Let's see your fully tuned timing maps
Old Mar 7, 2008 | 11:28 AM
  #376
TouringBubble's Avatar
Lean spool richens the mix like that. Completely disable lean spool for a closer match to 3rd in all gears.
Old Mar 7, 2008 | 11:31 AM
  #377
EE's Avatar
EE
before and after :S
Old Mar 7, 2008 | 11:33 AM
  #378
EE's Avatar
EE
how to do it??? we set it to begin and end at 2000 rpm for example???
Old Mar 7, 2008 | 01:33 PM
  #379
Jeff_Jeske's Avatar
There is a lean spool thread to answer all those questions.
Personally I like lean spool and have no problem with it.
Old Mar 7, 2008 | 04:30 PM
  #380
RazorLab's Avatar
Factory is to begin at 2500 and end at 7,000 rpm.
You can set the end to 2500 and it basically turns it off. Or you can set both to 2000 or whatever.
Turning it off will keep the AFR more consistant in the gears. You won't see the richness problem in higher gears.
If you do a single log of say, 4th gear, from 2500 to 7500. The AFR will be pretty much how you set it in the maps. But if you do a drag style row through the gears, say, starting in 3rd, then 4th will be much richer, and 5th, etc
I've seen 4th gear be set at 11.2 with a normal pull and 10.4 in 4th when rowing through the gears with lean spool on.
Old Mar 7, 2008 | 08:43 PM
  #381
codgi's Avatar
Originally Posted by razorlab
It's 2byte rpm right by his AFR.
He is on lovely California 91
Eh too late last night evidently
Old Mar 8, 2008 | 01:22 PM
  #382
EE's Avatar
EE
Thx mate, will do
Old Jul 13, 2008 | 07:36 AM
  #383
bas_evo's Avatar
here is my timing map
this one is for a 03 evo 8 with exhaust, air filter, ams licp, walbro fuel pump
and ebc 25 psi on 93 octane
what do you guys think
Old Jul 13, 2008 | 05:10 PM
  #384
GTijoejoe's Avatar
I feel if we are going to compare Ignition tables more accurately we need:
Turbo Size
Short Mod list (exh, cams, IC)
Boost
Fuel type
Trace of Load cells for a given gear.
A/f couldn't hurt either.
Old Jul 14, 2008 | 05:22 AM
  #385
bigric09's Avatar
that is a good point... maps change tremendously
Old Jul 14, 2008 | 10:22 AM
  #386
lemmonhead's Avatar
agree, otherwise its like comparing figs to sundried raisons or apples and oranges. or like whos line is it anyways where the POINTS JUST DONT MATTER
Turbo Size
Boost
Fuel type
Old Jul 14, 2008 | 08:24 PM
  #387
khara's Avatar
Good Thread
Old Jul 14, 2008 | 08:36 PM
  #388
3star2nr's Avatar
this is a noob question but why do you guys pull so much timing at low RPMs?
The way how I was thinking about it was you would pull more timing out when the boost kicks in at high load and at higher RPMs.
How much boost can you be making at below 2000 rpms?
Old Jul 15, 2008 | 03:58 AM
  #389
bas_evo's Avatar
under 2000rpms there's no boost
Old Jul 15, 2008 | 05:04 AM
  #390
bigric09's Avatar
the lower numbers that low are for idle mainly. If you set the #'s too high, you misfire
