Confirmed: Evo ROM Can Be Flashed to Lancer ECU
Old Apr 26, 2010 | 09:38 PM
  #61
RoadSpike's Avatar
Originally Posted by link62
when you click on the file names look at the last digits for 13ab i cant tell u the begging cause i just organized them all today
when opened it will say multiport fuel injection (mfi) diagnosis
Awesome i found it now
I'm going to disassemble the auto tranny rom and see if the code appears for the AT control in the evo and how to get it enabled.
  #62
ClixT's Avatar
time to share these:
dont mind the small Evo VIII text. it should be M/T
Old Apr 26, 2010 | 09:39 PM
  #63
ClixT's Avatar
thats gonna help a lot man.
Old Apr 26, 2010 | 09:40 PM
  #64
RoadSpike's Avatar
Originally Posted by 03lances
Lol just realized I didnt even attach the file... Twice!!! haha sending now
Took a look and there are a couple good spikes in that area but sometimes without even any knock. I would still try to get it out with tuning first just as a precaution before we try to make the knock sensitivity less.
Old Apr 26, 2010 | 09:45 PM
  #65
link62's Avatar
yes please do so
Old Apr 26, 2010 | 09:46 PM
  #66
03lances's Avatar
Ill keep taking her down and see what I get. Hittin the sack yall workin 6am tomorrow and getting late here.
Old Apr 26, 2010 | 09:52 PM
  #67
turbolancer02's Avatar
the manual evo uses a completely different pinout and connector numbers then the lancer auto, , the gta uses almost the same as the manual evo , if someone has a copy of that pinout I think thats the key to this ,
Someone would have to disable the extra one gear in the wagon rom and I think it'd work
Old Apr 27, 2010 | 08:28 AM
  #68
ClixT's Avatar
here:
credit goes to nads1978
Old Apr 27, 2010 | 01:05 PM
  #69
RoadSpike's Avatar
OK guys update.
There is a major problem trying to use the evo 8 rom on an auto. I have disassembled partially a volunteers rom and have discovered I think the reason I'm having so much trouble finding the auto transmission variables.
Its pretty simple, the rom isn't really 256kb in size its really 512kb like the evo 7 GT-A rom. So essentially I think the auto guys at this point could use the larger 512kb gt-a rom as previously suggested. I'll need to do some more research to figure out how that will work though shouldn't be too much of an issue.
Old Apr 27, 2010 | 01:28 PM
  #70
RoadSpike's Avatar
Auto transmission guys I need someone to do an experiment for me.
Download and place this file into this folder.
C:\Program Files\OpenECU\EcuFlash\rommetadata\read templates
If you had ecuflash open close and reopen it. I need you to read the lancer rom again trying the new read method of 2002-2007 lancer a/t
It should produce a 512kb file. It shouldn't be dangerous to read the rom even if it fails. If this works I believe we can tap into the Evo 7 GTA rom or hack up an Evo 9 rom which is based off the evo 7 GTA to be used for turbo'ing the car
File Type: zip
read_lancer_auto.zip (302 Bytes, 0 views)
Old Apr 27, 2010 | 02:27 PM
  #71
ClixT's Avatar
ok imma try this
Old Apr 27, 2010 | 02:30 PM
  #72
ClixT's Avatar
so do i just copy and paste it, then open my rom?
EDIT: oh and btw, if you try to read the lancer ecu thru evo 9, its gonna produce a 512kb rom.
EDIT 2: i used to have the "flashed" ecu before so its reading thru evo9/eclipse AT.
i tried it again with a normal ecu and it didnt work.
Old Apr 27, 2010 | 02:32 PM
  #73
RoadSpike's Avatar
No I need someone to try reading the rom again.
If you had flashed the rom with an evo one you'll need to flash ti back before trying this. Just read thec ecu with the program and select lancer a/t instead of evo 8 this time.
Old Apr 27, 2010 | 02:33 PM
  #74
ClixT's Avatar
ok brb in 5 mins
  #75
RoadSpike's Avatar
Nice I'll send you a pm with my email so i can check that puppy out.
