Let's see your fully tuned timing maps
Try leaning out the AFR another .2 or so and see how the car reacts. Then try adding some more boost in the midrange.
Depending on how you set-up your fuel map, you will need to fine-tune the fuel again after upping the boost
ok will do...to be continued...sheesh...hardcore tuners stay up late^just a little more accurate rpm just like 2byte load...i've logged regular rpm and 2byte rpm and it makes easier on the brain to interpolate while ur tuning. i hate interpolating
not necessarily... depends what AFR values are in your higher load cells that you will be hitting under higher boost. Normally raising your boost will lean you out some... but not always.
However, it didn't hurt the car at all because I taper the timing/fuel down at higher loads. Evolved Member
you are right... it is always our fault
... we should foresee the 28 psi on pump gas. What we should do is issue MBC's with our flashes and have some sort of lock on them so they cant be moved lol.
glad im not a tuner though...
im a rom adjuster
... we should foresee the 28 psi on pump gas. What we should do is issue MBC's with our flashes and have some sort of lock on them so they cant be moved lol.glad im not a tuner though...
im a rom adjuster
guys... just a quest. abt afr's...
i adjusted lean spool to be disabled at 7800 rpm...
then adjusted afr's to 11.5 at 3d gear
the prob i hv is that afr's are leaner by 0.5 for each gear lower than 3d (2nd 12,
1st 12.5) and richer by 0.5 for each higher gear (11 4th, 10.5 5th...), didn't try
6th...
any1 had this prob before??? what would be the possible cause?? cure?
Krgds+
6th...
Krgds+
j/k, totally j/k
