TephraMOD V6 - testing!
Old Apr 25, 2009 | 11:01 PM
  #571
nonschlont's Avatar
quick question: since we have moved to 1 byte load, Im assuming we need to change the formula for "g/rev" to reflect this. old formula = [LoadMUT2Byte]/95, so new formula would be [Load1Byte]/95???
Old Apr 26, 2009 | 01:41 AM
  #572
nano's Avatar
Wanted to give an update on my problems...or should I say lack of problems now
Thanks to tephra and fostyou, I was able to narrow my problem down to the WGDC = 100% setting along with making sure I had the correct scalings for PSI based direct boost control.
Tephra, just wanted to say thank you very much for you help and quick responses, also great job on v6...the higher resolution for wgdc was noticeable in my logs, boost holds closer to their values in the rom as far as I can see. Gear dependent boost is awesome too
And fostyou, thank you for taking the time to review my map and give me some pointers, I appreciate it!
Tephra Is your paypal e-mail the same as the gmail one? I would like to donate
Old Apr 26, 2009 | 02:04 AM
  #573
tephra's Avatar
Phil - yup same formula should work.
Nano - donations@globalshare.net, good job on getting it to work
Old Apr 26, 2009 | 07:35 AM
  #574
nothere's Avatar
for the 0015 evos going over to the 0006, what is the neatest method? wait for T 7 and download T 7 0006, or make the switch now and then update with the mod?
Old Apr 26, 2009 | 08:12 AM
  #575
fixem2's Avatar
Personal opinion, use the 5.10 version and then upgrade to V7 when released. This is due to V7 being a Beta version and 5.10 being tested and stable for awhile.
Old Apr 26, 2009 | 08:36 AM
  #576
phenem's Avatar
Agreed, I am still having issues with boost on my car. Anyone else that switch from 9417 having issues or am I the only one testing?
Old Apr 26, 2009 | 12:05 PM
  #577
Jack_of_Trades's Avatar
No issues here on 94170015 boost tables running load based targeting (I wish I had a JDM MAP sensor). I have both maps completely dialed in just fine.
EDIT: Nevermind, I thought I was in the v5.10 thread. My bad.
Old Apr 26, 2009 | 05:48 PM
  #578
tephra's Avatar
Originally Posted by phenem
Tephra, I was able to test, now the WGDC is 0% at all times! I went through every WGDC map. Which I have ROMs, one where everything is 0 and one where I have my desired boost settings. Both maps go from the crossover m(100% duty) then when 200% load is reached it shoots to 0% and stays there all the way to redline.
I can post logs later and screenshots of my settings, don't have that computer right now. Let me know if there is anything specific you want me to do or try.
~Zach
Zach can you send me your ROM?
Old Apr 26, 2009 | 07:21 PM
  #579
phenem's Avatar
You've got mail!
Old Apr 27, 2009 | 12:59 PM
  #580
shawnevo8's Avatar
question for tephra,
Q:what switching procedure are you using between e-85 and gas? ie some have said something about a toggle; what are you wiring it to etc? what does it switch on/off?
Old Apr 27, 2009 | 01:07 PM
  #581
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/ec...hramod-v5.html
The first few posts there might be able to help you out
Old Apr 28, 2009 | 05:33 AM
  #582
shawnevo8's Avatar
thank you!
Old Apr 29, 2009 | 02:14 PM
  #583
fostytou's Avatar
EvoM Community Team
http://evoecu.logic.net/wiki/TephraMod
Started to add option descriptions here. I'll add more tomorrow if I get a chance.
Does anyone know if Jack_of_Trades minds if we dump his schematics on a page for building a harness?
Old Apr 29, 2009 | 03:42 PM
  #584
I'll ask him......................yup, he said its ok lol Its for the community anyways, glad to help when I can.
Old Apr 30, 2009 | 06:30 AM
  #585
tephra's Avatar
ok just a quick update for the 0WGDC problem Zach has.
I found the problem - and have given Zach some xml to try out.
Once he gives the ok I will put the XML here AS WELL AS releasing test3
