Let's see your fully tuned timing maps
Old Jan 8, 2008 | 03:34 AM
  #271
tkklemann's Avatar
Originally Posted by TTP Engineering
Hey now...
Hey Scott,
Any particular reason for the choice in the "69" number signature of you tunes?
Old Jan 8, 2008 | 04:03 AM
  #272
TouringBubble's Avatar
Maybe it was his lacrosse number in college ...
Old Jan 8, 2008 | 05:37 AM
  #273
bigric09's Avatar
maybe its the number of horsepower he expects to gain from tune to tune ?
or maybe its an old jestr ttp favorite move ? lol
im kidding im kidding ....
whatever the 69 is for, it sure does work. Im only able to put 34.5 in that square
Old Jan 11, 2008 | 10:15 PM
  #274
recompile's Avatar
Originally Posted by al\lupo
Do you get negative timings for load values > 270 @ peak too?
Nope.
But I did recently make some small changes to the map. I'll post it up tomorrow.
Old Jan 12, 2008 | 12:57 AM
  #275
C6C6CH3vo's Avatar
Isn't it correct to say it doesn't matter what number is fed to the coils from the ecu's map, so long as the peak psi (not from knock) of the combustion hit's when the crank is at about 20* on the power stroke, regardless of RPM and load?
Too many factors effect the time from when the spark light's, to when the first flame starts, the flame speed and I think theres another FF that happens too. The condition of the coils, even the gap plays a role in the spark ignition lag that will have an effect on where the actual timing really lights combustion.
Timing map values, bah
Old Jan 12, 2008 | 09:26 AM
  #276
mplspilot's Avatar
I think it's more like 15. But there's no way to control that..
Old Jan 12, 2008 | 12:13 PM
  #277
PVD04's Avatar
There's no way to control it directly, but there are plenty of ways to control it indirectly (A/F ratio, boost, ignition timing).
Old Jan 12, 2008 | 10:26 PM
  #278
cpoevo's Avatar
14* ATDC
Old Jan 13, 2008 | 12:13 PM
  #279
recompile's Avatar
You may have to do a full refresh to get the updated image (CONTROL + F5)
But here's my current map, 93oct only, 25psi:
Old Jan 13, 2008 | 12:32 PM
  #280
codgi's Avatar
^^ What AFR at peak torque?
Old Jan 13, 2008 | 05:43 PM
  #281
recompile's Avatar
During spool it's 12.0 to 12.5 and then 11.8 ish at peak torque... going to 11.5 the rest of the powerband
Old Jan 13, 2008 | 07:52 PM
  #282
RazorLab's Avatar
shameless,
I still don't really understand why you are rescaling the RPM so much in the 3k to 5k region if you are possibly only running 1* difference in that whole power band.
Also, I don't see why you added so much load resolution when you have a sea of 6's and 7's in the areas where load changes the most quickly.
This map and the earlier look like you are just doing it because you can.
In my honest opinion, you would be better off with the higher resolution 5500 and up.
Old Jan 13, 2008 | 07:56 PM
  #283
Evo_Jay's Avatar
Originally Posted by razorlab
shameless,
+1
Old Jan 13, 2008 | 10:29 PM
  #284
codgi's Avatar
Fair enough just curious.
Old Jan 14, 2008 | 02:08 AM
  #285
recompile's Avatar
shameless,
You're probably right... that's just the way I initially setup the scale, so I may try rescaling and see what I come up with. The load resolution has worked well... I always hated having to tune for spots like 210, 230, 250, 270... having increments of 10 after 200 has helped.
I will try rescaling RPM for more high RPM resolution though
