Utah Evos
Old Jan 16, 2008 | 10:15 AM
  #12241
evo_domination's Avatar
Originally Posted by eficker
If it is leaking boost, then the maf is seeing extra air, and delivering fuel for it, but the air never makes it to the cylinder, thus making it too rich, choking, etc.
You may have to push through it to see if either it blows off a hose, or that the bov is actually leaking. replacing that greddy unit with stock is a good measure just as a matter of course.
Hey thanks alot for your help I really appreciate it. I put the stock bov on and it made no improvement. Then I disconnected my MBC (Forge UNOS) and hooked up the stock solenoid unit and that was where I got the most improvement, except I'm only getting about 13-14 lbs boost. 15 and above is where I was having the problem. I have a Hallman MBC I will hook up to see if that brings the issue back with a little higher boost, or if for some reason it was the Forge causing the problem???
I have seen a few posts of people having a spiking problem with the Forge UNOS but I've found nothing like this. Thanks again for the help.
Old Jan 16, 2008 | 03:58 PM
  #12242
gear head's Avatar
You're name isn't Evan is it?
Old Jan 16, 2008 | 11:45 PM
  #12243
E46CSLM3's Avatar
You would, along with 7 other cars, but dont worry you'd sell them all in like a week!!
you know it brother
Old Jan 17, 2008 | 06:35 AM
  #12244
munoa13's Avatar
Originally Posted by E46CSLM3
would u buy it ??
Ya I probably would! Ken Block's One Lap car looks pretty cool with it.
Old Jan 17, 2008 | 07:16 AM
  #12245
UT_Evo's Avatar
That's like some shirt you could buy at Hollister or Pac Sun or something... Only, its a car!
Old Jan 17, 2008 | 08:28 AM
  #12246
eficker's Avatar
It may not be the boost controller, but a leak that makes itself known at higher boost levels. That's what i would suspect the most. Do you have all stock soft hoses? stock clamps?
Tracking a boost leak can be a pita, but you can start by taking apart every connection, cleaning the mating surfaces with brake parts cleaner (outside of the hardpipes and inside of the soft hoses), then put them all back on. The stock hoses are okay, but expand and are made of rubber, so one could be bad. You may want to consider the samco hose kit (i think rallysport carries them), and some t-bolt clamps from napa (there is a part list of the proper clamps in the engine section i believe).
you know it brother
LOL
Old Jan 18, 2008 | 07:33 AM
  #12247
gear head's Avatar
Does anybody out there have a set of scales that I might be able to rent?
Old Jan 18, 2008 | 11:08 AM
  #12248
I found this link on another thread to do a pressure test on the system.
http://vfaq.com/mods/ICtester.html
I'll let you know how it works and what I find. I also changed my plugs to a cooler plug and checked my cables and coils, it smoothed it out a little but that's still at 14 lbs boost, but like you said, it might be a boost leak that only shows itself at high boost.
Old Jan 19, 2008 | 02:11 AM
  #12249
The Stranger's Avatar
Originally Posted by Evolution IVGSR
Here is a few fast pics off my phone. Will try to get some better ones up soon.
You can see part of the Evo IV next to it if you look really hard.
Here you can really see what the finish looks like. I think it turned out pritty good
Some pics of that nice RICER WING
The flat black is cool.
But honestly, is the wing a joke?
Old Jan 19, 2008 | 07:31 AM
  #12250
gear head's Avatar
I would also tap a pressure guage next to the valve stem.
Old Jan 21, 2008 | 08:35 AM
  #12251
Evolution IVGSR's Avatar
I like the wing I want one for my car now I think all the car really needs is some 18x9 wheels one this street setup or some 15x5 and a Rally suspension setup like the subaru WRC car
Old Jan 21, 2008 | 09:03 AM
  #12252
wesside's Avatar
haha yea everything but the wing
Old Jan 21, 2008 | 03:12 PM
  #12253
evobullet's Avatar
hey i just got my evo a few weeks ago and i was looking at the boost gauge in it and at idle it reads negative boost,
is that how it should be or is it suppose to be at zero? it is a defi d-gauge. any one know anything
Old Jan 21, 2008 | 04:10 PM
  #12254
slcrsx's Avatar
if its a vacuum and boost gauge it will read vacuum till your in boost so yes its working correct
Old Jan 22, 2008 | 10:19 AM
  #12255
I think I figured out it was the spark plugs, way too hot , and a moron (me) had the gap all screwed up. We did a boost check and it held pressure just fine. I put my Iridium plugs back in, along with my bov and mbc, and turned the boost up to 19 and it did a pretty smooth 3rd gear pull from 2000 to 5800, at which we encountered some knock. GEAR HEAD did some datalogging for me and it looks like a proper tune will probably fix that problem. Thanks for the help GEAR HEAD and EFICK.
