SAS Hardware
Old May 30, 2009 | 05:32 AM
  #181
SmurfZilla's Avatar
ok contacted a few UK members. Hopefully they can come through.
Old May 30, 2009 | 09:06 AM
  #182
Maikumaru's Avatar
Originally Posted by chrisw
in the ALS thread, there was mention that the EGR line is shared with the stock SAS pin on the ECU.
that might be a route to take, but it would require some reconfiguration to pass emissions.
SAS pin 4
EGR is pin 5
I can see how there would be confusion...both recirculate air...
Old May 30, 2009 | 09:11 AM
  #183
Maikumaru's Avatar
Originally Posted by Green Meanie
I'll try some of our UK brethren. I'd rather deal someone from this site....lancer reigstry is last resort. Thanks guys so it looks like i need:
Complete set up from a 9 which should consist of:
pipe and valve
2 banjo bolts
SAS sensor
resevoir tank
Optional to make life easier:
stock upper IC pipe
hose from upper IC to valve or heater hose from your local autoparts store
I'll try Cossie.
After you acquired these parts and put them on what part of the EVO IX ecu did you have to alter (I swear I need to read this thread again because I think you said you put it on and it worked with having to flash anything).
He is a good start. they are friendly guys.
but I would use evom last...just my opinion.
I have a valve and pipe from a 7.
if you look at my previous posts it does not fit right....but if that is ok...then two big things are knocked off the list
actually there are two parts to this...
1. hardware
2. ecu
you will definetely have to do some work on the ECU. luckily I have a friend who come to find out was a bit genius with it lol
Old May 30, 2009 | 09:48 AM
  #184
Maikumaru's Avatar
videos posted here
https://www.evolutionm.net/forums/en...ml#post7115464
Old May 30, 2009 | 10:46 AM
  #185
SmurfZilla's Avatar
1. hardware
2. ecu
Thought it was as simple as enabling it through ECU flash (or adding tables). I posted a WTB ad on lancer register. Had one hit already but the guy owns an 8 not a 9. I'll keep trying. THanks.
Old May 30, 2009 | 12:23 PM
  #186
chrisw's Avatar
can you send me that poster I have an 8
Old May 30, 2009 | 08:55 PM
  #187
SmurfZilla's Avatar
you have PM
Old May 31, 2009 | 01:33 PM
  #188
silex's Avatar
Love how this forum comes together to help others
Old May 31, 2009 | 06:48 PM
  #189
SmurfZilla's Avatar
great community...and i've been part of a few
Old Jun 1, 2009 | 02:37 PM
  #190
williams12's Avatar
ALS without SAS and ignition degress -19º
Hi:
This is the video of my EVO VIII GSR EDM with ALS without SAS and ignition degress -19º.
http://www.youtube.com/watch?v=WvmBN08SIGY
Old Jun 1, 2009 | 08:18 PM
  #191
rodrig.diaz3's Avatar
Originally Posted by williams12
Hi:
Ok pal did you move the 3 high octane maps with negative values from 0 colum to 30 or 40, from 2500 to 7000 Rpm.
Tio solo moviste las 3 tablas de high octane? yo hize lo mismo pero nada de fuego puros pedos.
Old Jun 1, 2009 | 11:44 PM
  #192
williams12's Avatar
Sas
Hola Rodrigo:
Exacto, lo unico que hice fue retrasar el encendido a -19 º en High Octane, decir que tengo arboles Brian Crower 272/272 y por eso igual suena mas. Me gustaria conseguir un ALS con fuego.
Hi Rodrigo:
Exactly, the only thing I did was delay the ignition to -19 ° High Octane, I have to say that Brian Crowe 272/272 trees and sounds more like it. I would like to get an ALS fire
Old Jun 8, 2009 | 11:21 AM
  #193
4wdrifter's Avatar
i jsut got my SAS hardware in today and now the fun begins getting it all on the car. i also have an extra valve and tubing off an evo 4-6 i believe is this is needed by anyone on here.
Old Jun 8, 2009 | 11:26 AM
  #194
Maikumaru's Avatar
hahahahaha,
welcome to the sickness.
how are you going about manifold and IC pipe?
Old Jun 8, 2009 | 11:27 AM
  #195
Maikumaru's Avatar
nevermind...lucky guy lol
