ECUFlash / Evoscan / Mitsulogger Questions
Old Aug 4, 2012 | 08:31 AM
  #1261
jayE5's Avatar
My first post here guys and probably a bit of a newb question...
I want to start logging my EVO 5 so bought a copy of EVOscan and a cheap VAG COM cable from ebay(a search on the net said this cable will work)
My problem is with drivers. Ive not installed the drivers that came with the cable instead ive tried to use the drivers that come bundled with evoscan/ecu flash software but no matter what i do i can not get the drivers to install with the cable.
In device Manager i get USB 2.0serial under "other devices" with the yellow exclamation mark, if i try and update driver from there using the bundled drivers i get the message ...windows can not find drivers..
Any help would be greatly appreciated.
Thanks in advance...Jay
Old Aug 4, 2012 | 01:01 PM
  #1262
Jeramiahs1's Avatar
Hi,
I have a 2006 evo 9 mr with injen intercooler piping, intake, magna flow catback, turbo xs manual boost controller and a pro tune.. I recently failed california OBD II emissions test because my ecu isn't storing any information in it.. when I hook up my obd II meter it says "no DTC's are available...my question is can I buy another stock ecu off ebay and swap it out with mine, put all of the stock intake, intercooler piping etc back on and smog it? BTW i am in california and I bought the car with the tune installed and I have no Idea who tuned it..Sorry if I posted this in the wrong place I am new to this! thankyou
Old Aug 5, 2012 | 01:47 AM
  #1263
nudge120's Avatar
How do you make a shift light for evoscan GPS? I have the image, x y location and size, but don't know how to address it. I want to start it at 7k. Any help is appreciated.
Old Aug 5, 2012 | 02:12 AM
  #1264
atmdyno's Avatar
MalibuJack, how can i live tune my evo without worrying about reading the map and then writing it to my ecu,
i heard that you can live tune your stock ecu using ecu flash,
how is it done?
Old Aug 5, 2012 | 08:24 PM
  #1265
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Is there any way to quickly figure out the difference between two maps?
Old Aug 5, 2012 | 08:30 PM
  #1266
07EvoIX's Avatar
atmdyno: You will need to use ELM (Evo Live Map) for tuning on the fly
Butt Dyno: I use excel, i find it easy this way.
cheers
Old Aug 5, 2012 | 11:05 PM
  #1267
Jhusey's Avatar
Hi, i own an evo 7 with teprha mod v7
How do i disable the egr??
My egr was removed long time ago before i reflash my ecu, so i didnt have that problem of check engine for egr
After we tune the car it appear the check engine light. Then i scan the car and it says code P0400 Exhaust Gas Recirculation Flow Malfunction
thanks
Old Aug 6, 2012 | 10:12 AM
  #1268
atmdyno's Avatar
hi, sorry for my ignorance but i didnt find out how to tune using ELM, i couldn't open any hex file that i used to open using ecuflash, is it because i have the light version of the ELM?
Old Aug 6, 2012 | 11:59 AM
  #1269
atmdyno's Avatar
one more question,
if i replaced my stock map sensor with a 3bar gm map sensor, how can i calibrate my voltage values using ecu flash
Old Aug 6, 2012 | 03:53 PM
  #1270
GD1087's Avatar
hi guys
i want to upgrade my map sensor, is this possible on the standard ecu? if so, has anyone got a write up?
Old Aug 6, 2012 | 07:03 PM
  #1271
Raptord's Avatar
Originally Posted by GD1087
hi guys
Yes. What sensor are you looking to go with?
Old Aug 6, 2012 | 08:26 PM
  #1272
CDrinkH2O's Avatar
thanks
Find this section in your V7 ROM and change the 1 to 0
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-capture.png
Old Aug 6, 2012 | 11:55 PM
  #1273
GD1087's Avatar
not sure, i was looking at the omni 4 bar one, just want to know how to install one (ie, do i need a specific map in my ecu) and what pin to tap off the standard ecu.
Old Aug 7, 2012 | 08:00 AM
  #1274
ihockey1's Avatar
bringing this up from the last page
Originally Posted by ihockey1
alright i know this has been asked but i cant find where, what is the zeitronix boost formula for evoscan so that it reads correctly
Old Aug 7, 2012 | 10:01 AM
  #1275
Jhusey's Avatar
thanks
