Let's see your fully tuned timing maps
Old Nov 5, 2010 | 10:25 AM
  #706
leecavturbo's Avatar
Originally Posted by evo8426
huh? all stock cams are the same in the usa
intresting if correct
jdm gsr and mr cars have different cams the mr being far better
Old Nov 5, 2010 | 10:34 AM
  #707
evo8426's Avatar
I was thinking they were different in Japan, but I'm almost 100% positive they are the same here since they have the same ratings for power and torque
Old Nov 5, 2010 | 10:46 AM
  #708
more lift i think if its not clear too.
Old Nov 5, 2010 | 07:33 PM
  #709
project_skyline's Avatar
Originally Posted by GST Motorsports
Not only are you way past MBT and actually losing torque, I think your going to chuck a rod.
- Bryan
Originally Posted by mrfred
+1 on Bryan's comment. Its insane. 26 psi gauge at 6000 ft is roughly equivalent to 23 psi gauge at sea level. I imagine that load is around 240, and if that's the case, I wouldn't be any higher than 5 deg timing. Didn't you do timing sweeps to look for diminishing returns?
Originally Posted by l2r99gst
I sure hope you meant peak RPM and not peak load. Otherwise, I'll be reading your rebuild thread.
Thats what I figured. Anyway its not on my car or anybodies I tuned. It was on the logs of a car I was helping a guy on. I'll post the logs here later.
And yes it was peak load/tq I'm pretty sure.
Old Nov 6, 2010 | 06:05 AM
  #710
ddb's Avatar
ddb
I've seen that when you go with a stroker you almost cut your timing in half does anybody has one timing map just to compare?I'm curious.
Old Nov 19, 2010 | 09:42 PM
  #711
04EBevo's Avatar
I would like to display my maps and was wondering how you guys import them from ecuflash?
Old Nov 20, 2010 | 10:30 AM
  #712
evo8426's Avatar
you have to take a screen shot by hitting "Ctrl and Print Screen" at the same time, open up Paint, and then paste it. After that you need to save it as a .PNG file.
Old Nov 20, 2010 | 05:12 PM
  #713
yeah or another is just press print screen. then open paint and paste. save as jpeg
Old Nov 20, 2010 | 06:37 PM
  #714
Raptord's Avatar
Please don't save as jpeg if you're using paint, it's so compressed it's barely readable. Use .png instead.
Old Nov 20, 2010 | 09:46 PM
  #715
04EBevo's Avatar
Let me know what you think. Its my first stab at this. Im running a green on stock injectors at 19lbs until I get injectors. The idc's are in the 80s. I am having trouble building boost until VERY late.
Old Nov 21, 2010 | 06:48 AM
  #716
Raptord's Avatar
Looks decent to me, nice and smooth. How much load are you seeing through the rpm range?
Old Nov 21, 2010 | 07:13 AM
  #717
i'll give it ago never really had any issues personally and nice and small file size jpeg
Old Nov 21, 2010 | 07:16 AM
  #718
boost is more likely your duty settings or a bad actuator/solenoid and/or vacuum hosing. or the worst scenario a boost leak
Old Nov 21, 2010 | 09:16 AM
  #719
04EBevo's Avatar
im on an mbc, im going to see what a boost leak test tells me. I typically see 260 load.
Old Nov 21, 2010 | 11:32 AM
  #720
ramievo7's Avatar
here is my timing map for 35r 91+50/50 wmi @ 28psi
let me know what you think ?
