there weighing the cars like that!! my fwd eclipse was stripped out & they dynoed it @ 3200 and i know my evo weighs a ton more than that i would want a retest with the correct weight. i bet the mr dynoes more around 250 with the correct weight. scott what does yours say?????? if i ever do mine i will make sure close to the correct weight is on there.
i would call up to ***** just to get some more pulls in.
but like ray said that's modern for ya.
Old Feb 23, 2005 | 03:01 PM
  #2459
scott88vr6's Avatar
mine says 3100lbs
https://www.evolutionm.net/forums/sh...d.php?t=115082
Old Feb 23, 2005 | 03:03 PM
  #2460
UT_Evo's Avatar
Ok, I've got an appointment at Mitsu tomorrow, for them to do a prelim test of everything... In case they can fix it before Saturday so I don't waste your time, Jared
