SAS Hardware
Old May 12, 2009 | 09:58 AM
  #136
dolphin888's Avatar
http://ikelk.lt/images/4927
http://ikelk.lt/images/4928
http://ikelk.lt/images/4929
http://ikelk.lt/images/4930
http://ikelk.lt/images/4931
http://ikelk.lt/images/4935
http://ikelk.lt/images/4936
http://ikelk.lt/images/4937
Last photos show SAS valve (with hose attached BTW) bolted near USDM Evo 8 engine head exhaust manifold you can see in photos also fits perfectly, SAS piping connects without any mods. Plug and play
Edited: all SOLD to US
Old May 12, 2009 | 02:11 PM
  #137
laramie_05MR's Avatar
What happened to the pic of the banjo bolt in the bag? it had the part number on it.
Old May 18, 2009 | 11:13 AM
  #138
Maikumaru's Avatar
oh sorry laramie, didnt realize you guys posted.
I dont know what happened to the pic...crapola...I have no idea where I found that one.
Ok found it...just to make sure it is never deleted.
MR312702 Eyebolt
http://carview-img02.bmcdn.jp/carlif...1407130/p1.jpg
I dont know if the prices are current but it is about $13 per bolt...
Old May 18, 2009 | 12:51 PM
  #139
thanks for the part number.
Old May 24, 2009 | 02:24 PM
  #140
Maikumaru's Avatar
Installing piping now...along with all the other goods.
Hopefully up and running very soon...lol
taking my sweet *** time
Old May 25, 2009 | 01:15 AM
  #141
Maikumaru's Avatar
installed like a charm...now to see if I can get it to work.
One thing I found.
stock usdm intake does not fit with aftermarket upper ic pipe with sas outlet (trust one in particular)
the same size bolt that attaches to the pipe and valve fits into the bracket that holds the valve to the engine...
9 piping is different than the 7.
looks like the original posts piping would fit on the 9. except the valve is different...if anyone was curious.
if anyone wants to see pics...ill post them up of the install...turned out nice.
Old May 26, 2009 | 08:03 PM
  #142
rodrig.diaz3's Avatar
My Stock Evo Ix cames with Sas hardware how can i have antilag?
I cant found the hidden tables of antilag on my rom
Old May 27, 2009 | 12:47 AM
  #143
Maikumaru's Avatar
check the anti lag ECU dissasembly thread
Old May 27, 2009 | 12:53 AM
  #144
Sr20kidD's Avatar
excuse my ignorance what does the hardware do??
Old May 27, 2009 | 01:00 AM
  #145
Maikumaru's Avatar
for homolgation reasons for FIA rally...SAS or (anti lag) is installed from evo 4 onwards.
the piping and all of that is for factory anti lag...(which will be mild in comparison to full fletched ALS systems)
basically
keeps the turbo spooled when letting off the throttle.
retarding the ignition+a secondary source of air will cause ignition in the exhaust manifold...keeping the turbo spooling even when off the gas...
hopefully it works...finding out tomorrow for sure...
Old May 27, 2009 | 03:22 PM
  #146
I checked the entire Thread, didnt found the way.
Old May 27, 2009 | 07:07 PM
  #147
post your rom id and see if someone can find the tables
Old May 27, 2009 | 08:28 PM
  #148
My ROM ID 88580013 i hope some one can help me.
Regards.
Old May 27, 2009 | 11:52 PM
  #149
Maikumaru's Avatar
Everybody!!!
OK, I am proud to announce...after much work and searching...and work and research...
the thing works...
and the best part...works on stock usdm ECU.
I am still shocked.
Barry C...if you read this...
is correct. moved wire 41 to pin 4 or (5) forget...
tapped into said wire
and BAM
tunable by the ECU...
really unbelievable
Old May 28, 2009 | 04:41 AM
  #150
SkyNight's Avatar
S.A.S.: I believe it!
