Let's see your fully tuned timing maps
Old Jan 30, 2016 | 11:44 PM
  #2641
ZanarkO's Avatar
Originally Posted by blitzkreig
car : evo ix
mods: engine and head is stock. stock ix turbo. 3.5 ETS intercooler. LICP.
fuel : 98 Octane
boost : 22psi falling to 19psi
a/f : 11.5-11.3
This is pretty dead on, Good job mate I will say once you do cams you could get away with slightly less timing up top, and I only say this because you have a IX
Old Jan 30, 2016 | 11:47 PM
  #2642
ZanarkO's Avatar
Originally Posted by ReaperX
It has been a bit since I changed my setup for this past race season. I only had a chance to run this map at 1 event. It is an all out map for Global Time Attack events. It only sees 1 to 3 hotlaps in a 20 minute track session.
Mods:
GSC S2's w/ 5041 springs and Ti retainers
FP 71hta w/ stock wastegate actuator preloaded to the max
FP 84mm FAP Cover w/ FP Intake
FP Race Manifold
APS Twin Vent BOV
FIC 950's
Aeromotive 320lph pump
VRSF 3.5" IC
ETS LICP
Muse UICP
Map o2
Invidia DP
3" Straight Pipe Exhaust
Logged 26.6psi peak, 25psi by 7k and 24psi to 8k. 93octane. 396/355 to the wheels on a Mustang Dyno
Is this an 8 or 9? Seems like you could get away with a couple more degrees up top, Im curious how well it holds tQ to redline. Does it die out up top?
Old Mar 1, 2016 | 06:26 PM
  #2643
jeffbeagley's Avatar
What do you guys think about this. Car is an 8 with a 2.4LR 9:1 CR motor with an Evo 8 Head, GSC S3s and an Evo 8 Turbo with 9.5 hotside on E85.
My old setup made 630 on a 62mm and a stock block, so this will be quite the change for me
Just got the new motor installed and started up for the first time yesterday, but haven't driven it yet. I anticipate peak tq being around 4000-4500rpms with the S3s. I could be way off though.
Old Mar 10, 2016 | 01:12 PM
  #2644
LuckyManiac's Avatar
I have evo 8 with evo 9 turbo and 272 cams..
It was running OK but now I have significant power loss, very low AFR and a lot of knocks..
Please tell me something about this tuning
Attached Thumbnails Let's see your fully tuned timing maps-2016-03-10-23.08.01.png   Let's see your fully tuned timing maps-2016-03-10-23.08.02.png
Old Mar 10, 2016 | 01:41 PM
  #2645
LetsGetThisDone's Avatar
Depends on what load cells you'll be hitting and fuel you're running..
Old Mar 10, 2016 | 02:07 PM
  #2646
RazorLab's Avatar
Since it's blocked tuned and a 2.4L, stock turbo on E85 he will easily be past 260 load at WOT, does it matter?
Old Mar 10, 2016 | 03:14 PM
  #2647
It matters because if he's on speed density, depeding on SD tuning, 28psi could be 300 load, or it could 250 load. I also wasn't sure how much it may or may not taper boost, which would effect how low the load will go out the top. For example, if it hits that 160 load cell at 8k rpm for 27*, that's kind of a lot...lol
Old Mar 11, 2016 | 05:09 PM
  #2648
3gturbo's Avatar
Thats what I was thinking too
Old Mar 13, 2016 | 06:06 PM
  #2649
ReaperX's Avatar
It is an 8. I loose 100 wtq by 7500 rpm from peak. It starts around 5900. I think there is too much back pressure with the 9.8 housing I was running with that turbo to add anymore timing and still be reliable on track.
Old Mar 16, 2016 | 09:10 PM
  #2650
C6C6CH3vo's Avatar
I also wasn't sure how much it may or may not taper boost, which would effect how low the load will go out the top.l
Factory turbo is like an exhaust shut-off valve closing beyond 5k. Esp with S3 cams
Old Apr 8, 2016 | 08:03 PM
  #2651
EvoSupersonic's Avatar
Hey guys, I’m new to tuning so let me know what you think.
Mods: 05 Evo 8 SSL, BBK Full ported, S1 cams, tbe with high flow cat, 3.5” fmic, licp, 850cc injectors, walbro 255, 93 oct pump gas.
3rd gear, hits 275 peak load by 3650rpm. 25.5psi peak boost tapering to about 22 by redline. Peak tq at 5500rpm. 5* at peak tq, 12* by 7200rpm. AFRs are high 12s spoolup tapering to 11.0 by redline.
1 or 2 counts of knock in 3500-5k range, some runs are 0 knock.
Best so far was 433/366 VD. Outside temps 43F. Sorry I don’t have boost or afr plot yet, working on that.
Car runs great and pulls hard, but I welcome any feedback. Thanks
Attached Thumbnails Let's see your fully tuned timing maps-timing-map.jpg   Let's see your fully tuned timing maps-fuel-map.jpg   Let's see your fully tuned timing maps-43f_11.0afr_93oct_433hp-366tq_25.5psi.jpg
Old Apr 9, 2016 | 12:10 AM
  #2652
Ian0611's Avatar
Not too bad but timing could definitely use some smoothing out.
Old Apr 9, 2016 | 04:15 PM
  #2653
ronaldo9's Avatar
We have very similar setups but i'm on the stock turbo. My map is similar to yours but I run about 4* at peak and 11* up top. I just had Ivey install a ported a buschur manifold and wow I can feel the difference already. I"m also in Central NJ if you want to compare notes. I need to retune after the manifold install because I'm running a little leaner above 3500 RPM's.
Old Apr 9, 2016 | 08:14 PM
  #2654
Thanks for checking it Ian, any specific areas of the map you would suggest?
Thanks Ronaldo, I'm also debating on porting the stock mani or going with a tubular, while porting the IM and tb.
This thread has helped me a ton. Thanks all
Old Apr 9, 2016 | 09:20 PM
  #2655
ronaldo9's Avatar
I was confused for a second because my real name is Ian lol. I wanted to keep a stock style manifold so I could keep the heat shield. I can honestly say this ported manifold was the best mod I've done and upset I never did it earlier.
