Disabling EGR and fuel pressure solenoids
Old Sep 13, 2009 | 03:35 PM
  #166
Resi's Avatar
im just wondering, is it necessary to vent to the engine bay? installing a breather filter on line 2 and capping 1 should suffice? ...less clutter in the engine bay this way
Old Sep 15, 2009 | 02:26 PM
  #167
kaj's Avatar
kaj
so. like this??
Old Oct 4, 2009 | 07:44 AM
  #168
logic's Avatar
Originally Posted by mrfred
For USDM Evo 8 94170008-15 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/>
For USDM Evo 8 96420007-11, 96940011, USDM Evo 9 88590013-15, and EDM Evo 8 96530006 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/>
mrfred, are you sure about 1041 being correct for 96530006? It actually looks like 103d might be the right address for that ROM.
Old Oct 4, 2009 | 08:40 AM
  #169
mrfred's Avatar
You're right. I didn't actually check that one. I just assumed it would the same as all the later US variants. I'll fix up my original post in a few minutes.
Old Oct 4, 2009 | 12:55 PM
  #170
binky's Avatar
Does this code change also apply in the OBD Inspection thread? https://www.evolutionm.net/forums/ec...-mrfred-8.html?
-Bink
Old Oct 4, 2009 | 05:51 PM
  #171
mrfred's Avatar
-Bink
Nope. They have nothing to do with each other.
Old Oct 6, 2009 | 11:10 AM
  #172
kaj's Avatar
kaj
Originally Posted by kaj
so. like this??
bump
Old Oct 18, 2009 | 04:08 PM
  #173
fostytou's Avatar
EvoM Community Team
Added the how-to: https://www.evolutionm.net/forums/ev...ml#post7625687
Old Oct 22, 2009 | 11:23 AM
  #174
nonschlont's Avatar
probobly a dumb question,
but since moving to the V7 rom w/ the EGR bits disabled, (decided to see if the car liked it) is there any issues w/ disbling the EGR w/ out a block off late, and leaving the solenoids? The reason to get rid of the solenoids, is to save weight, right? I started reading up on this last night, but didnt come across this question/answer. I probobly need to re-read both threads...
The car seems fine. Havent done any pulls yet...
TIA
Old Oct 22, 2009 | 12:47 PM
  #175
kaj's Avatar
kaj
i have a question: i have the EGR disabled.. but everything is still hooked up/plugged in. if i have it disabled, do i NEED to remove the solenoid and add the block off plate?
Old Oct 22, 2009 | 02:02 PM
  #176
fostytou's Avatar
EvoM Community Team
TIA
You can just disable it. There is some discussion that it might be able to blow open under high boost, but that is not confirmed.
Additionally, removing the solenoids and other parts reduces the clutter and chances of a vac line blowing off.
The last option is to leave it all there and do the "tin can mod" (aka slice your fingers off mod) and just make an EGR gasket that does not have openings on it. Really though, the blockoff plates are only ~$5.
Old Oct 22, 2009 | 02:50 PM
  #177
nonschlont's Avatar
thanks fosty! I was thinking this was a NO NO... Good to know! Since reading up on this a lil, Im considering purchasing the blockoff plate, can you/some1 link me up? Ebay?
TIA
Old Oct 22, 2009 | 03:07 PM
  #178
Fast_Freddie's Avatar
Veteran: Navy
TIA
EGR Block off plate
Old Oct 22, 2009 | 03:10 PM
  #179
nonschlont's Avatar
Originally Posted by Fast_Freddie
thank you kind sir! just purchased and in process of setting an appt to have a bunch of stuff done, including removal of all of the solenoids...
Old Nov 26, 2009 | 09:17 PM
  #180
SeanV's Avatar
ok, after some more disassem of the EGR routines, I have found that Periphery 0 (FAA) bit11 does not actually shut off the EGR system until the coolant temp passes ~68C. Its ok to use if you plan on ripping out all the EGR stuff. However, it turns out that there is a byte length value that completely disables the EGR system and is a better choice to use.
For USDM Evo 8 94170008-15 and EDM Evo 8 96530006 use:
For USDM Evo 8 96420007-11, 96940011, and USDM Evo 9 88590013-15 use:
A value of "0" disables the EGR system and sets the EGR duty to 0% all the time. "1" enables the EGR system.
Oct 4, 2009 - Fixed to show that the EDM Evo 8 96530006 address is 103D instead of 1041.
Thx MrFred.
I have two cars here, EDM Evo9's using the stock ROM 88840016, and they both have Magnus intakes on.
"USDM Evo 9 88590013-15 use:
<table name="EGR System Enable/Disable" category="Emissions EGR" address="1041" type="1D" level="2" scaling="uint8"/"
I am going to try the above on them to see if I can get rid of the EGR/EVAP error codes.
Can you please confirm that the "1041" address is correct for the 88840016 ROM.
Thx.
