MIVEC tuning
Old Sep 6, 2011 | 02:45 AM
  #706
VGergo's Avatar
What is the suggestion on Mivec maps with 2.4 high compression engine with Fp black or similiar turbos ? Are you guys runing with full mivec advance until peak boost too ? than tappering as the RPM goes higher ? I will play with the Mivec table and see how the power curve change on Virtual Dyno .
Old Sep 25, 2011 | 08:50 PM
  #707
killerpenguin21's Avatar
so in my never ending adventures with whatever the hell the previous owner had done to my car...i discovered this bastard of a mivec map.
it appears some what similar to someparts of a jdm map, and seems to look nothing like what people have suggested for tuning...
any thoughts would be greatly appreciated. i may just load a regular jdm map.
(top is whats on my car, bottom is a JDM RS map)
Old Sep 26, 2011 | 08:03 AM
  #708
211Ratsbud's Avatar
That doesn't seem so bad, it has high advance for spool and tq, but tapers off by ~6000
Old Sep 26, 2011 | 08:05 AM
  #709
Raptord's Avatar
Agree, I've definitely seen worse than that.
Old Sep 26, 2011 | 08:11 AM
  #710
I just can't figure out the theory behind it compared to what else I've been seeing. I need to see what happens by clearing out the advance at idle and low rpm, as the car isn't that easy to drive in those conditions.
Old Sep 26, 2011 | 11:34 AM
  #711
chetrickerman's Avatar
Veteran: Army
So you guys are basically running full advance until the turbo spools?
Just wondering
Old Sep 26, 2011 | 11:58 AM
  #712
SWOLN's Avatar
Originally Posted by SWOLN
Question : In tuning the MIVEC. Does it seem to be the best to have max MIVEC at peak torque, and then taper down. Basically following the load down as boost tapers off ?
Originally Posted by JohnBradley
Yes But actually a little prior to the actual torque value. Spool, decrease advance, profit.
I think it was answered.
Old Sep 26, 2011 | 01:18 PM
  #713
so i made a little mashup of these two maps. just copy/pasted from 0-80 load of the JDM RS map into the mystery map. figured id keep the top end for now since it seems to be making/holding good power.
the car is now 100 freakin times smoother. SOOO much easier to drive around town, no more messing with the throttle from a stop sign, just a single smooth input, the car no longer feels like its its stumbling between gears, and best part is it no longer tries to stall out when coming to a stop with the a/c on.
the car went from having issues i thought were just "because it was an evo" to driving like a civil car.
thanks to everybody who posted in this thread...i would have never even looked at my mivec map if i hadnt read this thread and had such good insight.
Old Dec 26, 2011 | 03:59 AM
  #714
marcoEVO9's Avatar
I have a Mivec Map for you guys to analyze.
I bought my car used 2 years ago and it came de-tunned. (supposedly). Im not sure who the tunner was but i have a couple ideas... Anywho, I tried john and Nj mivec map and it felt good but i think this one might feel alittle better. But i want to hear feed back from you guys!
I dont have access to a dyno, but when i get back my laptop i will at least run a dyno sim or something.
Old Dec 26, 2011 | 08:23 AM
  #715
vmrevo9's Avatar
Veteran: Air Force
what mods (turbo, boost, etc) do you have?
with my Mivec map which is very similar to yours
i did this pull in 3rd today and she felt good but there are some areas where i need to give some attention to. for some reason my spool has become lean but im actually dropping the 1000cc injectors for 880s. plenty of injector for my setup. than im smoothing out my AFR.
Old Dec 26, 2011 | 11:24 AM
  #716
marcoEVO9's Avatar
Im surprised our maps are almost identical. Ever been to So. Cal? Who tunned your car?
when i bought the car it came with, GM3 port boost solenoid, Walbro, and de-tunned, I believe is is boosting 21lbs and 20 at redline. Since then i bought IC pipe with air filter, o2 housing, turboback, havent touched boost.
Ive been reading up on tunning and well im going to tune her myself, im just waiting the wideband and boost gauge.
What are you going to do to your 1000cc injectors? Ive been looking for injectors, i want to run e85 since i have a pump like 3 minutes away from me. If you sell them i might be interested if the price is right. Let me know!
Old Dec 26, 2011 | 12:47 PM
  #717
vmrevo9's Avatar
Veteran: Air Force
Never been to socal. I have had a couple people tune the car but that map I have tweaked myself afterwards. I'm pushing 26psi tapering to 23 by 7k. I'm learning to "tune" myself which is fun for me. I like doing things to my car. Mivec seems to be a little more complex to me compared to timing and fuel. But I'll figure it out
I plan on selling the injectors pm me if your interested.
Old Jan 15, 2012 | 02:47 PM
  #718
evolvd276's Avatar
i need some help with my mivec tables if i could get some good help i would be greatly appricative i recently finished my second 2.4 because i think the mivec helped hill the first one now i just got my second 2.4 started and really dont want to drive it till i get a safe mivec map .
thing is i think i got to much or not enough advance because i didnt know my last tuner didnt chane the mivec tables from my stock tune i now have a 2.4 again with kelford 282s . the bigest thing my last motor tore up when i was heading up a steep incline on interstate in less than 5 lbs of boost it ate 3 of 4 plugs and broke all 4 top rings
Old Jan 15, 2012 | 04:23 PM
  #719
vmrevo9's Avatar
Veteran: Air Force
I'm not sure if mivec will allow the valvetrain to make contact with pistons. I wonder if your timing was off?
Old Jan 15, 2012 | 05:32 PM
  #720
evolvd276's Avatar
i am def not sure i do know that the timing all lined up the exhaust cam on the cam gear is at 2 degrees advaned thats really what i know im worried about the mivec
the car starts and revs fine i have added fuel in the tune so far using a new wideband also im running an aem ems v1
