Let's see your fully tuned timing maps
Old Nov 21, 2007 | 08:57 AM
  #31
TouringBubble's Avatar
No knock. The possible side effects are increased EGT and reduced engine braking.
Old Nov 21, 2007 | 09:01 AM
  #32
esevo's Avatar
I will have to try that... Everyone has a little flamer in them
Old Nov 21, 2007 | 09:52 AM
  #33
JustDSM's Avatar
IX - Apexi Induction kit (w/ box), Nisei IC Pipes (Upper/Lower), AMS FMIC, AMS TBE, Hallman MBC @ 23psi.
Old Nov 21, 2007 | 10:05 AM
  #34
dudical26's Avatar
I just tried retarding the ignition for flames, and noticed one thing, the ECU will not set timing lower than -10, despite whatever is set in the map.
Also...it worked...lol
Old Nov 21, 2007 | 11:08 AM
  #35
EvoBroMA's Avatar
TB pointed already pointed that out.
DISCLAIMER: There's a good chance you are decreasing your turbo life every time you shoot fire. So implement at your own risk.
Old Nov 21, 2007 | 11:53 AM
  #36
As far as the -10 thing, it's a little confusing. With my testing, I started small (like -2) and went from there. I found that around -15 or -16 is where it seemed to work best. Even though the logs only ever showed -10, if I go below -18 or so on the map or above -12 or so the effect is almost completely gone. It makes no sense, but it was what I came up with ... hence my map.
Old Nov 21, 2007 | 12:07 PM
  #37
frenchy99's Avatar
Can you do it if you have a cat?
Old Nov 21, 2007 | 12:09 PM
  #38
NO! Do not attempt this if you have a cat installed! You can cause serious damage!
Old Nov 21, 2007 | 01:15 PM
  #39
grenade's Avatar
Are all these timing maps for the evo IX??
I dont really see any for the VIII !!
Old Nov 21, 2007 | 02:38 PM
  #40
lurkerpika's Avatar
well change that and post yours
Old Nov 21, 2007 | 02:48 PM
  #41
Mr. Evo IX's Avatar
This log had some knock at spoolup.. and counts of 1 and 2's up top. 25+psi.. mods in sig. except this was a brand new OEM air filter.
The car is normally detuned to around 23psi 330+/320+
Old Nov 21, 2007 | 05:51 PM
  #42
RazorLab's Avatar
The one I posted is a 05 MR
Old Nov 21, 2007 | 09:58 PM
  #43
C6C6CH3vo's Avatar
I didn't read any of the earlier related post's on other threads, but at what point does load get down to 30% while fuel cut reving?
Old Nov 21, 2007 | 10:02 PM
  #44
recompile's Avatar
It goes down there during a normal shift, and shoots flames while running through the gears. I don't know if there's a way to get the stationary limit to shoot flames
Old Nov 21, 2007 | 10:05 PM
  #45
grenade's Avatar
woot woot !
