Car and Driver Comparo is out
Old Nov 28, 2008 | 04:37 PM
  #376
C2Rally's Avatar
Originally Posted by ambystom01
On a good dyno that's about right. On a good dyno (ie. one that accurately portrays how much power you're putting down in a real world situation where there's load applied), an STI or an Evo puts down about 220 whp. Since the Ralliart is rated at 235ish, I figured I'd be nice and just take 40 off the above number. It could dyno as low as 160 whp if the 237 is accurate and the tranny eats up the power. A single number is meaningless unless we have a reference in which to frame it.
By the way 40 off is not 160, try 180
GO FISH!
Old Nov 28, 2008 | 05:05 PM
  #377
dboz's Avatar
The HP figures for the RA are very predictable from the performance numbers. Dyno numbers are great and all, but ultimately track times are what you should use. That is real world. The RA engine is not underrated. From the several sources that have posted drag numbers, the RA is right were Mitsu puts it 235-240 at the crank. You can argue whp all you want but what does it matter? The car runs what it runs. It isn't going to get any faster by hashing 1000 different dyno runs.
Old Nov 28, 2008 | 05:24 PM
  #378
dboz's Avatar
Depending on performance sources, the GSR is showing about 272-285 crank HP based on test numbers. That seems low. Of course those early test would be with the poor tune.
Old Nov 28, 2008 | 06:55 PM
  #379
boondoc's Avatar
Ok i found it. DSport magazine @ XS Engineering using a Dynamic DTS Dynamometer:
Baseline: 222.1 WHP, 230.3 LB-FT TQ
Eneos Synthetic Oil: 226.5 WHP, 233.8 LB-FT TQ
Sun Auto Hyper Ground Cables: 228.6 WHP, 236.6 LB-FT TQ
Greddy SE Exhaust: 232.3 WHP, 236.8 LB-FT TQ
This might not be amby's almighty Real world dyno but these are the numbers they got. From the picture it looks like the Dyno is outside but they didn't say the temperature.
Old Nov 28, 2008 | 08:51 PM
  #380
kyoo's Avatar
I haven't seen the article yet.. any links? I'm surprised the gti beat the wrx, among others
Old Nov 28, 2008 | 09:48 PM
  #381
ambystom01's Avatar
GO FISH!
Hence why I gave a range.
Old Nov 28, 2008 | 09:50 PM
  #382
ambystom01's Avatar
How on earth do those numbers make sense? There isn't a car in the world that is 97% efficient in turning crank HP into WHP. Those numbers are higher than STI and Evo numbers. Clearly that dyno is extremely high reading.
Old Nov 28, 2008 | 09:53 PM
  #383
ambystom01's Avatar
Please don't put words in my mouth! I have not suggested any WHP rating, mearly not believing a 33% drivetrain loss is all I"m getting at. Really if the Evo is at the 220whp mark then surely the RA will be much less. How about this then:
EVO rated 291hp crank
RA rated 237 hp crank
237/291 equals 19% difference
Therefor.... as you say and the shop tested; 220whp less 19% equals 193whp for the RA!
Is this a realistic assumption? There! now I've quoted a number! but how would I or anybody else know without REALLY doing a dyno run. Hang on there Amby someone will do it soon and prove your theory !!
Why is 33% unrealistic? Think of all the things in a car that sap power. You have the engine itself (accessories), you have the transmission, you have the differentials, you have the tires and of course you have other factors that don't do much, but add like the conversion of power into vibrations.
You're math is off. What's 237x 0.66 (since 66% of the power makes it to the ground)? It's 160ish. What you did didn't actually take into account the starting value but merely used another value and took a percentage of a percentage.
Old Nov 28, 2008 | 10:58 PM
  #384
ambystom01's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=384286 This might be a sign of things to come.
Old Nov 29, 2008 | 12:00 AM
  #385
C2Rally's Avatar
Read the way read the whole post amby! Again someone getting over zealous and jumping to conclusions about the SST, try the MAF sensor! quoting post #20
By the way I just heard the new wrx's only put down 150hp on a dyno! it must be true since I posted in a forum no?
It's amazing what people will believe.
Old Nov 29, 2008 | 01:39 AM
  #386
boondoc's Avatar
Ok hold on Amby. If u got beef with the numbers talk to XS Engineering and Dynamic Dynos. I understand ur point but I did say this might not be ur almighty 'Real World' dyno but it was outside, for all we know it could've been 40 degrees outside but these are the numbers they got.
Old Nov 29, 2008 | 01:43 AM
  #387
boondoc's Avatar
I bought the magazine i will try to find a online link. If not i'll try to photocopy the page and post it. Jus came from and tetas in my face so it's sleep time .
Old Nov 29, 2008 | 09:45 AM
  #388
dboz's Avatar
Go to post #1.
Old Nov 29, 2008 | 10:07 AM
  #389
heavyD's Avatar
Well Amby since you think a single person having an issue (not failure by the way) is a big deal I will offer something a bit more substantial for you. Another 2009 WRX bites the dust. This IS past the sign of things to come as double digit 2009 failures is nothing to dismiss.
http://forums.nasioc.com/forums/show...487482&page=21
Even a video of the issue on a 2009 for your pleasure.
http://www.youtube.com/watch?v=SvxaR7HSmWc
Cue the excuses lol.
Old Nov 29, 2008 | 10:32 AM
  #390
EsRt2evo's Avatar
HAHA turned out to be a MAF sensor. Nice try anyway.
