Pounding the White Rabbit
Old Jul 27, 2005 | 03:35 PM
  #196
4G63>OOOO's Avatar
Hmm, still no SAE corrected charts, but I do have some good information to add:
Al, this is where you would do an rpm pickup on a coil on plug equipped Evo with the BR ignition. Follow the yellow arrow and put alligator clip right on there after pulling the sheathing back a little. Easiest thing in the world.
Regards,
Old Jul 27, 2005 | 03:38 PM
  #197
Erik@MIL.SPEC's Avatar
I think Al does a lot of road tuning, hence no rpms.
Old Jul 27, 2005 | 04:36 PM
  #198
dryad001's Avatar
Originally Posted by ForcedPerf
Bad info. We have not recieved any of the high pressure actuators yet. They are due to arrive in about two weeks.
Robert Young
So what is the actual deal on these, is it just a heavier spring in the wastegate? Or is it completely redesigned? Is everyone getting one?
Old Jul 27, 2005 | 04:53 PM
  #199
Go to their website and look up the White Rabbit. The info is there.
IIRC, it's a stiffer actuator (I'm assuming the spring).
Old Jul 27, 2005 | 07:29 PM
  #200
mksevo's Avatar
Regards,
JUST FYI for all the people still learning about DYNOS, most dynos you do have to have the RPM pickup on or you cannot calculate the Torque, on our dyno you can choose to print the graph with either RPM or MPH is just an print option. I dont know why yall are trying to make some point of the RPM on the graph . its lame, lets get back to the topic. lets see an SAE graph, or have others shows their DYNO or track times with the WR. apples to apples. why cant some just call Pruven and get it printed and scanned. its not AL car, and so it should be up to AL to keep posting on this unless he has some other info to add. I noticed some issue with the Accuator and this needs to be clarified. I have good money to spend on mods and would like all the info before i drop 2000 grand. I would hope FP cont to get us info so we can make an informed decision. I dont have thoughts of grandeur. no simple bolton will start spewing thousands of HP out of cars but we should be able to see what is the next best step in our quest for more Performance and at what cost or sacrifice.
Old Jul 27, 2005 | 07:44 PM
  #201
DynoFlash's Avatar
Regards,
Thanks Joe for the hint - but my COP is different than that one and the wires go directly under the plate
I have a tach signal on my data logger so I do not need the dyno tach signal to tune my car
I will be posting those sheets tomorrow for you btw
Old Jul 28, 2005 | 04:15 PM
  #202
DynoFlash's Avatar
No matter which way you slice it - its still weak on the bottom
Attached Thumbnails Pounding the White Rabbit-pounding444.jpg   Pounding the White Rabbit-pomuding333.jpg
Old Jul 28, 2005 | 04:24 PM
  #203
Precision Dyno's Avatar
Run 90 is the WR correct?
So it gained only 4 HP and 4 FTlbs with corrected figures right?
Not much there... Thanks for posting those Al
Old Jul 28, 2005 | 04:46 PM
  #204
mksevo's Avatar
as was already mentioned. SAE correction gave very little to the graph. as expected. now back to discussion. was this the best tune for the WR , dont know. did the acuator adjustment play a role in the low power reading Dont know. we need more test mules and more dyno time for good answers. most of us would like to see this mod on a stock 2L motor not 2.3L if possible.
it may be a bit better than the stock 03, 04 turbo, but will it be better than the MR turbo. or the TME . ????
alright FP what other info do you have for us potential Turbo upgrade people.
Old Jul 28, 2005 | 05:17 PM
  #205
If you ask me, it's better than the TME based upon my car on 100 vs. a TME with cams and test pipe. The little dip on the end was Shiv doing something. THe final graph looks similar, but does not have that anomoly.
https://www.evolutionm.net/forums/sh...8&postcount=68
Old Jul 28, 2005 | 07:17 PM
  #206
mksevo's Avatar
I dont know Atlvalet , we are still not talking apples to apples, i would have liked to seen it on a similar setup with cams on each car and hiflow cat or test pipe. i think you will loose some of the performance potential with out cams but for those who dont have them yet its nice to see a good bump with out them .
i would ask the usual question, who tuned each car , when were each of these test run then compared. I would again look at area under the curve. it looks like Alex still had more power across the whole curve even tho you had peaks close to the TME. I would like to have seen your base pulls before turbo swap. do you have these please post these along side this one. if you have it posted else where sorry i didnt see it.
glad to see other stepping up with graphs and mods so we can cont . to hash this out .
Old Jul 28, 2005 | 07:21 PM
  #207
If you ask me, this comparision is as close as you can get. Alex went on the Dyno right after me. Both cars tuned by Shiv. Considering that I have a HFC and no cams or cam gears and Alex has cams, TME, and test pipe it's pretty close. We both have TBE and different intercoolers (IIRC).
Or think of it this way. My car didn't have cams or a test pipe while his did with TME turbo.
Old Jul 28, 2005 | 07:25 PM
  #208
shiv@vishnu's Avatar
The only way to make a better comparison between the TME and WR would be to tune them on the same car, same day. That's not going to happen any time soon, so I think atlvalet is right. His car compared well to a car with a test-pipe and cams. That is no joke.
Shiv
Old Jul 28, 2005 | 07:30 PM
  #209
mksevo's Avatar
come on guys , your leaving to much to chance. so then what would the WR do on a car with cams , 5 more hp 20 hp or 45 hp. ? see you just leave questions. this may help answer some peoples question with out cams . that leaves alot of us with cams still in the dark.
SHiv, its not that difficult to swap out the turbo on the same car., if FP want to sell turbos , this is money well spent to have common variables answered.
again , base runs before turbo swap is really a must.
Old Jul 28, 2005 | 07:32 PM
  #210
Well, I think the prevailing wisdom is that a test pipe is worth 10 to 15 whp and cams are 20 or so. Have you ever seen anyone with cams that only made 5 more whp? I certainly haven't. Honestly, I think you're just being difficult on purpose now.
