Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
Old May 1, 2009 | 09:48 AM
  #376
Clipse3GT's Avatar
one measuring the pressure in the manifold (after the turbo but before the cylinders) that is the Manifold Absolute Pressure (MAP), and one sensing just the pressure of the air in the atmosphere (Barometric Absolute Pressure (BAP)). The relative pressure is the difference between these = MAP - BAP.
Relative Pressure = MAP - BAP
I'm no tuner so I'll let other chime in. The way I see it, the relative is showing you what pressure the turbo is contributing (MAP - BAP). So, to know how "well" your turbo is working, I'd check relative (hence what most guages read).
MAP (Absolute) actually shows you what your engine is seeing, so this is what really determines performance (along with temp, etc.).
Actually, either can work since the atm pressure (BAP) hardly changes at all -- it hovers around 14.7 psi. A two inch change in mercury only equals about 1 psi, so even as the weather is changing, just subtract 14 psi and you're close (or simply remember "hey, my max MAP is usually 32 psi absolute").
Old May 1, 2009 | 11:06 AM
  #377
masudkarim's Avatar
Anyone compare the AccessPort
Don't anyone ever go to Dyno-Comp in Scottsdale AZ, they lie, cheat, and steal. ... The Accessport is an AWESOME product, with many capabilities, very advanced in what it can do and what it can ..... The Real RocknRolla
Old May 1, 2009 | 08:59 PM
  #378
ApexSilverXGSR's Avatar
so has anyone done any kind of comparison?
Old May 2, 2009 | 10:08 PM
  #379
empirepb210's Avatar
Is it pretty safe to run cobb stage 2 with these mods?
3 in cat back/3 in test pipe and cone filter with venturi ring for the intake.
thx in advance
Old May 3, 2009 | 05:31 AM
  #380
smoke4's Avatar
No. I have cobb AP with a cat back and I tried both works dropin filter and perrin dropin filter. To be honest, I felt like the works filter made the car act wierd before I even had the cobb ap installed. The reality with this car seems to be leave the air filter alone unless you are going for big power and have a custom tune to go with it. Especially NO cone filters! This is just my opinion from a little experience and alot of reading.
Old May 3, 2009 | 06:23 AM
  #381
Excalibur's Avatar
That is the one filter that cobb suggested I didn't go with when I called them. I don't know why. Maybe b/c of what you're talking about.
Question; when datalogging via the ap, which selection monitors afr? I'm sure which ever it is won't be all that accurate, but I was just wondering.
Old May 3, 2009 | 10:47 AM
  #382
but it's like the same thing as their Cobb Sf intake, i would think it would be good but idk
Old May 3, 2009 | 11:37 AM
  #383
smoke4's Avatar
I think you will find with the cobb ap loaded up with stage 1 map. You wont want to muddle it with an intake. The map does well on its own. Get it tuned for a filter.
Old May 3, 2009 | 04:03 PM
  #384
Silversx's Avatar
cobb has a map for ca/az/nv 91 octane gas but it says requires turbo back exhaust..
what map should i run if i just have k&n drop in filter and i live in cali
would it be ok to run stage 1 aem intake map if i have k&n drop in??
Old May 3, 2009 | 04:14 PM
  #385
bouncintiga's Avatar
so nobody has results for econ mode yet? been hoping to hear from you guys.
Old May 3, 2009 | 07:09 PM
  #386
smoke4's Avatar
Our results were consistently decent mileage. Before any flash we sometimes we would get 24 mpg. After econ mode it happened a little more consistently. We can easily get 24-25 mpg. Ive gotten as high as 28 mpg for a days average on the way from tennessee to va. Really depends im sure on what rpms you are running.
Old May 4, 2009 | 09:05 AM
  #387
Tunerhead's Avatar
Gotta use wideband for afr monitoring. COBB AP doesn't have sensor to monitor afr readings.
Old May 4, 2009 | 09:19 AM
  #388
dek0026's Avatar
dude this thread is pointless.
why doesn't anybody read cobb's website or the map notes they are downloading and flashing. all these questions/mistakes have been made many times before and are well documented on this site.
Old May 4, 2009 | 05:00 PM
  #389
lukiluv69's Avatar
AP reflash to stock question
The cobb access port reflashes back to stock, but it doesn't remove the access port from the ecu. Is this noticeable if a dealer was to check or manage my ecu? And im assuming if so this would void my warranty. Thanks guys.
Old May 4, 2009 | 05:39 PM
  #390
Q15H's Avatar
If you want it back to stock, remove the AP ( unmarry it )
It's always a good idea to set it back to stock whenever visiting a dealer. They just might happen to reflash to a newer, stock map and destroy your AP installation.
