Evo IX 2-byte Load & Lean Spool for Dummies
Old Feb 10, 2008 | 11:30 PM
  #181
Profoxcg's Avatar
Originally Posted by Jack_of_Trades
I'd suggest keeping your eyes on the road and inspecting your map tracer logs afterward
lol , yes indeed
Old Feb 14, 2008 | 08:47 PM
  #182
SeanV's Avatar
Originally Posted by Pd1
FOR VERSION 8 ROMs (Evo VIII), refer to the following how-to:
https://www.evolutionm.net/forums/sh...d.php?t=272246
Newbie here....
after doing extensive searching, I can't find any information that will help me to setup 2 byte load and lean spool for my Evo8 with ROM id - 96530006.
Will the above procedure which is intened for an Evo with Rom ID 94170008 ROM work on my Evo 8 Rom - 96530006?
Any help greatly appreciated, thx.
Old Apr 8, 2008 | 01:06 AM
  #183
nonschlont's Avatar
ok I just added 2byte load and leanspool start/stop rpm... My current value for start rpm = 3250
stop rpm = 1250
from what I have read I need to change start to 2500
and stop rpm to 7000?
also I have start and stop, but I dont have enable and disable, are these required or is the start/stop and updated version of enable/disable?
I also have lean spool load threashold/leanspooltrailingtime(rich side)/ (lean side)/ min. temp. 4 lean spool/ lean spool enable load hysterisis/ lean spool afr mapping/ lean spool afr below enable/ lean spool clip value...
Old Apr 8, 2008 | 11:32 AM
  #184
nonschlont's Avatar
bump
Old Apr 9, 2008 | 03:21 PM
  #185
nonschlont's Avatar
I have read the entire thread, and from what I understand, I have my definitions in my .xml (88590015) to read actual rpm? And I need to edit them to read 2500 for start, and 7700 for stop. As my tune is set up for enable 2500 disable 7700 also my boost enhancement (antilag) start/stop read 2500/3541... Do I edit these values?
Old Apr 10, 2008 | 12:26 AM
  #186
nonschlont's Avatar
anybody?
Old Apr 11, 2008 | 03:45 PM
  #187
nonschlont's Avatar
any1 kind enough to confirm this for me???
Old Apr 18, 2008 | 02:36 PM
  #188
amak87's Avatar
subscribed.
Old Apr 19, 2008 | 09:13 PM
  #189
nonschlont's Avatar
finally got it. I guess my definition was a lil different from the one used when I was tuned...
Old Apr 22, 2008 | 04:37 PM
  #190
xpro's Avatar
any info for 88570008 rom.Does anyone one know the values for this rom,as i couldnt find anything for that rom.
thanks
Old Apr 22, 2008 | 05:35 PM
  #191
tephra's Avatar
xpro what do u want to know?
Old Apr 23, 2008 | 12:25 PM
  #192
xpro's Avatar
just want to enable 2byte load on my rom,need the exact formula if possible.
thanks phil
Old Apr 23, 2008 | 12:30 PM
  #193
nonschlont's Avatar
Ill post it up when I get home!
Phil... lol
my name is Phil also...
Old Apr 23, 2008 | 12:37 PM
  #194
nonschlont's Avatar
actually, In my newbness, I believe there are 2 ways to accomplish this.
1. Is to have the definition for "2 ByteLoad" in ur .xml file for ecuflash "15" mine is 88590015
2. The other way is to add the 3D MUT table to ur .xml file for ecuflash "15", and make sure the ID"s are matched up. 2ByteLoad is 00, and 01 on the 3D MUT table and the address is 6B42, 6B43. So in the 3D MUT table @ 0,0 u would put in 6B42, and @ 01 u would put 6B43. Save, flash to ur car and u can now log "2 byteload".
Old Apr 23, 2008 | 01:30 PM
  #195
SWOLN's Avatar
Hey, I did this mod and with the Green and JUN 272 in 4th gear I was able to hit 25 psi at 3250 rpms. Thanks
