Virtual Dyno Room-Dyno Simulator
Old Sep 1, 2009 | 10:32 AM
  #571
Jack_of_Trades's Avatar
Ok, so I updated the program to version 5.61 for now. I removed the password protection on the Data Entry page where you cut 'n paste your datalog info. I also locked the Evo-M Comparator's Dyno Correction value so it will always stay the same for any future versions. I updated the Dynojet(average) Dyno Correction Factor to 1.110 as well. Let me know if there is still a problem with the BASE PULL side not showing up correctly.
CLICK HERE TO DOWNLOAD 'Virtual Dyno Room v5.61' !
Old Sep 1, 2009 | 10:44 AM
  #572
Mellon Racing's Avatar
sweet, thanks for the update
Old Sep 1, 2009 | 10:48 AM
  #573
I will try to find time to fix any other bugs this week if I can find enough spare time. I have an FP Red,FMIC,piping,cams install to do on my buddies Evo this weekend so I'm HOPING to get to it before that shows up and takes all of my free time.
I'll PM Bbarnhill and see how the stand-alone version is coming along.
Old Sep 1, 2009 | 10:57 AM
  #574
I talked to him the other day and he said it's rough but he wanted some feedback and was going to send it to me soon for beta testing.
Old Sep 1, 2009 | 11:08 AM
  #575
Colt4g63's Avatar
My base side still doesn't show up when u put data in it... It doesn't show anything just zeros out...
Old Sep 1, 2009 | 11:15 AM
  #576
WHat are you using to view it? Excel 2003,2007 or OpenOffice? If you can, email me the vdr file with your datalog loaded into it so I can SEE it happening.
Punkdivo78 at hotmail.com
Old Sep 1, 2009 | 11:19 AM
  #577
Colt4g63's Avatar
Says Microsoft Office Excel when i look at properties.
Old Sep 1, 2009 | 11:21 AM
  #578
nonschlont's Avatar
I just checked out the new version... Everything looks good except 1thing, that I have not been able to get working... Maybe Im not doing something correctly... But I have not gotten the "User Correction factor" to change anything on any of the versions... EVERYTHING else is on point!
Does this need to be accounted for, before you input the data log items?
Im on my work comp. and just wanted to take a peep, and I cant get the user correction factor to make any changes...
My "base run" is reading...
It did take 3 - 4 tries to get it to let me open it up... It was giving me some error... I tried to DL to this comp. and no go. Then just tried to open it up, and no go, gave it a couple more tries, and it worked...
EDIT: Thanks for the update!
Old Sep 1, 2009 | 11:23 AM
  #579
Did you first select "USER CORRECTION 1" from the drop-down list where you choose the dyno type (i.e; Evo-m Comparator,Dynojet,Mustang,etc)?
Old Sep 1, 2009 | 11:24 AM
  #580
Go to 'HELP', then click on 'About Microsoft Excel' and it should tell you which version. Probably Microsoft Excel 2000.
Old Sep 1, 2009 | 11:29 AM
  #581
Colt4g63's Avatar
Says Microsoft Excel 2003. The base pull is the only thing i have had trouble with. On V5.2 i can use the base side but from 5.3 on up i haven't been able to.
Old Sep 1, 2009 | 11:32 AM
  #582
Just e-mail me a copy of your v5.61 with your base pull loaded in it and I'll track down where the issue is happening.
Old Sep 1, 2009 | 11:33 AM
  #583
Colt4g63's Avatar
Will do that right now
Old Sep 1, 2009 | 11:35 AM
  #584
Colt4g63's Avatar
I forgot something important... PM me ur email
Old Sep 1, 2009 | 11:37 AM
  #585
Post #576
