Want to remove/disable your rear O2 sensor without a CEL? Here's how..
Old Mar 24, 2008 | 05:14 AM
  #211
phenem's Avatar
Originally Posted by mrfred
I found the subroutines where the heater circuit is checked. Now I just have to figure out what the heck is happening in those subroutines. Once I figure out what's happening, I can make a software sim to eliminate the heater CEL without having to add a resistor.
Well, in the meantime I am running the v5 patch from Tephra, what resistor do I need?
I am confused from the first post it seems like it is working for him but others in the post have said it gets too hot....etc...so whats the right resistor? Has anyone had any luck with their testing?
~Zach
Old Mar 24, 2008 | 12:04 PM
  #212
mexevo's Avatar
i have the resistor unther the car fixed to the pipe heatshield wired thru the original sensor so it does not mater if it gets hot i am woried about posible short so i am jut waiting for the heater patch
Old Mar 24, 2008 | 12:08 PM
  #213
mrfred's Avatar
~Zach
If you've got a current meter, the ECU looks for a current between 0.17 A and 10.5 A across the heater when the heater circuit is engaged, and then it looks for a voltage of > 2.0 V across the heater when the circuit is not engaged. The current seems easy enough to measure. Not sure where the ECU is measuring the voltage (wouldn't seem to be across the O2 sensor), so not sure how to measure that.
Old Mar 30, 2008 | 07:13 AM
  #214
Oettinger's Avatar
Where is this connector?? under the passenger seat?? Not find it Help-me!!!
Old Mar 30, 2008 | 09:12 AM
  #215
logic's Avatar
That's the plug under the passenger seat (and under the carpet, if memory serves) that connects to the rear O2 sensor under the car.
Old Mar 30, 2008 | 03:22 PM
  #216
tephra's Avatar
its not really under the p-seat, more like under the dash where the feet go.
just pull the carpet back on the side that the gear stick goes you should see it!
Old Mar 30, 2008 | 04:15 PM
  #217
mitsuboost30's Avatar
Its under the seat!
Old Mar 30, 2008 | 04:30 PM
  #218
tephra's Avatar
must be different on different evo's
mine is inside the kick panel..
Old Apr 1, 2008 | 04:32 PM
  #219
Oettinger's Avatar
I see under seat passenger and next view under the carpet, and no look this conector in wher site, only see metal white
It is necessary to remove all the original carpeting for see this connector?
Show me one photo, please!
Other question, Kick Papel... is under Ecu?? or where is??
Sorry my bad english!
Old Apr 1, 2008 | 04:56 PM
  #220
mexevo's Avatar
its beter to go the other way, you can go under the car and see where the wire comes to the inside of the car, there are many groomets on the flor and by what i see here not all evos use the sameone, mine its wright under the pasenger seat under the front left corner of the seat, hope these helps pictures tomorrow
Old Apr 1, 2008 | 05:56 PM
  #221
Oettinger's Avatar
Ok! Thanks, waiting the photos for my trouble!
Old Apr 6, 2008 | 07:42 AM
  #222
Oettinger's Avatar
I put the resistance between yellow-red and yellow-blue. Now the car new error, the P0141[Heated oxygen sensor heater circuit (sensor 2)].
Help-me please!
Old Apr 6, 2008 | 08:37 AM
  #223
dyablo's Avatar
"I have a software fix for the Rear O2 CEL for the Evo IX 88590015 ROM" that leaves the O2 sensor in place and does not throw a CEL?
Still no fix that completely eliminates the rear O2 sensor on the evo 9 with out a CEL?
Old Apr 6, 2008 | 09:02 AM
  #224
nothere's Avatar
its very prehistoric, but you can kill the cell with a antiflouler extention that the o2 sensor bolts into. I know it works, even catless.
Old Apr 6, 2008 | 09:35 AM
  #225
dyablo's Avatar
well yeah i knew about that just wanted to ask for another option.
