Let's see your fully tuned timing maps
Old Aug 31, 2013 | 01:42 PM
  #2431
211Ratsbud's Avatar
Leaner afr to a point - crispy feeling I'm now 13.8 +- at
6-8 psi damn clean it feels. Closed loop to 120 load . I used to err on the rich side but at low boost there's no point with error to the rich side.
Old Aug 31, 2013 | 03:00 PM
  #2432
NightCat's Avatar
Different Car. Still an Evo IX on E85
Old Aug 31, 2013 | 04:51 PM
  #2433
domyz's Avatar
Damn I'm impressed everytime I see these maps... I wish e85 wasn't 1000miles from here.
Old Aug 31, 2013 | 06:36 PM
  #2434
211Ratsbud's Avatar
Yes.. Damn.
Old Sep 1, 2013 | 03:25 AM
  #2435
NightCat's Avatar
anyone wanna throw out some input bout the map? Always open to hear outside opinions.
Here's this to go with it..
Old Sep 1, 2013 | 12:19 PM
  #2436
90zcrex's Avatar
Looks pretty good to me, as long as your not over MBT. The only thing I would do personally is rescale the RPM axis and take out some of the lower rpm values and add some more rpm values uptop for more resolution. But thats just me.
Old Sep 3, 2013 | 08:07 PM
  #2437
01sporty's Avatar
I hate the fact that all we have is crap 91!!!!!!!!!
Old Sep 3, 2013 | 08:24 PM
  #2438
domyz's Avatar
We're sparking at like a full second before MBT
Old Sep 28, 2013 | 01:30 AM
  #2439
gsteensland's Avatar
Here's my first try with timing. I haven't flashed my ecu yet. Still have stock tune.
Evo 8, exhaust, UICP, synapse DV, EBC set to 21 psi, and 91 octane.
Any suggestions for changes?
Is this safe and a good place to start?
Thanks
Old Sep 28, 2013 | 07:44 AM
  #2440
domyz's Avatar
It's a nice map. It could use some smoothing (try my smoothing tool https://www.evolutionm.net/forums/ec...t-version.html).
But I'm pretty sure you will knock at high RPM if your load drop below 240. Make your 220 and 200 columns look more like the 240 column. Beside that, look for knock here and there but I think it will be okay.
Thanks
  #2441
Raptord's Avatar
Seems decent but it would help to know what loads you're hitting. Your peak torque timing might be a bit high for 91 oct depending on what load you're reaching.
Old Sep 30, 2013 | 08:44 AM
  #2442
Ok, I've attached a edited .xml file from a run this morning. I've cut out most of the cruising parts. All the pulls were in 3rd, 4th, or 5th.
I didn't get much knock except a 4th gear pull, and under 50% throttle at normal acceleration when the turbo was spooling up.
On the 4th gear pull that had bad knock, I had turned my boost up by 1 or 2psi to see how it would do and I saw leaner a/f on my wideband that what is recorded on my datalogger, and I also got studdering when I hit full boost. I turned it back down from 22psi to 21 and did several other pulls and it was fine.
Also, does the "AirVol" column look normal on the document? Those number are bouncing all over the place.
Thanks for the help.
File Type: xml
Old Sep 30, 2013 | 10:37 AM
  #2443
Biggy VIII's Avatar
Dyno thread https://www.evolutionm.net/forums/ev...gear-pull.html
Attached Thumbnails Let's see your fully tuned timing maps-fpgreen-timing-1-.gif   Let's see your fully tuned timing maps-fpgreen-timing-2-.gif
Old Sep 30, 2013 | 02:41 PM
  #2444
desiromeo812's Avatar
I would back it down a hair up top.. Usually you want 7-7500 area at 15-17*.
Old Sep 30, 2013 | 02:43 PM
  #2445
Originally Posted by Biggy VIII
Are you sure you are in ned of 6* at peak tq area? U should bring that down to 3-4* and see if the power changes a lot.
ON another side up top your timing looks nice.
