AEM UEGO Serial Cable Instructions
Old Feb 27, 2009 | 09:13 AM
  #166
Fast_Freddie's Avatar
Veteran: Navy
How much interest would there be if I prefabbed some of the serial connectors with blue wire(3 ft) and black wire (3 ft + t-lug for ground) with instructions for the AEM wideband? PM me if you are interested
Old Feb 27, 2009 | 07:14 PM
  #167
Veteran: Navy
Made 3 today here is a pic of the finished product. All you have to do is connect the blue wire to the blue wire coming off the AEM UEGO and ground the black wire... PM me up if you guys need one...
Old Feb 27, 2009 | 09:58 PM
  #168
Veteran: Navy
One has a home... I still have 2 left!
Old Apr 7, 2009 | 12:04 AM
  #169
GRNCT9A's Avatar
This is confusing. I found a link to a 15 pin serial, but it has 3 ground pins. Which one do I solder too? There is the 1+8+15 pin for ground (Black) and the 13 pin to recieve data (blue). I try logging it with all the ground pins connected and I get the AFR column, but no AFR data?
I'll keep reading around.
Old Apr 7, 2009 | 12:15 AM
  #170
GRNCT9A's Avatar
Never mind, I believe its because I have vista and I need a serial to usb adapter...stupid vista.
Old Apr 17, 2009 | 08:07 PM
  #171
555R's Avatar
pm me about that cable fast freddie
im interested in one if it works with vista and a usb convertor
heck piece it together with the drivers etc
let me know
Old Apr 19, 2009 | 04:12 AM
  #172
Veteran: Navy
Here is a direct link to the for sale thread I started for the serial cables...
https://www.evolutionm.net/forums/sa...g-evoscan.html
Old Apr 20, 2009 | 05:50 PM
  #173
Gary@MellonRacing's Avatar
any one else know were i can get this cable from ??????
freedie is of on a ship and i need it asap
Old May 8, 2009 | 09:34 AM
  #174
the_mork's Avatar
What connector are you guys using? A link would be helpful. I looked at Radioshack and didn't find anything useful. I found a scanner cable that I bought but it only has two wires in it and I haven't tested to make sure that they go to the right pins.
Old May 8, 2009 | 11:40 AM
  #175
fostytou's Avatar
EvoM Community Team
I thought someone had posted it. Try this
http://www.radioshack.com/product/in...ductId=2102498
Otherwise if you want to buy a full cable...
http://www.radioshack.com/product/in...ductId=3109713
http://www.radioshack.com/product/in...ductId=2049676
I use the first one and leave it under my ashtray, when I need to have the cabl in I pull the ashtray and plug in one like the second one posted (but from monoprice.com).
Old May 8, 2009 | 11:59 AM
  #176
the_mork's Avatar
Thank you very much, my local radioshack didn't have any of those available.
Old May 8, 2009 | 12:18 PM
  #177
fostytou's Avatar
EvoM Community Team
They are usually in a small slide-out drawer "bin" near the resistors/LED's/Circuitry stuff.
Old May 8, 2009 | 12:30 PM
  #178
rogue's Avatar
Go to your IT guys at work or look around at home for an old serial mouse and cut the cable off of it.
Old May 13, 2009 | 05:02 AM
  #179
the_mork's Avatar
I purchased this cable
and it was perfect. The pins are labeled on the end for easy continuity checking (keep in mind the AEM instructions show an incorrect picture) and the wires inside it happened to be the same colors as the AEM instructions suggested. I wired it up in just a few minutes and it worked great.
Old May 13, 2009 | 09:55 AM
  #180
fostytou's Avatar
EvoM Community Team
FYI your link is corrupted, you posted the truncated version with the ... in it. It should be http://www.radioshack.com/product/in...ductId=3109713
What diagram was wrong on the AEM? I believe I used their picture to create my cable and it was fine.... maybe you were looking at it backwards?
