Virtual Dyno Room-Dyno Simulator
Old Aug 24, 2009 | 12:32 PM
  #496
3gEclipseTurbo's Avatar
Originally Posted by Jack_of_Trades
First, you need to lookup the gear ratios for your particular transmission model # f5m42 (most likely online or in a haynes service manual perhaps). It appears that 3rd gear= 1.379, 4th gear=1.030, and the final drive gear=3.722
If you did a 3rd gear pull, find the gear ratio for 3rd gear and for your FINAL DRIVE gear. Enter those values on the page where you select your tire diameter.
On the dyno page, for transmission type selecet the USER option. This makes the simulator use the gear ratios you manually entered on the other page. The drag coefficient won't be the same since right now its only set for an evo 8/9 but it will get you a ballpark figure.
i cant find user for transmission type. i tryed typing it in but it says i have to choose from the list
Old Aug 24, 2009 | 12:34 PM
  #497
Jack_of_Trades's Avatar
Just choose any transmission on the list, the USER selection is in the 'GEAR' box....sorry, my bad. Once you select the USER option, its using the specific gear ratios you entered manually so transmission type is over-riden.
Old Aug 25, 2009 | 10:56 PM
  #498
the dyno sim says i have 269hp & 346tq. How close to my real hp & tq is it? i know its impossible to know for sure until i get on a real dyno, but i put in everything from the weight of the car an me to the 3rd gear an final gear ratios.
Old Aug 26, 2009 | 02:23 AM
  #499
Mellon Racing's Avatar
what dynojet data did you need in particular? https://www.evolutionm.net/forums/ev...ld-record.html
Old Aug 26, 2009 | 04:17 AM
  #500
rolly1818's Avatar
Registered User
sorry for my ignorance, is V5.6 the latest simulator? i know there was an issue with the gearing ratios for the IX 6 speed G-Box?
also the download link is not working
Old Aug 26, 2009 | 06:03 AM
  #501
It's definitely in the ballpark. Though its designed for the frontal area and drag coefficient of an Evo8/9 so it'll be off a small amount,I'm sure.
If it was a load bearing dyno, I just need the vehicle weight entered into their software. Other than that, all I need is a log of the pull and the uncorrected HP/TQ from that pull that was logged. That's it. Dynojet I assume?
I believe the gearing issue was fixed, although v5.6 still has plenty of bugs. Since we are working on a full stand-alone program now, the revisions are on hold until the new stand-alone version is released. Link works fine for me over here *shrug*
Old Aug 26, 2009 | 06:22 AM
  #502
ok, I'm sending Ryan one of the dyno owners an email right now about this. It is a Dynojet.
Old Aug 26, 2009 | 06:24 AM
  #503
Thanks man. Dynojets don't require vehicle weight since it does its calculations by the weight of the rollers, not the car. Just need the uncorrected figures and we're golden!
Old Aug 26, 2009 | 06:37 AM
  #504
ok, email sent and just for reference here's what DLL showed: this was done on the road about a half hour before we get on the dynojet
Old Aug 26, 2009 | 06:39 AM
  #505
Your car is sick man. So when are these 9 second passes happening? Can't wait!
Old Aug 26, 2009 | 06:43 AM
  #506
I ran out of e85 and my ebc is pegged so Kevin is going to borrow the truck and we'll go get 55gal more e85 and he's going to let me borrow his MBC to see if we can get it in the 43psi area. Once the tune is checked at that level we should be ready for the track.
Old Aug 26, 2009 | 07:46 AM
  #507
rolly1818's Avatar
Registered User
any idea on estimated completion?
Old Aug 26, 2009 | 07:53 AM
  #508
The guy working on it (bbarnhill) was hoping to send me a beta version to check out this week so hopefully sooner than later. I'm excited to see where we can take this OpenSource FTW! lol
Old Aug 26, 2009 | 10:18 AM
  #509
rolly1818's Avatar
Registered User
good stuff as always! cannot wait!
Old Aug 26, 2009 | 04:18 PM
  #510
I don't know if this is what you're looking for but this is what the dyno op sent me. with and without correction he says: These were done in 3rd gear btw.
