The Ultimate 2009 Ralliart Thread mega merge
The Ralliart's just 25 kilos lighter than the Evo GSR, and 60 kilos less than the Evo MR. Modifying the Ralliart to push up engine power could also easily push it over the stock weight of an Evo.
The argument was that the AYC is compensating for "extra weight", which didn't make sense, and really seems wrong when the weight differences are less than the weight of an average driver. The Evo has marginally more weight in the rear (f/r=57/43) than the Ralliart (f/r=60/40), but otherwise there's no real difference. Anyway, wouldn't the more balanced weight distribution in the Evo actually improve raw control?
Push up the weight by adding intake/exhaust/ecu mods? Hunh? Probably lighten it. Also, you misstate what I said and then say it doesn't make sense. I said that the AYC is allowing the X to compensate for the 300 lb weight penalty it suffers compared to the IX, not compared to the RA. Perhaps you care to argue that a 300 lb (136 kilo) difference isn't significant? Lastly, it's a 60 kilo (132 lb.) difference b/t the MR and the RA, not 25 kilos.
Not sure how an exhaust mod won't raise the weight -- it's a single exhaust pipe back in the stock RA, and aside from the garnishes on the tailpipes and the split after the muffler, the exhaust system looks pretty routine. Presumably the easiest mods would be to split the exhaust farther up or to use a larger pipe, and those would both add weight. Maybe the garnishes are heavier than they look?
Right, it compensates for weight by limiting yaw and the corresponding weight transfer, which makes it handle as though it were lighter. Also, yeah, sorry, you did say 60 kilos. I read to fast but I don't know why we're talking about the GSR anyway.
Shocked to see nobody's really talking about the fact the the packages for the RA have leaked.
Cheat sheet for those that haven't seen it...
FAST is standard. This is nice. Standard Bluetooth as well.
RECARO™ Sport Package:
RECARO™ sport bucket front seats
650-Watt (max) Rockford-Fosgate Punch® premium sound
system with 9 speaker including 10-inch dual-voice coil subwoofer, custom 20-liter sub-enclosure, digital signal processor, speed compensated volume and equalization.
SIRIUS Satellite Radio with 6 months pre-paid subscription
6 CD/MP3 in-dash changer
Xenon HID Headlamps. (BUT NOT AUTO-OFF APPARENTLY? SEE BELOW, BUT NOTE THAT ON THE PDF, THE NON-HID LIGHTS ARE AUTO STANDARD)
Navigation Premium Package:
30GB HDD Navigation system with music server
Singlle CD/MP3/DVD capable, AM/FM head unit
Auxiliary video input jack
Power glass sunroof with sunshade
Auto rain-sensing wipers
Auto on/off headlamp control
I said it was 60 kilos (RA to MR), and I still don't see how the AYC could be compensating for weight as opposed to weight distribution.
If you would have been looking around the weight reduction thread in the Evo 8 and 9 section you will notice that most aftermarket parts are lighter than stock.
Edit: You can also change to a single tip exhaust system to reduce weight even further like what the Evo X people are doing.
here guys i found this. look at the very last sentence. oh and i called MMNA and they told me that the RA should be coming out this summer
http://www.motortrend.com/auto_shows..._ralliart.html
Um I know that the car hasnt come out yet but and that its not gonna come out for a couple more months its just a question that i was askin. The Current RA is a completely different car then the new RA but i have a feeling that the new RA will be alot easier to reflash then the current RA
Stupid to speculate about these things because the car is not still sold anywhere. But yes, when they find out how to crack EvoX ecu, the RA should open up too. The problem is that in RA you have to tune the SST ecu also or the engine goes probably in a limpmode and shuts down. This is speculated in EvoX section about the MR version.
Ok... Time waste would have been better.
I recon than someone said the limit for EvoX SST torque would be 380lb ft.... 515Nm. If so I think that should be pretty enough for 90%. Even for if they put it with a diesel engine.
best-guess colours
The Eclipse shows us what Rotor Glow Orange means to Mitsubishi, but there doesn't seem to be a standard for Octane Blue Metallic (pray they don't use what Ford once called that shade of blue -- extremely dull). However, Alfa Romeo has used that name in the past and currently their Brera comes in colours suspiciously similar to Mitsubishi's 'orange' and what used to be called octane blue metallic. Here's the match to the Eclipse and the Brera:
That's plenty. So, there's no need to hack the ECU if you don't want to exceed that torque limit? If so, that's a 21% margin. If the RA does comes in at 253 ft/lbs that would give a torque limit of 320 ft/lbs. Also plenty. I'm not planning coming anywhere near that and neither would Cobb in Stage I/II.
You are right, however... Like I have said somewhere in this thread, If you plan on racing a road course or auto-x often you will be better off with an evo anyway. So your point really isn't a point anyway. I DD my evo and hit a 1/4 mile track once in a blue moon. That is why I will be trading my IX MR for a ralliart. I will never use/need the extra handling of the AYC let alone being able to slip a clutch through turns. The only time I take turns that quick is to have fun and kick it out anyways.
I still have two very big concerns about the Ralliart though. It will need the same internals as the evo. With the information we are aware about now the bottom end is identical to the evo. So far so good. Then there is the tc-sst strength. Since it is in the MR though I can only imagine that it will be strong enough to meet the standards of the IX MR trans. Those are the only two things that could stop me from being the first in line to buy a new Ralliart.
I don't get why they don't let you do these features 1 at a time. Like.. I want a sunroof... but I don't want ANYTHING ELSE from the navigation Premium Package. Soon as I get the car I'll replace with my own receiver. How well will auto-rain sensing wipers really work anyways.
Are there custom receivers/kits that will fit well in a 2009 Lancer? I know it was an incredible pain to customize the receiver in my Mazda Protege ES, at least so that it still looked good. I don't want the dash looking like it's held together with duct tape, but I also think the Nav-receiver looks pretty crappy. On the plus side, the Lancer speakers seem good (was also a pain refitting the Protege with good speakers).
